Question about iLO 2600 Television
Blue screen I can turn the tv on and even pullup the actual tv's menu. However, it will not recognize that my didrect tv is hooked up. All I get is a blue screen then it tells me no input and moniter going to sleep. Can you please help me and tell me how to fox this problem? Thank you for your help
    Problem Solver:
  • 13 Answers
It may be the component board or tuner its hard to say ,without seeing it ,how do you have it attatched to your tv ,if it is just a coaxial cable try composites or component cables ,it may just be a simple thng, your dish box is the tuner so i would start with different cable types
Posted on Apr 14, 2008
I purchased a component cable (rectangular plug I think called VGA plugs into female left side laptop toward the back and red, blue and green RCA type jacks for LG TV.
Look for a Function Key (fn) on your laptop for activating the VGA external monitor.
If your fn button is blue (for example) all of the keys on your laptop that are activated when you hold down the fn button will have an option in blue. Look for a blue icon on a key that roughly looks like a monitor or two monitors.
With everything hooked up, press and hold the fn key, then tap the corresponding key to turn on the external monitor.
Having said that... the cable you are describing has a VGA (blue 15 pin connector) that plugs onto the VGA jack of your laptop and splits that signal into a set of component RCA plugs. Its critical how you plug these into the correct place on your LG TV component connections. I know such adapter cables exist but I've never seen one work.
Sep 06, 2017 | Acer Computers & Internet
My sanyo 42 inch plasma has a blue screen, i can hear the sound on the tv but screen remains blue. can u help please
Be sure your channel settings are correct and that you have proper orientation of the hook up cables. See if your remote has a video-mute if so turn it off...a video-mute will produce a blue or black screen. To be sure its not the tuner that's enter the menu screen if you can see the menu then the tuner is ok this means the down-stream video is functioning. Be sure to have all your input devices set to the correct output ports. If all check good and still blue screen then the logic section is not processing video codecs and needs servicing.
Oct 18, 2010 | Sanyo 42 in. LCD TV
TV is turned on-only see blue screen that says Video
if only see blue screen indicate no video signal, check the yellow cable.
Apr 13, 2010 | Sanyo DS13204 TV
Blue menu screen stays on
Hi! the blue menu screen can be turned off by pressing the same button that caused it to appear. In most cases pressing the "Menu" button on the remote or TV-control will make the blue menu screen disappear..
I hope this helps!
Mar 10, 2009 | Zenith C27A24T 27" TV
TV turned off itself
Can you still turn it on?
If so, does it stay on with sound?
If the sound is ok and the picture is blue (even when changing channels, inputs, etc.) the lamp may have gone out.
Can you see the TV menu when you press the menu button on the remote or TV?
Jan 07, 2009 | Sony KP-51HW40 51" Rear Projection...
Blue screen
bad connection but where need tech.
Nov 27, 2008 | JVC AV-27D302 27" TV
Can not get the image back on my astar hdtv when I choose the option
First check Tv menu comes on screen?
Connect DVD Player at any a-v input and confirm picture on tv. This will confirm that tv has no problem except in tuning circuit.
Now check Antenna / cable hooked up in RF input of tv properly.
Perform Auto-Search / Auto-Tuning / Auto-channel on TV menu and tune all available channels.
Still blue screen? means TV Tuner looks bad.
Sep 16, 2008 | Astar Televison & Video
Rca 52 in rear projection... start up menu always on
The setup menu will repeat until it is completed and/or something is hooked up.
On my TV it kept reoccurring until I connected up the wire from the roof antenna, even though I had cable already installed.
Check your manual for setup instructions or if you do not have one, Google the make, model number and "owners manual" to see one online.
Hope this helps. :)
Mar 31, 2008 | Televison & Video
Horizontal Lines and Blue Tint on my Sony KDP 57XBR2
ok,your porblem is very simple,reheat or resolder the main board your tv.
Oct 22, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Watch tv through antenna
mine turns itself on as soon as its plugged in,goes to just a blue screen and buttons do nothing,no menu,no volume,just a bright blue screen,whats up with that?
Sep 23, 2007 | Maxent MX-42VM 42 in. Plasma HDTV
Televison & Video Logo
42 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
