Question about Frigidaire FEQ1442ES Electric Dryer
Frigidare Dryer Model Number leq1442es0
The dryer runs but will not heat. In a trouble shoot section it says there are two house fuses, if one is blown this could be the cause of the problem. I have been through the online documentation and also taken a part portions of dryer trying to find these fuses (just not seeing them) need help on location?
  • 3 more comments
  • Calliejazz Jun 12, 2008
    I have a Frigidaire FEQ1442S which runs but with no heat. It is only a few years old. It had a habit of switching to cool down prior to the clothes being dry. Any suggestions?
  • steveb650 Mar 05, 2009
    dryer runs but wont heat i put dryer in test mode and the element work i am confused
  • Anonymous Apr 16, 2009
    model feq1442eso dryer runs but does not get hot. is it fuses or the heat coil ?
  • Anonymous Apr 29, 2009
    I have the same problem w/my unit where the drum will turn but the heating unit does not come on. Then after a while the unit will just stop and the four-five green lights on the right side of the panel blinks.
    There are no fuses in it that I can tell either. I've looked everywhere as well.
    I just had a service tech out to do a diagnostic on the unit...here's the problem. The circuit panel in the dryer is bad and needs to be replaced. Cost of the panel is $140 and change. Labor to replace the circuit panel is $150. Overall cost of the change out of the panel...$307 and change with tax. This has been going on intermittantly for the past month or so on my dryer. If you stand there and hit the button a few times...sooner or later it will heat. I don't have the time to do that.
    This problem sounds more like a defect in the materials of the circuit board. I believe that this should be a recall situation.
  • fritzlio Apr 29, 2009
    I agree, check to see that your receptacle is running 240 into the dryer first. More than likely it is the circuit panel on the dryer. I had a tech come out today to check the same thing on mine. Circuit panel costs about $140 w/labor to replace about $150. It sounds like there are a lot of people with the same problem. It's starting to sound like a recall problem if you ask me.
    Genius:
  • 1,073 Answers
They are refering to the fuses in the breaker box of the house not the dryer, verify that you have 240 volts at the terninal block on the back of the dryer, you must have it there it is ac voltage.
if you do then you may have a heater, a thermastat, a safety limit a motor a timer a heating selector issue too many coulds to tell you right now need to be more specific if you have the proper voltage
Posted on Apr 12, 2008
    New Friend:
Did you find the fuses?
Posted on Apr 23, 2013
Did you get it figured out? i'm having the same issue.
Posted on Mar 02, 2009
Our dryer was running fine and now it wont turn on.
It could be the timer or a safety switch that keeps it from over heating.Sears used to sell a home owner repair manual.You can call Sears Parts Central or go to the web site and give them the model number and see if they have the manual. It is a pretty good easy to follow manual with a good trouble shooting section.
Aug 10, 2010 | Kenmore 600 6965 Electric Dryer
I HAVE A FRIGIDIARE DRYER MODEL NUMBER LEQ1442ES0 AND IT DOES NOT HEAT. I HAVE TESTED EVERYTHING WITH A OHM METER AND IT CHECKS OUT GOOD. WHAT COULD BE CAUSING THE DRYER NOT TO HEAT UP?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 10, 2010 | Dryers
Dryer ran for hours and did not stop automatically, now runs but wont heat?
Good day,
If set to automatic and there is no heat it will run continually run without shutting off. You'll need to trouble shoot the heating problem.
A lot of the problems are due to limit fuses and limit thermostats located in the back. Beyond that you'll need to supply the model and whether its gas or electric.
May 14, 2010 | Kenmore 500 6952 Dryer
No heat
The thermal fuse is located on the blower housing while the thermal cut-off is located on the heater housing. If the dryer is electric, runs but doesn't heat, the thermal fuse is not the problem; otherwise the dryer will not run because the thermal fuse is wired in series with the motor and cuts power to the motor when it fails. The problem could the heating element, high-limit thermostat, thermal cut-off, or cycling thermostat. These components can be found in the blower housing and the heater housing depending on the model of the dryer. Specify the model number of the dryer for a more specific advice.
Apr 12, 2010 | Kenmore 63942 Dryer
No power of any kind
This is commonly caused by a blown Thermal Fuse. The fuse is a small white component mounted on the blower fan assembly. There should be two wires running to it. UNPLUG the dryer and disconnect the component wires before taking any resistance readings. You should read something close to 0 ohms with a multimeter if the fuse is good. If the fuse reads bad, you must replace it.
The location of your blower fan housing depends upon the MODEL NUMBER. Since you posted no model, the easiest way to determine where these components are is by the location of the dryer lint screen.
If the lint screen is on TOP of the dryer, all your heating circuits are BEHIND the dryer. Just remove the back panel to access. The blower fan housing will be located on the lower left hand side.
If the lint screen is in the DOOR of the dryer, the heating circuits are INSIDE the dryer cabinet under the drum. You will need to remove the lower toe panel under the door for access. If the dryer has a solid front with no lower panel, you must lift the dryer topand remove the entire front panel for access. The blower fan housing is on the left hand side of the cabinet under the drum.
The following link can give you some more guidance on dryer no power issues:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
Refer to the section that explains the possible components for "Dryer Does Not Run At All". The Thermal Fuse is the most common cause, but there are other possibilities to consider.
Now...if the thermal fuse has blown, it usually blows for a reason. The most common cause is poorly installed, kinked or clogged exhaust vent ducting. I would strongly recommend you thoroughly inspect the ducting, air blower and cabinet interior before replacing any defective components. Otherwise, these same components will fail again.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Mar 30, 2010 | Whirlpool Dryers
How to take off heating element. The fuses seems
do you have a meter?pull one of the wires off the heater and read it out,you could have a bad thermal fuse,a,bad high limit t stat or a couple of other problems,check to make sure you have 240 volts coming in at the back of dryer at the block where the cord connects to dryer,there are 2 house fuses that can go to dryer and one could be bad,next time send model number,if the filter is on top then go to the back of dryer,if the filter is inside,take off the bottom panel and check out the thermal fuse there,it's located on the blower wheel housing it's either 3392519 or 3390719 depending on model number,if you need more help let me know,good luck
Feb 18, 2010 | Kenmore Dryers
I'm looking for the two house fuses mentioned in the trouble shooting section of the dryer manual; runs but wont heat. MODEL # is FEQB400FSI
they should be in you fuse panel in the house .how ever you can check the heating element and the thermal fuses located in the cabinet of the dryer
Sep 05, 2009 | Frigidaire FEQ1442ES Electric Dryer
How do you replace the fuse when your dryer tumbles but does not heat? it is a front load frigidare affinity electric dryer model LEQ700SE0
The fuses or breaker is located in your homes fusebox. An electric dryer requires 240 volts and 2-30amp fuses, or 1-30amp breaker. Locate your fusebox and determine if you have fuses or breakers. If fuses, then I recommend changing both 30 amp fuses to eliminate any possibility of being wrong. If it uses a breaker,(If not labled, look for the number 30 on a breaker). Flip the breaker to the OFF position, then back to the ON position. Repeat this action if there are more than 1-30 amp breakers and your dryer still doesn't heat.
May 25, 2008 | Frigidaire Dryers
Frigidaire FEQ1442ES Electric Dryer Logo
739 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
