Question about Remington Smooth and Silky WDF-5000 Electric Shaver
Remington WDF-5000 Battery Replacement?
Can the battery be replaced in this unit or is it a throw away? The battery won't fully charge and it needs to be replaced. Do I need to get a new one?
  • demibell Apr 28, 2008
    hi i have a philips cool skin it wont charge its not working and no lights come on do i need new batterys its a hq7782
  • geocacher May 10, 2008
    Same problem. Sticker on unit says to recycle the Ni-Cad battery or dispose of it properly, but I cannot even open the battery compartment. Any suggestions? Took the entire shaver apart from the top, and batteries were visible, but still inaccessable.
  • 3 Answers
SOURCE: I need to replace batteries in Remington wdf 3500
Have just opened the same model -
First prise off the front and back "rubber" inserts - they should come unstuck quite easily. Then pull the bottom half of the case off the top half - it is held by 2 internal clips, one on either side of the inside black plastic casing - pull and wriggle and pull some more, and suddenly it will pop off.
Posted on Jan 31, 2009
  • 1739 Answers
SOURCE: How do I replace a
You can have the battery replaced. This however needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
http://www.remingtonproducts.com/ConsumerService/AuthorizedServiceDealers.aspx
If you are in another country, go to the top right of the screen, mouse over the Country and select your country. Look for a tab for the Authorized Service Dealer search function.
Posted on Apr 05, 2011
  • 1739 Answers
SOURCE: How do you replace the
  • 1739 Answers
SOURCE: How do I replace the
You can have the battery replaced but this needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
  • 1739 Answers
SOURCE: how to replace battery on
You can have the battery replaced This needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
My battery is stuck at 18% and wont charge any farther than that but the battery will decrease. why?
think you need to buy a new one. if it is a few years old it may need replacing. Do not throw it away though, check that a new on charges fully before disposing of it. If the new battery charges to 100 percent you know what the issue is
Mar 29, 2015 | Hisense LHDN32V66AUS 32 in. LCD TV
How to jump the soleniod on 2002 super glide
Hi Anonymous, before you start throwing big money away start by throwing small money away. First make sure your battery is fully charged, then do a load test anything below 9 volts replace the battery. Second replace the starter relay cheap $6. Third remove the back cover of the solenoid and de-arc/refurbish the contact plate and shoes making sure they are tight. Fourth make sure the starter drive/clutch only spins one way. If everything checks out ok then you can start throwing big money at it. Good luck
Jan 24, 2013 | 2002 Harley Davidson FXD Dyna Super Glide
Battery will not charge
li-Ion batteries have a bad habit: whenever fully depleted, they lose a few cells, to the extent that they might not be able to hold a full charge if enough cells are damaged. In other words, repeatedly using a laptop (or any other Li-Ion powered device) to battery depletion can shorten the battery's life significantly. You might want to keep the batteries fully charged whenever possible and avoid fully depleting them too often.
There is also the habit of "re-setting" the batteries by using the "fully deplete-fully charge" procedure. It only applies to niMH or NiCD batteries ( and is used to erase the "memory effect" ) but is damaging to Li-Ion batteries for the reason mentioned above.
so if your battery can not full charge,this mean you need change a new battery for your laptop
http://www.aulaptopbattery.com.au
Oct 05, 2012 | Computers & Internet
Starter replacement 2007 Harley Davidson flstc Heritage Softail
Aug 09, 2012 | 2007 Harley Davidson FLSTC Heritage...
BATTERY WILL NOT CHARGE
It's likely then that the battery isn't able to hold a charge due to its age which means you need to buy a new battery.
Jun 18, 2011 | Cameras
Lenovo y550 laptop, battery shows fully charged, everytime i un-plug the charger,system shuts down, and won't start back up until i plug it into an outlet
Quite simply, the battery is dead. What is happening, is that the battery is charging, but the cells cannot retain the charge and it drains straight away. You need a new battery
Jun 16, 2011 | Computers & Internet
What can I do to fix my Honeywell thermostat -- I didn't turn it off before changing batteries and now it won't work at all
Hello
If the thermostat will not turn on and it has good batteries as back up to wall DC voltage then the conclusion is that the Thermostat has failed, these are considered throw away and are not serviced by Honeywell except under warranty and then they send out a new one and "thrash" the old one, so fixing it is not an option, you will need to just replace it, a good quality electronic programmable T-stat is less than $40.00.
Oct 29, 2010 | Honeywell Programmable Thermostat Heater
Remington Smooth and Silky WDF-5000 Electric Shaver Logo
892 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
