Question about Compaq Presario 700 470024-192 Notebook
Computer hang! unable to boot system up,what are the common fault.
  • 27 Answers
The problem is unclear,  does it reboot by it self or simply stuck you in a no exit situation?
in both cases, my best advise is to restore windows.
Posted on Apr 12, 2008
CPU: intel core i3 550, MB: Inel DH55TC, Ram: Transcend: 2GB 1333Mhz, SMPS: 550 Watt. After first installation, this system ran for 3 months without any problems, suddenly, it became dead and assuming it...
How many years do you own that desktop computer? You have a problem with your Ram: Transcend: 2GB 1333 Mhz
Ram is always responsible to boot and run all system required by your computer
A defect ram cannot boot or not properly run application e.g.
Power-On-Self-Test (start up of your computer)
Booting your Operating System
Running your Application like Microsoft office , Photoshop and so on
Replace your Ram
Jul 25, 2011 | Intel DH55TC Motherboard
I was installing Windows 7 over Vista on an Acer Aspire 11.1 netbook with 2 Gig of ram. The system crashed (the chronic problem with Vista that I was trying to fix). Now I'm in a loop where Windows 7...
Have you tried to press F8 when the system boots ( initial screen ) and tried the safe mode or last known good configuration ?
If this does not help, try a recovery disk and it should work.
Regards,
Ron
Feb 11, 2011 | Acer Computer AO751h-1145 Aspire One 11.6"...
My system Processor is working, but its not Displaying anything. Sometime its displayed, but hangs and reboot or shutdown.Send me suggestion what should i do to solve this problem.My system Configuration...
There are different possibilities for system hang up. I want you to find it your self from following my simple instruction.
1. (when computer is turn on) Check temperature... overheating can cause system to hang up, it can cause the system to reboot, it can cause the fatal error message and turns your screen to blue. Overheating is cause by exhaust fan or blower not working. Find this blower or exhaust fan on top of the processor, as built in fan in your video card, attached on your power supply and on the casing of your computer. Replace non working fan or blower.
2. Check video card...faulty video card can cause your system to hang up. It can cause also your system to go on blank screen. Most common problem is loosen connection of video card from the motherboard. Disconnect and reseat the video card properly. Inspect the fan, if not working then video card will overheat and system fail. If you previously see moving colors in your screen especially small boxes, or discoloration and screen going black and white then it means video card is already failing. You will need to replace it.
3. Check for hardware failure. keyboard, mouse lan card can cause your system to halt and hang. You will need to disconnect this first when booting and see if by removing this hardware will complete the system to boot up to operating system. Replace faulty one.
4. Harddisk failure. when computer reset or will not boot up completely then hard disk usually cause this problem. Initial remedy is to reseat its connection sata, ide or power supply connector.
If you hear ticking sound in the harddisk or excessive vibration then it will need replacement.
5. Operating system corrupted. this can cause your computer not to boot up properly and hang the system. Reformat and reinstallation of operating system is required.
6. Power supply failure. you need to check the output voltage. dropping of voltage can be cause bi leaking capacitor in the power supply unit. replace it with exact value. Voltage should read +12VDC for yellow, +5VDC for red. and should be stable even with load.
let me know which one cause it.
Feb 07, 2011 | Intel D845GVSR Motherboard
I am unable to execute the antivirus software. It downloads to myh computer fine but when I click on the file it just hangs there. I have no other antivirus software on the computer. I am using IE. The...
You have windows 7 so do a system restore. While booting the pc keep tapping f8 until a black screen appears with a list of choices. follow onscreen directions. Don't do a destructive restore. Do a system restore back to a previous date.
You will see it.
After you do it, run a full system anti-virus scan as well as spy-ware etc....
Sep 19, 2010 | F-Secure Computers & Internet
Bluescreen/unable to use ctrl +alt +del
hi
i am techbuddies from fixya group ..
in your computer issue you need to uninstall and reinstall the operating system .
once you do this your problem will be solved but before doing this try to boot the computer in a safe mode check that whether it works or not if it works then their is a fault in hardware
Jan 04, 2010 | Computers & Internet
My computer hangs when i boot it by any bootable cd or floppy
Apparently you solved your problem and the system no longer hangs, though you never supplied the information requested.
Apr 07, 2009 | Soltek X400A (SL-85ERV2-L) Motherboard
Computer hang
Do check viruses in the system, that might cuase the system hang, initially try to boot with good antivirus cd, scan the system once viruses removed, boot to normal mode and install the same antivirus, it will works
Mar 16, 2009 | Intel Motherboard
Installing OSX 10.5 on G5 Mac Desktop Locks up
try to boot on 10.4, and then introduce de 10.5 DVD. Then the computer will ask to reboot, but with good options.
Jan 25, 2009 | Apple Power Mac G5 Desktop
Bios hangs
Reseat all cards in system, including the RAM. If it still does not boot try removing one stick of ram at a time to see if it boots. As well as removing extra cards.
Jan 05, 2009 | Intel D845PT (KD845PTPAK10) Motherboard
Booting from mirrored drive
GO TO STAERT AND CKICK ON IT ... WHERE IT SAYS "RUN" TYPE IN CHKDISK. ALSO CLICK "START" AND CLICK ON "SEARCH" SEL;ECT ALL FILES FOR SEARCH AND TYPE IN CHKDISK .... THIS MAY TAKE A WHILE. IT WILL SHOW EVERY LOCATION OF CHKDISK. CLICK ON EACH ONE AND CLICK OPEN OR RUN. ALSO CHECK ADMINISTRATOR/USER TO MAKE SURE YOU ONLY HAVE ONE. ITS LOCATED UNDER CONTROL PANEL. GOOD LUCK
Aug 31, 2007 | Microsoft Windows 2000 for PC
Compaq Presario 700 470024-192 Notebook Logo
19 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
