Question about PC Chips P23G Motherboard
Ram DDR2 There are 2-1 gig sticks of DDR2-533 240 pin ram in the computer! We just purchased a 2 gig stick of DDR2-533 240 pin ram. We took out one 1 gig stick and put in the new 2gig stick of ram. Now the comptuer will not boot. Then we took out the 1gig stick and put in JUST the 2gig stick of ram and it will still NOT boot. Also reset the CMOS. We do not understand what the problem is, as this motherboard supports up to 4 gigs of ram???? We have even put the new 2gig stick of ram into another computer, it WILL boot. Why with this motherboard does the extra ram not work???? Is this a BIOS Issue? If so what is the BIOS version, as it does NOT state a version when the computer is booted. It just states a bios date: AMI BIOS (C) 2005 07/20/2006 From reading on your website you need a bios version to download the apporpriate bios flash utility? We are not sure what to do next????????????? Thank you
    President:
  • 2,351 Answers
Hi Terry, you're board, PC Chips P23G only supports a max memory of 2GB. Please check pg. 9 of your manual, Installing Memory Modules.
Please be noted you can NOT use DIMM DDRII 1~2 (DDR2 533/400) and DIMM DDR1~2 (DDR 400/333) simultaneously. Only use either DDR2(533/400) or DDR(400/333) memory modules! (You should check the spec's of the other board before inserting memory that may not be supported). (You can damage the memory)
Click the link listed below for you're PC Chips P23G board.
Suggest you save this link to you're favorites.
http://www.pcchips.com.tw/PCCWeb/Products/ProductsDetail.aspx?MenuID=92&LanID=2&DetailID=387&DetailName=BIOS
You will notice there is a fix for:
Patch code to fix REALTEK clock buffer sometimes couldn't detect DDR2.
Once there, click BIOS. Scrol down to the bottom of the page & read special notes. Than click the drop down menu & pick a download site. Creat a folder on you're desktop to store the download. Uncompress the .zip file. You will than have a folder named 070115 & a ROM file named 070115.ROM
This bios flash program requires you to use a floppy disk drive to flash the bios.
Follow the instruction at this link to flash you're bios.
http://www.motherboards.org/articles/guides/42_1.html
If you find to hard to folow you can pick another from this google search site.
http://www.google.com/search?hl=en&q=how+to+flash+a+bios+&btnG=Search
Good Luck! & Take your time.
Have more questions, feel free to ask.
Mike
How to vote you're expert.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Posted on Apr 13, 2008
I have a gateway GT5228, with no ram in it will the gateway run on one stick of ram? 1 gig or no matter what I have to put 2 sticks in???
Depends on the type of RAM it is. If it's "dual-RAM" then you need both sticks. If not then 1 stick will work fine.
Feb 28, 2011 | Gateway GT5228 PC Desktop
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
Can I install one (1-gig) memory stick instead of 2 match pairs (only have one) this is to replace two 256 sticks?will it preform at 1 - gig memory
Yes.
The Maximum Total Amount of Ram Memory is 2GB.
(2048MB)
The Maximum Amount for EACH ram slot is 1GB.
(1024MB)
Ram should be installed in Slot 1, when using just one stick of ram.
This is the ram slot closest to the Processor.
The Processor reads ram memory that is installed in Slot 1, first.
This is Dell Support, and the main support page for the Dimension 3000 desktop computer,
http://support.dell.com/support/edocs/systems/dim3000/en/SM/index.htm
In the list left-click on - Technical Overview
Now click on - System Board Components
Number 1 is Slot 1.
Note*
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate computer hardware components inside a computer.
Work on a table.
After you have opened the computer case, and BEFORE you remove that ram module from it's anti-static protective bag, TOUCH the metal frame of the open computer case. (Power unplugged from computer)
This will relieve your body of static.
Ignore the above if you are already aware.
May 21, 2010 | Dell Dimension 3000 PC Desktop
I would like to add a memory card reader to my Inspiron B120 that is flush mount so I can just leave it in all the time to read my SD and Sony memory sticks. What would be best?
Hello and thank you for using Fixya.
Your brand of computer calls for DDR2 PC2-4200. This is the "type" you would need to purchase. I would recommend searching eBay for an inexpensive on. The memory sticks come in 1 gig. I would recommedn purchasing 2 sticks of RAM which would eqaul to 2 gigs total.
If you already have a 1 gig stick of RAM, then you would just need to purchase 1 more stick.
As forthe best one, any brand of memory would work. I recommedn Kingston brand but that is just my personal favorite as I know there is a warranty on it and the customer support is great.
Ebay Search
Dec 21, 2009 | Dell Inspiron B120 Notebook
2 gig ram sticks
Not with Windows XP, because more than 3 gigs isn't useful. Many servers come with 8 or more and nearly any computer you configure at the major manufacturer's websites can be bought with 8 or more.
Sep 19, 2009 | ASUS P5VD2-MX SE Motherboard
DDR2's only showing half installed RAM
IF THE SYSTEM SAYS YOU HAVE 1GB RAM THAN YOU HAVE 1 GIG OF RAM, EVEN THOU SOMEONE TOLD YOU YOU HAD 2-512MG=1GB.
HERE IS HOW I SEE WHAT YOU ARE SAYING YOU HAVE 2-DDR-2 1 GIG STICKS THAT MEAN IF 1 IS INSTALLED THAN YOU HAVE 1 GB AND IF YOU COULD GET 2 STICKS WORKING TOGETHER THAN YOU WOULD HAVE 2GB RAM.
1 CHIP SET = 1GB RAM
2 CHIP SET = 2GB RAM
YOU MOTHERBOARD MAY NOT ALLOW THAT MUCH RAM, OR WHAT I MEAN THE BIOS MAKE UP THE AMOUNT OF RAM.
TO RULE OUT ANY BAD CHIP SETS OR GOOD RAM OR BAD RAM.
TAKE THE PEACE OF RAM THAT IS WORKING OUT AND REPLACE IT WITH THE OTHER PEACE AND SEE IF IT WILL RUN.
IF IT WORKS THAN LEAVE THAT ONE IN PLACE AND INSTALL THE SECOND PEACE IN THE SECOND SLOT.
IF BOTH CHIP SET ARE GOOD THAN BOTH SHOULD WORK OKAY TOGETHER.
IF THERE IS A PROBLEM, IT MAYBE SOME DUST IN THE MEMORY LOTS
OR THE SLOT MAYBE DAMAGED.
OR
THE CHIP DESIGN LAYOUT MAYBE THE OPPOSITE SIDE, THIS MAY MEANS THE CHIPS MAY FACE EACH OTHER, OR FACE OUTWARD FROM EACH OTHER.
ROD
Mar 14, 2009 | EliteGroup P4M800-M7 Motherboard
Adding ram, but computer freaks out.
there is a jummper on the mother board you need to take off.
Jan 05, 2009 | E-Machines eMachines Desktop PC
One of the ram isnt recognised???
This is likely a memory timing incompatibility. You can go into the BIOS settings of many motherboards and set the timing specifically for each RAM slot, but without knowing exactly which piece of RAM you have I can't tell you what to set it at. You could use the utility CPU Z, install one stick, run the utility and write down all the memory information, then install the other stick and write it down too. Then go into your BIOS and see if you can set all of your specifications to match the memory.
Of course if you could find someone to swap sticks with that would be easier. Some motherboards are more picky than others about which sticks they work well with, name brand manufacturers are more picky than aftermarket in general.
Dec 30, 2008 | Computers & Internet
2 gig ram stick
Absolutely, 2 Gigs stick of RAM exist. Unfortunately your motherboard's maximum memory supported is 2GB. This site specifies very clearly 1 gig stick max per slot:
http://www.crucial.com/store/listparts.aspx?model=P5VD2-MX+SE
A.J.
Jan 28, 2008 | ASUS P5VD2-MX SE Motherboard
Not seeing other stick of ram
MAYBE YOUR COMPUTER ISNT CAPABLE OF HANDLING MORE THAN 1 GB ram UPGRAPE LOOK AT THE SPECS ON THIS MODEL TO SEE WHAT MAX MEMORY IT WILL SUPPORT.
Jan 17, 2008 | Compaq D310 (287944-CTO-4) PC Desktop
PC Chips P23G Motherboard Logo
305 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
