Problem tuning Philips 20PV220/07. When I go to installation I can only select Set Clock and Language. The other options are in red and marked N.Ava. (not available). How do I make these options available
  • DeclanKidd Apr 20, 2008
    Thanks Dave
    This was the problem. I found out by trial and error during the week. My aint's telly is now working again. I hoped she would get a new telly but she seems happy now that all the channels are retuned.
    Many Thanks
    Declan
If you get an answer for this, please post it, I have just got exactly the same issue, I've swapped my sky boxes around, and need to add the new chanel frequency to the Philips TV, same problem as above.
Posted on Apr 19, 2008
  • Dave137 Apr 19, 2008
    Solved it.... You need to go into the timer menu and switch off any alarms which are set, (TV,Radio, buzzer), by removing the asterisk. Once that is done press okay to store, then go into the normal menu and select installation and the options which were previously not active should be there to select.
How do I change language on pioneer deh4600bt
Section
02
Using this unit
(iPod control)
c
This unit's iPod function is operated from your
iPod.
d
(Bluetooth indicator)
Set up menu
After installation of this unit, turn the
ignition switch to ON.
SET UP appears.
Turn M.C. to switch to YES.
# If you do not use the unit for 30 seconds, the
set up menu will not be displayed.
# If you prefer not to set up at this time, turn
M.C. to switch to NO.
Press M.C. to select.
Follow these steps to set the menu.
To proceed to the next menu option, you need
to confirm your selection.
LANGUAGE (multi-language)
This unit can display the text information from a com-
pressed audio file even for information embedded in
English, Russian or Turkish.
! If the embedded language and the selected lan-
guage setting are not the same, text information
may not display properly.
! Some characters may not be displayed properly.
1 Turn M.C. to select the desired setting.
ENG (English)-??? (Russian)-TUR (Turkish)
2 Press M.C. to confirm the selection.
CLOCK SET (setting the clock)
1 Turn M.C. to adjust hour.
2 Press M.C. to select minute.
3 Turn M.C. to adjust minute.
4 Press M.C. to confirm the selection.
En
FM STEP (FM tuning step)
Use FM STEP to set FM tuning step options (seek
step settings).
1 Turn M.C. to select the FM tuning step.
100 (100 kHz)-50 (50 kHz)
QUIT appears.
! The manual tuning step is fixed at 50 kHz.
! When AF and TA are turned off, the seek step is
fixed at 50 kHz even if set to 100.
5
To finish your settings, turn M.C. to se-
lect YES.
# If you prefer to change your setting again, turn
6
Notes
! You can set up the menu options from the sys-
tem menu and initial menu. For details about
the settings, refer to System menu on page 19
and Initial menu on page 23.
! You can cancel set up menu by pressing SRC/
OFF.
Basic operations
Important
! Handle the front panel with care when remov-
ing or attaching it.
! Avoid subjecting the front panel to excessive
shock.
! Keep the front panel out of direct sunlight and
high temperatures.
! To avoid damaging the device or vehicle inter-
ior, remove any cables and devices attached
to the front panel before detaching i
Feb 08, 2015 | Pioneer Deh-5400bt Car Stereo...
Windows 7 language pack
Installing the Language Pack:
1. Start off by accessing the Control Panel through the Start Menu
Then select Change Display Challenge under the Clock, Language, and Region Box. If you're in Classic View, select Regional and Language Options.
2. Make sure you're on the "Keyboards and Languages" tab and click on Install/Uninstall Languages
3. Select the 2nd option and Browse to your DVD drive or where you had previously extracted the ISO. You only need to navigate to the directory in which the language pack is in. For some reason, the ISO doesn't show up as a selectable option. (Microsoft may offer these language packs as optional updates in the near future.)
4. Click Open and Windows will automatically find the language pack. Accept the EULA and Install the Language Pack. This can take quite a while. Once you're done, you'll be asked if you want to switch to the installed language pack. Whenever you switch language packs, you will have to log off and log back in for the changes to take into effect. In the future when you want to change language packs that have already been installed, head back to the "Keyboards and Languages" tab under Regional and Language Options and you should be able to select from a menu of different language packs. Just want to note that Windows 7 Beta actually switched to my new language pack without me having to log off even though it had asked me to.
These Language Packs are untested, please download at your
own discretion:
  • Windows 7 Build 7100 Italian MUI x64 (Rapidshare)
  • Jan 14, 2011 | Sony VAIO VGN-AW330J/H Notebook
    I need a user manual for a Techwood LVD2263D flatscreen tv. I cannot install & re-tune to view TV channels
    If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service and Installation Instructions as required.
    Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
    I hope this helps.
    Dec 23, 2010 | Televison & Video
    Instructions to tune Philips tv 54cm colour TV. Search & store channelss
    Hello
    You haven't mentioned about the model number of your Philips TV. Different models have different type of tuning procedures. Any way I hereby send a procedure to set it autotuned. If it Doesn't work, please inform me through Fixya, stating your TVs model number also. ok
    Press "Menu" on the remote control handset, and select the installation language.
    Select a language and confirm it by pressing "OK" button on the remote control.
    Press ' button to return to 'Instalation' menu.
    Press "Menu" on the remote control handset and select Installtion > Preferences > Location.
    Select 'Home" and press "ok" to confirm.
    Press ' to come to the Installation menu.
    TO TUNE CHANNELS AUTOMATICLY AND TO STORE
    Press "Menu" on the remote control, "Select Installation" '>' Channels '>' Autoprogram '>' Start now.
    Press "OK" and allow the start installation automatically.
    If you run autoprogram when you have locked channels, a messege appears asking to enter your PIN code in order to complete instllation.
    Try this, if doesn't work inform me with TVs model number. OK.
    Nov 04, 2010 | Philips Televison & Video
    Hi i buyed a acer m900 QWERT with ROM and fisical keyboard in AZERT, i had instaled the ROM english, now i have a problem with the keyboard, because i'm writhing with a fisical AZERT keyboard and a QWERT...
    Step 1: Go to the Start button and open Control Panel
    Step 2: Choose the option "Clock, Language and Region"
    Step 3: Select "Regional and Language Options" and in the "Installed Services" section, click "Add"
    Step 4: If your keyboard is set to (AZERTY) change it to English US/UK and if your keyboard is set to an English language (QWERTY), change the language to (AZERTY).
    Step 5: In the "Keyboard" section, choose "QWERTY" or "AZERTY" and apply the changes by clicking "OK"
    Feb 22, 2010 | Cell Phones
    Someone has set my phone another language. How do I change the language to English
    Go to menu. You know the setting icon right. Click on that icon.In that one select first ooption named general settings. in that ,you want to select third option will be the language option in that one you can see the english option.....Hope this will helps you...Thank you...
    Oct 12, 2009 | Sony Ericsson K800i Cellular Phone
    My computer is set on a foreign language how do i get it back to english
    Instructions for Windows Vista
    1. Click Start and then Control Panel
    2. In Control Panel, if you are in Classic View, click on Control Panel Home (top left corner)
    3. Open Clock, Language, and Region
    4. Click on Regional and Language Options.
    5. Click the Keyboards and Languages tab and then click Change keyboards.
    6. Under Installed services, click Add.
    7. In the Add Input Language dialog box, select the keyboard layout you would like to add from the list available and click OK.
    8. The keyboard layout you added will be included in the list. To set the new layout as your default, select it from the list. Click OK to save your changes
    9. You can switch between different input languages (= keyboard languages) by clicking on the Language Bar button or by pressing the Alt + Shift keys
    Instructions for Windows XP
    2. In Control Panel, if you are in Category View, click on Switch to Classic View (top left corner)
    3. Open Regional and Language Options.
    4. Click on the Languages tab.
    5. Under Text services and input languages, click on the Details button.
    7. In the Add Input Language dialog box, choose the input language and keyboard layout or Input Method Editor (IME) you want to add.
    8. Click OK twice. You should now see a language indicator in the System Tray (located at bottom right hand corner of the desktop by default). You can switch between different input languages (= keyboard languages) by pressing the Alt + Shift keys
    If a language does not appear in the Input language list, the fonts for that language might not be installed. If that is the case, follow the instructions below.
    Add language support
    3. Open Regional and Language Options in Control Panel.
    5. Under Supplemental language support, select the check box beside the applicable language collection
    6. Click OK or Apply. You will prompted to insert the Windows CD-ROM or point to a network location where the files are located. After the files are installed, you must restart your computer.
    Sep 17, 2009 | Computers & Internet
    Help Please! I have lost my ? mark and its been replaced with a french e. What can I do?
    If you have Windows XP, go to Control Panel and double click the Regional and Language Options,
    In the Regional and Language Options box that options box, Under the Regional Options Tab, use the first drop down menu to select Engligh (United States) and at teh bottom of the box under Location, make sure United States is selected there as well.
    Click the Languages Tab then click the Details Button. Under the Settings Tab in the new box under Default Input Language, make sure ithe drop down menu is also set to English (United States) - US. Also make sure under Installed Services, below Keyboard it is set to US.
    If you have Vista it is similiar. Go to the Control Panel in Classic View, and double click Regional and Language Options.
    Click the Keyboards and Laguages Tab then click Change Keyboards Button.
    Make sure the Default Input Language drop down menu is set to English (United States) and in Installed Services, under Keyboard, United States is selected.
    For both XP and Vista, in Installed Services, if it is set to something other than US or United States you will have to click the Add button and select US or United States. After you add it, click to highlight the region you do not want then click the remove button
    Jul 17, 2009 | Computers & Internet
    Channel stuck and can't record shows the same night
    Your two problems are related - the DVD player lost contact with the local PBS channel, which altered its internal clock.
    Add a red, white and yellow cable from one of the outs on the back of the cable box to the slot marked AV1 IN on the back of the Philips. Then redo the channel programming - press the System Menu button and change Tuning Band to CATV - it will then ask you if you want to do an Auto Channel Set - say Yes.
    Once it is done with the channel programming, turn the DVD player to whatever channel PBS is on in your area's cable service. Then go back to System Menu - select Clock Set and go to Auto. Alternatively, you can select Manual under Clock Set and change the date by hand).
    -Tha Mp3 Doctor
    Sep 24, 2008 | Philips DVDR3320 DVD Recorder/VCR
    Tuning a Channel
    why did it get the highest raiting?? it doesent even say a solution
    Sep 23, 2007 | Philips 30PW633R 32" TV
    Televison & Video Logo
    117 people viewed this question
    Top Televison & Video Experts
