Question about Samsung Refrigerators
I had a FREEZER VERTICAL BRADA 1 MF 183, the alert light is always on, and my food defreezing . I dont know what to do because we followed all instruction written in manual instruction. The problem is still there. Do you have an idea about the solution. Thanks
  • 607 Answers
Are you able to measure the temperature inside the freezer to see if it is working. It may be that the compressor unit has failed, or the thermostat is faulty.
Posted on Jan 03, 2018
3 Suggested Answers
SOURCE: I have a new (3mth
I have the same problem. It's not freezing.
Posted on May 28, 2009
imufo2
  • 3773 Answers
SOURCE: Hi! My BRADA MF-305 UPRIGHT
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 27, 2011
Would not buy a mf-183 freezer again. Food doesn't freeze. I need answers.
turn the temp control down to the highest number
if that doesn't work get out a technicianunder warranty
Mar 06, 2018 | Refrigerators
E140 error
Lens vertical home position sensor error 1
- Definition - [B]
The lens vertical home position sensor remains de-actuated 3.0
seconds after the lens starts returning to the home position.
- Possible causes -
· Lens vertical home position sensor defective
· Lens vertical drive motor defective
· DC power supply board defective (check FU303)
May 18, 2011 | Ricoh FT5832 Copier
Ihave recently moved my fridge freezer ,and the red alert light has come on,could you tell me what is wrong,thanks
It comes on when there has been a power interuption to warn of a possible thaw of food or that the inside temp was high, it will correct itself within 24 hours or you can push the reset button beside the light to cancel.Please let me know if this works
Jan 19, 2011 | Hotpoint FFS70 Bottom Freezer Refrigerator
BRADA MF-305 UPRIGHT FREEZER AMBER/YELLOW LIGHT ON
I bought the same freezer and have the same question.
Anybody know? Did you figure this out vemmy?
Aug 03, 2010 | Samsung SRS20DTD Side by Side Refrigerator
MF-183 Brada Freezer
Having this same problem! cannot get past the front alert light... were you able to fix it?
Jun 27, 2010 | Samsung SRS20DTD Side by Side Refrigerator
Is the brada upright freezer 6.5 pi cu a good buy? any major problems with this product
No!!! Do not buy this freezer! Very short guarantee which makes you think even the manufacturer's don't stand by their product. I have had a problem of an orange light going on and then it defrosts everything (which you end up losing if you don't notice in time). I have searched everywhere on line and many people seem to have this problem with this freezer. I have yet to find a solution... my freezer is out of service.
Feb 08, 2010 | Samsung Refrigerators
Dell 1600N MF Laser Printer- Blank vertical strip on all prints
you need do follow steps:
1) take out the cartridge find a cover there is the drum inside, the drum you can see the color on the drum surface
2) check out and clean any pieces of paper or dirty waste toner stuck there, because there is a waste toner cleaner on the drum surface which is like a long rubbon strip (something like that) you can spin anyway a little to clean.
3) if you check out any different color (vertical round drum), that is the drum surface worn or scratched. you can see the worn area show light color than normal area.
so you need change it better. 4) if the color all very same and still not fix, you need check again something stuck the drum surface near cleaner rubbon.
hope help you fix it, please take a rating let me know how much helped you thanks! keep in touch your question please.
May 21, 2009 | Dell 1600n All-In-One Laser Printer
Refrigerators Logo
1,379 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
