Question about Dell Inspiron 8200 Notebook
Dell inspiron laptop 8200
Powers up but says there are no bootable devices. click f1 for reboot or
f2 for setup utility.
    Problem Solver:
  • 14 Answers
Sounds like the hard drive failed. If you have any super-important files on there, your local GeekSquad should be able to point you in the right direction to recover those items.
Posted on May 22, 2008
Error code: 1000-0143
I would suspect hdd errors and replace the drive.
Sep 06, 2014 | Dell Computers & Internet
Starting my laptop i get this message internal hard disk not found To resolve this issude . try to reseat the drive "which i did" no bootable devices stike f1 to retry boot , f2 for setup utility...
Hi ajmedina89,
If your system wont boot up and has a no "bootable devices" message, is often caused by a defective harddrive. I recommend to try a different HDD before replacing your system HDD to isolate the issue.
Hope it helps.
Thank you for using FixYa.
Apr 25, 2011 | Dell Inspiron 1545 Notebook
My Laptop is Dell Latitude D600 (A16) Everytime I tried to power up, Splash screen appears with blue bar and when going into next screen this message appears " No bootable devices--strike F1 to retry...
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Oct 26, 2010 | Dell Latitude D600 Notebook
Have a Dell Inspiron 1525 laptop and every now and then it is shut down for no reason with this message on the screen: internal hard disk drive not found To resolve this issue, try to reseat the...
The link below is supplied by Dell, for checking Hard drives on Dell machines, try this.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6
Aug 04, 2010 | Dell Inspiron 1525 Notebook
No Bootable Devices
Hard drive is toast
You will have to change it out and reload the "OS"
Feb 13, 2010 | VIA Bootable IDE Compact Flash Reader for...
Won't turn on
No bootable device usually means that your hard drive has failed. It is either not connected properly to the computer or the drive needs to be replaced.
Oct 27, 2009 | Dell Inspiron 1521 Laptop
My dell inspiron b130. says no bootable devices and strike f1 to retry boot. f2 for setup utility. but nothing happens just repeats sentence over and over
It may be that your hard disk is shot - or its connectors may have come loose or slightly corroded. Remove the hard disk and then reseat it back again. Good luck.
Sep 28, 2009 | Dell Inspiron B130 Notebook
Dell inspiron 1300 won't reboot. HELP!!!
Your Hard Drive may have failed. to be sure. enter setup (F2) then run the hard drive diagnostic utility. a scan can take up to an hour or more and will tell you if your hard drive has failed. if it has you will need to replace it and reinstall your operating system
Apr 21, 2009 | Computers & Internet
Windows will not start
try reseating the hard drive. Unscrew two screws on bottom right of laptop, where it IR window is. Slide the cover down, then out. Make sure the bottom connector is flush, then slide it back in
Jun 17, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell Inspiron 8200 Notebook Logo
100 people viewed this question
Alun Cox
