Question about HP vs15 15"LCD Flat Panel Monitor
Need help hi there when i turn on my computer it seems to work but, when i turn on my panel it stays black why??? this is a recent thing
    Problem Solver:
  • 13 Answers
From what you have told me it sounds like your monitor either has a defect (the power supply, most probably), or your video card is defective. I know that this sounds rather simply but have you tried the connections: I.E. the power cord in to the A.C. socket, the video cable? Also. If you have another monitor or access to one, try plunging it in to your CPU. If she comes up the video card is o.K.
As I mentioned before, the display has probably reached the end of it's life. The expense of buying a new monitor is close to the price of repairing ti so my suggestion is to buy another.
Good luck
Posted on Apr 13, 2008
Recently our tv has been shutting off. We have
Seems to be problem with Vizio Tv's.. mine does the same thing now. it turns off an on for about 20 times before it will turn on and stay on..
May 25, 2010 | Vizio L32 32 in. LCD HDTV
Viewsonic has trouble turning on-- seems to backlight (screen lights, makes an electronic hum), and then go to dead (yet the green power indicator stays on).
Hi, well if this is the inverter board, then its probably more cost effective to buy a new screen, same thing if this is the cathode lights. Reason for that is the technician will charge to replace, so cost will get anywhere from 50 and up. Only one question, how many years old is it? I do believe Viewsonic has 3 year warranties.
Nov 01, 2009 | ViewSonic VP171B (Black) 17 in. Flat Panel...
HP vs19e Computer turns on Monitor stays Black. blue light blinks
Same here- I understand that the capacitors are bad and need to be replaced. I am going to undertake it myself. Radio Shack sells them.
Apr 08, 2009 | HP vs19 19" LCD Monitor
Lt982s
Hi...there,
You've got a busted backlight inverter...
Dec 17, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
PLANAR Flat screen goes blank and then wil not come back on, blinks a second then dies.
Hi...there
Sure, you can fixed by replaced the backlight inverter or repaired it.
Oct 31, 2008 | Planar PL1910M (Black) 19 in. Flat Panel...
Displaying issue
Hi,,,there,
That's indicated your backlight inverter are busted. Need to replaced a new one or repaired it. To repaired look for a bad capacitors with a bulged on top of each caps. Not sure, just replaced all the caps... Have a nice weekend!
Oct 11, 2008 | Samsung Syncmaster 940BW LCD Monitor
Monitor goes black and won't come back
Hi! Trish,
It's seems your Acer monitor backlight inverter are burnt out. Need to replaced a new inverter. Since is a company monitor asked your boss to get you a new one.;) Hehehe...
Oct 03, 2008 | Computers & Internet
Another question about maxent plasma monitor
Yes problem is repairable sounds like the mainboard (video) needs replacement because the rgb is part of this board along with the rest of your inputs this should fix your problem. There are some models where rgb is seperate but not many I will need the model number of your Maxent to be of further help.
Sep 09, 2008 | Televison & Video
Computer monitor screen stays black
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 26, 2008 | LG Flatron L1710S 17" LCD Monitor
Panel doesnt turn on
First check all of your connections (power as well as video connections). If they are all secure, then make sure that if there are multiple inputs that you have it on the correct input (by cycling through the sources with the corresponding button). If none of that works then look carefully at your screen to see if you can make out anything on the screen. Sometimes if the LCD inverter goes out then everything is VERY dark. Hope this helps.
Apr 12, 2008 | HP vs15 15"LCD Flat Panel Monitor
HP vs15 15"LCD Flat Panel Monitor Logo
22 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
