Question about GE WBVH6240F Front Load Washer
GE FRONT LOAD WASHER NOT DRAINING
My washer will not drain. You can here the pump trying. I guess it may be the filter, but I don't know how to get to it. If you have any tips......
  • 5 more comments
  • JHoras Apr 29, 2008
    I cleaned the filter, but it still will not spin. The door lock keeps going on and off as it cycles and the washer never fully spins. I completely cleaned the filter. Is there anything else to inspect?
  • Anonymous May 15, 2008
    machine will not drain - seems that the filter is blocked - how do you get access to clean the filter?
  • dbsmms Nov 12, 2008
    I have the same problem and I cleaned the filter and it is still not draining or spinning. PLEASE help!
  • Anonymous Dec 07, 2008
    We have the same problem
  • Anonymous Feb 17, 2009
    I have the exact problem, this machine is fairly new, and I am not happy with it. Any solutions on how to fix this problem??? Help! Please....
  • sambo 3565 Mar 16, 2009
    COULD THE DRAIN PUMP BE THE PROBLEM
  • Anonymous Apr 01, 2014
    Where is the pump filter?
I see this is an old post, but if someelse has this problem I hope this helps. I had this same problem.
My GE front load washer (GBVH6260) has a filter located behind the front cover below the door. My manual makes no mention of this filter no is it obvious. Remove the three screws located at the bottom of the cover below the washer door, and remove the cover. You will see a what looks like a knob. This is the filter. Be sure to place a pan under it as best you can. If your washer is holding water be prepared you could get over a gallon, have some towels ready. Unscrew the filter and slide it out, it slides in the same way.
Posted on Jan 10, 2009
My GE washer #WDSR2080DEWW washer won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | GE WDSR2080D Top Load Washer
GE frontload washer doesn't spin
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
GE Washer will wash but won't drain?
heatman101
Jul 24, 2011 | GE Washing Machines
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
My machine is not draining properly GE WSSH300G0WW front load washer
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Take care.
Jan 10, 2011 | General Electric WSSH300G Front Load...
Ge adora front load washer not draining
I had the same problem with mine. would figure you have it fixed by now, but it is your pump. I had a childs sock get PAST the lint filter and jam my pump. but it does not take long for the pump to go bad once something has gotten into it. Somewhat of an easy fix, if your a do-it-yourselfer
Jul 18, 2010 | GE WSXH208A Front Load Washer
GE washer not draining
You should have one. Get down low, and look at the kickplate. You should see screws just below the main front panel of the machine.
best regards, --W/D--
Jul 25, 2009 | GE Washing Machines
NOT DRAINING
means your pump is blocked. Apperently there is no main filter according to the book .
It means you will have to open the machine and disconnect the hose from the pump and clean the pump. ( i presume the pump works?)
make sure you try to drain as much of the water by putting the drainhose low into a bucket or basin.
let me know what happened
Jun 24, 2008 | GE WSXH208A Front Load Washer
GE WBVH6240F Front Load Washer Logo
1,037 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
