Question about Dryers
My white westinghouse dryer blows the circuit breaker everytime I pug it in. Circuit breaker does not blow when the dryer is not plugged in.
  • viponlevi Apr 13, 2008
    Thank you for the response. I found the problem, The terminal block for the plug wire tail had melted and the terminals were were touching causing the short
  • Anonymous Mar 16, 2014
    model med5620tq0
Hi i have the same problem but with my simpson sirrico 350 with auto reverse anti tangle dryer ,i walked out after putting a load into the dryer to find the dryer had not dried the clothes and water was leaking from the front of the machine where the dials are,i left it a few days then tried to turn on but it triggers the circuit breaker (safety switch on my house meter box.can you please help me with any suggestions on how to fix the machine as i only bought this approx 2 -3 years ago thankyou sharon
Posted on Jan 08, 2009
    Genius:
  • 1,073 Answers
Check the heating element for a possible grounding to the case issue
Posted on Apr 12, 2008
Blowing fuses
Defrost element will be causing a short circuit. If the house fuse is blowing it would indicate that the value of the circuit breaker on the fridge circuit is too high.
Replace the defrost element .
Apr 08, 2014 | Angelo Brothers Westinghouse (r) Savona ES...
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
Dryer is tripping all electric in the garage everytime it is put on any ideas why? (looked at plug, checked wiring, changed fuse, emptied water and fluff filter)
First of all, if your dryer is tripping ALL the electric in the garage, you may be overloading the circuit capacity of the garage service. A major appliance such as a dryer should have its own dedicated circuit. That is, a circuit that ONLY the dryer is connected to with a separate service breaker. You may not have a problem with the appliance at all. It may be just be a matter of overloading. You should have a 220 VAC circuit breaker rated at a minimum of 30 amps for an ELECTRIC dryer. Or, a 120VAC circuit breaker rated at 15 to 20 amps for a GAS dryer.
You may also want to check to make sure you have the appliance wired correctly. If this is an ELECTRIC dryer, the following link explains how the appliance needs to wired:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have a GAS dryer, it should use a 110-120VAC configuration using either 14 gauge wiring for a 15 amp breaker and 12 gauge wiring for a 20amp. The power cord should be of the three-prong variety (HOT, NEUTRAL and GROUND). The color code for the wiring is as follows:
BLACK - HOT (110-120VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - GROUND (Usually wired to a terminal lug at the terminal block on the appliance)
If you're dryer is already configured with a dedicated circuit breaker, please post back with a MODEL NUMBER and WHICH fuse you are referring to that is blowing. I hope this information is helpful.
Apr 25, 2011 | Dryers
My dryer still runs but does not heat up (just blows cold air), any idea how to fix? Will it be a thermostat or the heater element itself?
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Jan 04, 2011 | Whirlpool AWZ7303 Electric Dryer
Dryer wont heat blows cold air
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Roper Dryers
Dryer will not heat up
Hi fairiesinfli,
Check the below:
Heating element
Thermal fuse
Regards
R.K.
Oct 22, 2009 | Whirlpool Dryers
No heat
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse which is about an inch long is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
Sep 03, 2009 | Kenmore Dryers
Speed Queed AEM677W2 dryer does not blow hot air
Below is a checklist provided by; www.repairclinic.com. They also provide repair parts, disassembly procedures and diagrams for DIY assistance.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Firstly, ascertain that you have made a positive heat selection, then read on.
Heating element
Thermal fuse
Wiring
Jul 12, 2009 | Speed Queen Dryers
Whirlpool 29"gas dryer Model#LGN2000LW1
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Dec 17, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool dryer blowing circuit everytime i plug it in
sounds like you have a heating element problem it is grounded to the heater housing
Apr 25, 2008 | Dryers
Dryers Logo
269 people viewed this question
Top Dryers Experts
