Question about Sharp AL-1641CS Laser Digital Copier
Sharp AL-1340 The copier recently started (3 weeks ago) making copies that are too light. Also, the left side of the paper is always lighter than the right side. This copy machine is also a printer, but the printer works fine. I have tried adjusting the settings to copy darker, but it doesn't help much.
  • 29 Answers
Try to pull out the toner cartridge and check if the developer located in the front of the cartridge is still ther and ther is no any empty space it should be pure black.if not replace the developer.
Posted on Apr 16, 2008
    Scholar:
  • 35 Answers
Try this: make a copy from the table and then one from the document feeder. compare the two. If the copy from the table looks good and the document feeder one is bad then clean the glass on the document feeder. If both are bad remove the top glass and clean the mirrors using rubbing alcohol and a lint free cloth. you can also clean the wheels on the feeder and in the tray with rubbing alcohol if you ever have feeding problems
Hope this helps
Posted on Apr 13, 2008
I have a Sharp AL 1642 CS. It prints black copies. It came out of no where so I know it isnt dust on the lens. Even after adjusting brightness settings it prints pitch black pages. The bulb on the scanner...
Problem on three things.
1.OPC drum cleaning blade is very old,so lost her activities.
2. Laser unite very dirty,so you need clean.
3. setup or configure exposure control.
# Press Auto key three second
when exposure light indicate now position,select way lighter side.
Jan 20, 2010 | Sharp AL-1642CS Copier
How can i reset the drum on al 800 sharpgrayscale
You should have on the right side of the display panel a "C" key and on the far left side your "light" exposure key.
Press c-exposure-c-exposure the scree should go blank. using your key pad make the display show 24 then press your copy key. then make it show 7 the press your copy key. Press the C or CA key until the copier resets. The light should have gone off.
Oct 14, 2009 | Sharp AL 800 Copier
Sharp AL-1340 has black spot repeating 3 times on each copy.
The problem was indeed caused by a defect in the drum. The drum surface had a small spot where the coating was missing. The drum makes three revolutions during the copying of an 8 X 11 sheet and the defect is seen on the paper as three distinct black spots. The drum had been poorly packaged for shipment by the supplier. A piece of lightproof black plastic was wrapped around the drum to shield it from any light during transiting from the shipping box to the copier. This piece of black plastic was poorly positioned and wrinkled. Additionally, as received, the drum - sealed in a light-proof bag was jammed into the shipping box and I have no doubt that the defect in the drum surface was caused by this poorly packaged shipment. I reinstalled the old drum and hopefully I can finish the current job before the drum counter times-out and shuts down before I can obtain another new drum from that company.
Apr 09, 2009 | Sharp AL-1340 Laser Printer
Loud clicking noice during copying
take the toner unit out check toner recovery bottle on the front of toner unit, empty or vacum it out dale, if not that could be gears on the machine drive, or fuser, or down in the by-pass dale
Feb 14, 2009 | Sharp AL 1631 Copier
LEAVES A BLANK LINE DOWN THE COPY
Dear sir; Try to pullout the drum unit, see have anything block the scan path( such as paper chip) or check the heat roller is there have torn paper wind up.
Dec 19, 2008 | Sharp AL 1631 Copier
Sharp AL-1340 Scanner hangs up, grinding sound, with E-7 code
The scanner rails will dry out. Try a drop of oil on the rod the scanner travels on. There are two bushings that slide along the rod/rail. Good luck.
Nov 10, 2008 | Sharp AL-1000 Copier
Random multifeeds and jams.
When it jams I take it that there is two sheets stuck together? If so then the paper tray separation pad will need replacing. To check if the machine it working ok try using the side feed.
Thanks Jason
Aug 07, 2008 | Sharp AL-1340 Laser Printer
Woodpecker noise II
A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
Are there error codes on the screen?
Make sure the right door where the bypass tray is closed all the way.
Jun 16, 2008 | Sharp AL 1631 Copier
Sharp copier AL-1642CS
Here is what worked for me.
You need to alternate pressing the clear button then one of the auto buttons until the display lights turn off.
First press the clear button (red letter “C” on the unit) then the auto button. (below the word auto there are 3 buttons. Press the one on the far left that has no other markings on it. This will only take 2 or 3 times back and forth.
When the display is blank enter the number 14 (like you were making 14 copies of something) then press the Green (start?) button. Let the copier warm up about 30 seconds and try making a copy.
It worked for me. Still having trouble call Sharp USA 630-378-3590 or Canada 905-568-7140. They were quick and helpful
Nov 07, 2007 | Sharp AL-1642CS Copier
Sharp AL-1641CS Laser Digital Copier Logo
82 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
