Question about Nikon COOLPIX L3 Digital Camera
Jammed lens Lens jammed in the middle of taking pictures, I sell on eBay so I take a lot of pictures. All I get is "Lens error" and it will not turn off or on and you can hear the motor grinding. Your quick response would be much appreciated.
  • xxeena Nov 01, 2008
    I'm on my second Nikon Coolpix, both have had the lens error within 8 months of purchase. I'll never buy another Nikon product.
  • 797 Answers
More than likely internal damage to the small gears of the lens.
A repair is in order.
See my other posts on this problem with lenses.
Posted on Jun 21, 2008
When i try to turn my camera on it sounds like its going to turn on but it stops and gives me the message on the screen Lens error 111. then it shuts off. I've been messing with it and i can get it to...
Often times a lens error comes up when the lens extension/focus mechanism has been jammed. It may almost fully function, but then the gears run into a small spot where those tiny gears are jammed, broken, have debris on them, etc. When the motor hits unexpected resistance, the camera kicks back the lens error code and shuts down before it does further damage to itself. Make sure there isn't anything wedged between where the pieces of the lens slide past each other. Past that, the best solution I can offer is to look on ebay... most cameras either die because the lens mechanism breaks, or because the LCD screen breaks. If you can find a donor camera with a bad screen, you can combine the best of both at a pretty reasonable price. These cameras are quite complicated to transplant, but fortunately most lens mechanisms and sensors are a full unit of themselves, and so are the lcd screens. Before investing in the donor camera, take yours apart and see how difficult it appears to be to work on it. Then make your decision. Good luck!
Aug 13, 2011 | Cameras
Lens stuck would not go in now it won't come out.
There is a great web page that will describe the problem, and give you a few things to try before you have to get it serviced. Here it is:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Sometimes you can get lucky with this problem, but if some part, such as a gear or lever in the lens assembly breaks, or gets jammed out of position, replacement of the lens assembly is required. They sell them as assemblies because it isn't time efficient to take them apart, troubleshoot, and reassemble. Get an estimate first if you choose to have it repaired, sometimes it's just better to sell it on ebay "as is" and buy a new one. I've seen name brands on sale for $69...10.2 mp also...can't beat that! Good luck, maybe it's just dirt jamming it.
Mar 25, 2010 | Fuji FinePix A400 Digital Camera
Displays lens error when turned on will not take pictures, lens wont open
Any camera repair guy can repair these. A store that specifically sells digital camera can repair these cameras easily. This is actually a common problem for this camera and its cousin, the m525.
I have been tinkering with theses cameras. The lens for the m425 (and m525 ) can be removed and repaired manually. Since I am a amateur, my success rate is about 50%. It all depends on how jammed the lens. If anyone has good technique in manually repair these, I would like to know.
The one good thing is that lens can be removed and swapped out with another from a m425/m525 camera. I would look for broken cameras on eBay, ones with workings lens to replace your non-working lens
Nov 24, 2009 | HP Photosmart M425 Digital Camera
Lens error
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Oct 19, 2009 | GE A830 Digital Camera
Nikon s200 when camera turned on lens error
You may have a jammed lens assy. When the camera is turned on, camera go through a few stages of processing to be ready to take picutre and if the lens does not respond mechanically, it will give you a lens error. Lens jams due to sand or impact (even unnoticable light impact). If the lens is extended out you can somehow grab the lens barrel lightly with two fingers while turning the power on and nudge it side by side. If this did not help, take it to a reliable local technician for a diagnostic(should be free). Good luck. -james
Mar 28, 2009 | Nikon COOLPIX S200 Digital Camera
Turning camera on, gets "LENS ERROR" and just stays on screen, can't take pictures.
Take a look at the little 2 grey pieces that open and close over your lens when you turn it on and off. Those might be jammed, if so try to straighten them out. That would be the easy answer, otherwise you might have a problem with lens inside the camera in which case youll need to get it repaired.
Jul 31, 2008 | Nikon Coolpix 4600 Digital Camera
Camera lens stuck
this occured to me whilst using my Sony P200, took it appart and found the lens motor had basically jumped its gears and jammed, the only solution was to replace the lense section (as motor & gears were built in) as no other part was damaged but to do that it would be at least £70 and the camera had dropped value to £160 and i could get a better camera for that amount...so my advice get a new one. and sell the remains on eBay.
May 13, 2008 | Cameras
CAMRA
you have jammed the 3 lens studs outside of the track , you cannot fix it without dissembling the entire camera to the lens,
its best to leave it alone and sell it on ebay for the lcd is worth 35 to 60
Apr 13, 2008 | Cameras
Lens error my friend
The 3 studs that allow the lens to move in a circular motion are jammed outside the track. it will require a complete dissembly to fix . most folks just sell it on ebay to a repair person.
Feb 18, 2008 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
