Question about Sony CDX-GT610Ui CD Player
How to wire a sony cdx-gt640ui in a 1999 dodge intrepid...I get sound with the tuner, but no sound with cd, aux, and usb. I'm assuming its only an incorrect wiring setup...
    New Friend:
  • 74 Answers
Instead of used the blue wire on the Sony head unit to the car wiring harness use the blue/whit wire
  • Blue - powers on only when am/fm is active
  • Blue/White - powers on when when radio is on am/fm/cd/ ect.
Posted on Jun 15, 2010
SOURCE:
Sony CDX-GT44U doesn't start. After switching off
car running or not? if it works with the car off then I would check the alternator, your car will require more power from your already low battery causing your radio to not play. If it won't start either way check all of the wiring going to it including your speakers. Could be loose or shorted wires. Could also be the switch on the unit. only way to know is to take it apart and test the switch. If all else fails then have it looked at.
Aug 19, 2013 | Sony Cdx-gt44u Cd Mp3 Car Stereo Player...
How do i fix sony head faceplate
They are not user (Repairable) It will have to be repaired buy a shop, Don,t mess around with it, You will just damage it all the more, I have been repairing car audio end home audio (Equipment for 35 (Years) End am a (Certified) Electronics Technician..
Oct 26, 2012 | Sony CDX-GT640UI In-Dash CD, MP3, WMA, AAC...
My sony 52wx4 tuner will not work. cd and aux does, but not tuner. Lights up but no sound
some of the sony tuners did have inherent problems, if your unit is a cdx-gt260 then most of these had tuner problems. best to change the entire tuner "circuit can/module" in the unit. or check out your sony service center for repair advice/cost. cheers.
Jun 10, 2012 | Car Audio & Video
I have a sony cdx-gt45ip wen playing a cd or using the tuner my sub works but wen using the aux all bas dissaperes, the sub still has power why is this happening ?
use the blue/white wire (amplifier remote turn on) to turn the amp on instead of the blue wire (power antenna remote turn on). the blue wire turns off when leaving tuner mode.
Mar 02, 2011 | Sony XPlod CD Player w/MP3 Playback...
Yes, also.... I am trying to use my AUX input but "AUX" is not an option on the Source menu. The only options are tuner and CD.
Make the audio only show the time no sound. Try pressing it off and then press a button not source. Then go through the settings by pressing the large round button there should be an option called aux a set that to on.
Feb 06, 2011 | Sony XPLOD CDX-GT200 CD Player
I have a sony xplod gt200 The truck is a 1999 Dodge Dakota R/T The deck beeps as I scroll through the menus and volume controls but will not play music in AUX, TUNER or CD. But I get Beeps. Thi sis...
the beeping can be turned off for AUX to have sound u need to have something hooked to it if there is no sound it could be blown or incorrectly connected speakers or even a blown fuse also try RESETTING the unit
Oct 13, 2010 | Sony XPLOD CDX-GT200 CD Player
Sony CDX-F5700 no longer sees Sony 10-disc changer
face plate is going bad lcd is fading solution--replace face
Jun 21, 2009 | Sony CDX-F5700 CD Player
Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Jun 03, 2009 | Sony CDX-CA810X CD Player
Sony cdx gt200
I HAVE A SIMILAR MODEL AND I HAVE TO HIT THE SOURCE BUTTON TILL AUX APPEARS MAY BE A RADIO MALFUNCTIO
Nov 13, 2008 | Sony XPLOD CDX-GT200 CD Player
No sound from cd or aux on CDX-GT32W
Just connect together the solid blue wire on the main harness to the radio with the blue/striped wire. The blue wire is for the power antenna and the blue striped is for the remote amp. but if not connected together only the fm/am has outputs to the line output RCA jacks. I learned this through Sony's tech line and it works perfectly now.
May 17, 2008 | Sony CDX-GT300 CD Player
Sony CDX-GT610Ui CD Player Logo
573 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
