Question about NEC MultiSync LCD1830 18.1" LCD Monitor
Monitor displays breifly then goes to blank screen
Hi, Whenever I turn on my monitor it displays the computers output briefly (~half a second) before going blank. I have tried the monitor on two other computers with the same result so it is definetaly not a computer problem. The power light on the front of the monitor stays green when the screen goes blank. Whenever I turn the power off and back on again the exact same thing happens. Help please!! Q8,Q9 and F1 on the inverter board are blown. I am looking for the value of F1 also the availability of these parts
  • 3 more comments
  • Michael Melchior Apr 12, 2008
    Yes but what value is it. How many amps. I can't find any designation on it. I live in Lethbridge Alberta I will probably have to order it.
    Thanks Mark. You saved me some time. Those transistors drive two transformers, both of which are shorted
    Thanks Mark, you saved me some time. These transistors drive two transformers both of which were shorted.
  • amtmech Dec 09, 2008
    where is q8, q9 and f1 on inverter board??
  • misty Dec 16, 2011
    Where is the inverter board? Is it the big one underneath the base?
  • 472 Answers
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Posted on Apr 12, 2008
  • Peter Thompson
    Peter Thompson Apr 12, 2008
    Most of the time these are rated at no more then 2-3 amps max.
    The original fuse would have only gone when the two transistors shorted out.
    You maybe in for a little more then you are expecting though. The transformer that was running off those transisitors has probably shorted as well.
I turn my monitor on and I see the display breifly
hi. it sounds like the power supply has gone bad... try to purchase a new power supply cord..
thank u
rate me
Jul 19, 2009 | ViewSonic VX800 18" Flat Panel LCD Monitor
ViewSonic VA720 Screen displays briefly then goes blank.
it looks like the Inverter's gone in your screen, it works like a starter in a florescent tube, it 'kick starts' your screen to come on. Turning it on/off many times eventually 'kick starts' your screen and makes it come on eventually.
Jan 15, 2018 | ViewSonic VA720 17" LCD Flat Panel Monitor
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
There is just no way you will be happy to hear it needs service or replacement under warranty.
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
I am not familiar with your particular model, but I do know what the problem is.
The inverter that runs the lights behind the screen is faulty and needs to be repaired. The lights shine from the top and bottom and reflect outwards through the panel so you can see what is on the screen. If you start the computer up, then shine a bright light into the panel you will see an image on the screen, but very feintly.
This can be cheap, it can also be expensive depending on where you go to get it repaired. Call aorund to a few TV shops in your area to get a rough idea on prices.
Hope that helps =)
Apr 11, 2008 | Sceptre X7GNAGAV 17" LCD Monitor
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After going blank, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Feb 23, 2008 | Gateway FPD2275W LCD Monitor
The green power light indicates that the monitor is receiving from the computer correctly. I suspect it is going into high voltage shutdown. There is a safety circuit that monitors the high voltage and shuts the monitor down if it sees anything amiss. So the monitor comes on and then shuts off. High voltage problems are generally not worth trying to repair. Another example of a worthless safety feature. High voltage failures are not dangerous, and adding the safety circuit just kills the unit when it may have some life left or worse, sometimes it is the shutdown circuit itself which fails!
Hope this helps.
Jan 10, 2008 | BenQ FP731 17" LCD Monitor
Wont stay on
IF there is no display even with a flashlight, the P/S board is malfunctioning. Bad capacitors or LCD driver board circuit. Mine did this and it was bad caps, 4 of 8 were bad and a burned out chip on the P/S board.
Oct 20, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Problem in monitor
Sounds like the inverter board or lamps are bad
Feb 26, 2007 | Dell E173FP 17" LCD Monitor
NEC MultiSync LCD1830 18.1" LCD Monitor Logo
584 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
