My LexmarkX125 shows change color ink. I put in a new cartrige and it still reads the same. Can you help me? Dino
Please i need a help with my printer all in one lexmark x75 the botton of status is linking and my printer dont work how do i reset my printer i need quicky because i loose my job please help me
Posted on Apr 19, 2008
Loaded new ink cartridges. Levels read full. Made 6 Nozzles checks. Levels showed practically empty. Paid $75 for 6 checks?
if it isnt putting out any ink and seems like it should work. then 90% of the time it means its just fine. no matter how many times you check it. youd know if you made all the ink leak out. if your unsure then id say compare weight against an old ink cartrage of the same type. there will be a diffrence. also if its not printing correctly it means that you just need to run a good 30 to 50 papers through with just that ink color and clean the hell out of the ink cartriges like 5 to ten times and wait till that color ink starts showing up. i just had to do this with a black ink cartriage.
Sep 20, 2012 | Epson WorkForce 545 All-in-One Printer
My friend had a problem of his printer, cause the printer didnt recognize the ink... it has 6 colors epson ink. we dont know how to fix it... all the cartrige shows x
Is your friend use CISS. If so
Move Ink cartrige holder to cartrige change station.
Put off cartrige ( genuin or CISS) from carrage
Take a soft erager try to remove dry in or dust or waste everything smothly
reassemble the cartrige again
push top of the cartrige gentaly sothat it struck acurately.
Turn on printer.
I think you will get rid from your pprinter problem.
Thank you
Aug 21, 2011 | Office Equipment & Supplies
Black ink does not work
A, Did u use a refilled one or a new one
B, Did u check that the black cartrige is touching the plate
C, Did u check that after putting in the cartrige the lock is put on
Nov 14, 2010 | Brother MFC-990CW COLOR INK-JET MFC Ink...
I recieve a message when trying to use my pixma cannon ip 90 that reads the color cartrige is empty, so i replaced it. still gettin message and wont print.....please help dallas44432@yahoo
Go into control panel, and right click on your printer and select properties. Under maintenance you will find the reset to show the inks as new. Also if you open the top cover while connected to your computer and then try to print a window will pop up asking if you put in new ink, answer yes and tell it which ink is new and it will be reset.
Feb 01, 2010 | Office Equipment & Supplies
Rx680 epson ink cartridge error
I was changing my cyan cartridge and got this error. I thought for sure it was that cartridge. Tried a few things including pulling them all out and putting them all back in. Didn't work.
Finally, I found a place in the software that showed the info on all the cartridges. Turned out the light cyan was not reading. Took it out and rubbed the contacts with a pencil eraser. Voila! Problem solved.
Sep 21, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Printer dont print without one of color ink
u should use all cartrige for printing with your printer
Apr 24, 2009 | Office Equipment & Supplies
Got new printer but it doesnt read the color cartige only black
what make is the printer let me know so i can help you sr tech
Jan 24, 2009 | Office Equipment & Supplies
New ink cartridge
http://h10025.www1.hp.com/ewfrf/wc/document?docname=
c00042820&cc=ca&lc=en&dlc=en&product=79499
Apr 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
56 people viewed this question
jasbo
jasbo
