My 2 year old sharp hdtv [26" i think] has no viewable picture except on the PC digital input, and no audio [no audio on any input, including pc]. The 3 video inputs all produce a full screen set of pink lines and dots alternating with a dark screen. Warranty long since expired. Have not tried VGA input Thanks. Judson Jenings
  • jenninju Apr 12, 2008
    LD-23SH1U 23" LCD color tv
    well, what i have right now is at least a working monitor for my pc/mac, and pretty good one at that. I assume if I am lucky I will find one bad part to replace, can they be bought and do they cost a lot?
    thanks
  • 156 Answers
The video thing happens as the capacitors and resistors may fail and so the video will not be seen, instead you get horizantal or veritcal lines. or in this case the case is more worse where only dots are visible. Sound problem might have occured due to variety of reasons.
But the thing here is the repair work can only be carried out by the technician, and may cost somewhere around 200$!.. so it is for you to decide on how to proceed.!
Posted on Apr 12, 2008
    Scholar:
  • 170 Answers
Need model number from the back of it.
  • 1 more comment
  • Scott Henderson
    Scott Henderson Apr 12, 2008
    actually, sharp has a problem with heat sync's and the compound they used for their heat sync transfer. remove the back, remove the boards one at a time, being very carefull of the double stacked boards, cause these connectors are very sensitive. Check all heat sync's for melting of the rubbery soft heat sync transfer areas.
    when these melt they cause several things to happen including picture problems, and no sound or sound that cuts in and out.
    please make sure you completely remote the main input board as usually there is one mounted under it.
  • Scott Henderson
    if you have this problem, then you need to clean the area's and replace it with a new one.
  • Scott Henderson
    what i do is cut the good pieces in half and use them in the bad areas.
Where is the Audio out on model NSA-40d40sna14
It is on the HDMI cable, or there is one audio output. Did you read the manual?
3 HDMI inputs for the best home theater connection:High-speed HDMI delivers a full 1080p picture and digital surround sound in one convenient cable. HDMI cable not included. Additional connections:Provides flexibility with component and PC inputs, a USB port and a DVI interface. 1 audio output.
Manual under Support and Downloads
Insignia 40 Class 40 Diag LED 1080p 60Hz HDTV Multi
Dec 14, 2016 | Computers & Internet
I have a Sharp Aquos. A video cable is connected to interface EXT-4. Video is working fine. Which audio interface can |I use to get audio too and what do I have to set in the TV menu?
There should be RCA type audio input connections near the ext-4 video cable. One red and one white. If you connect these cables you won't have to do anything in the menu.
Aug 30, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
We have a 42" sharp lcd tv we have satellite with
Hi to get the full potential of your Flat Panel, you need to subscribe to a digital HD feed. most likely they will give you a digital box for HD.
Mar 27, 2011 | Sharp LC-26DV24U 26 in. LCD HDTV/DVD Combo
What cable do I need to set up the HD and where do I plug it in? All the ones I lookes at have a rectangular end and I don't see one on the like that on the TV. I am using the 2 scart sockets for cable...
Any of these will work.
ANTENNA IN: UHF/VHF 75 ohm Din type (If in HD Broadcast)
EXT 1: SCART (AV Input/Output, RGB Input, TV Output)
EXT 2: SCART (AV Input/Output, Y/C Input, AV Link)
EXT 3: S-VIDEO (Y/C Input), RCA pin (AV Input)
EXT 4: RCA pin (Vomponant Input)
PC INPUT: D-sub 15 pin (ANALOG RGB), 3.5mm Javk (Audio Input)
Service Manual can be found here: http://www.givemefile.net/smanuals/lcd_tvs/sharp/file/45437.html
Feb 06, 2011 | Sharp Aquos LC-26GA5E 26 in. HDTV-Ready...
Hook up computer to tv
The Vizio GV47LF HDTV's connection bay has everything we'd expect. It includes a pair of HDMI inputs which can take 1080p sources (at 60 but not 24Hz), two component-video inputs, one A/V input with composite video and one with composite and S-Video, one RF input for cable for antenna connections, an optical digital audio output, and a VGA-style PC input for PC connections.
If you're connecting a computer, you'll probably be disappointed that the VGA input maxes out at 1,360x768 resolution (which did look pretty good) instead of the full 1,920x1,080. We did connect a PC via HDMI and got 1,920x1,080 resolution, but the image didn't look as sharp as the 1,360x768 version. Again, we believe this has to do with the lack of a dot-by-dot mode, although perhaps people playing with picture settings, either in the Vizio or in the video card's drivers, can achieve a better-looking higher-resolution computer image. All-in-all, shoppers looking for a big computer monitor would be better served by the Westinghouse LVM-47w1.
Jan 30, 2010 | Vizio GV47LF Television
Mitsubishi xc-3716c monitor
ttl is in short from Transistor-Transistor Logic.
Apr 18, 2008 | Computers & Internet
Televison & Video Logo
Top Televison & Video Experts
