Have a kichen aid model kaws777e need to remove agitator -need to lookunder for lost necklace.
  • bhale3 Apr 14, 2008
    Solution was exactly what I needed . Thanks.
    Genius:
  • 3,422 Answers
Can you give me more details on your problem so that i can help you fix it.
Waiting for your reply.
Posted on Apr 12, 2008
  • Priya darshan Apr 12, 2008
    This is the procedure:
    with the palm or the heel of your hand smack the top of agitator, the
    fabric softener cup will release.it doesn't seperate to clean any
    further though reccommend soaking in hot water to clean out. reach down
    and pull up the opaque cover from the center of agitator and there you
    will fond a 7/16 bolt holding the agitator to the tranny shaft. remove
    bolt and PULL up
    Also I'll see if there is a service manual available for your model.
    Goodluck,
    Please don't forget to rate the solution
I have a necklace chain stuck between the washplate and the basket, how do i remove the washplate?
Remove the fabric softener on top of agitator and plastic insert. Use socket wrench to remove hex bolt and lift top half and then bottom half of agitator which should then expose chain.
Feb 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
/There is a gold chain necklace wedged under the agitator. How do I loosen the agitator so it will lift up just an inch or so?
remove center downy cap on top of agitator get a 7/16 socket and long extension and hold base of agitator and loosen screw in center of agitator pull up agitator out of washer...
Jan 27, 2011 | Maytag Atlantis MAV6000 Top Load Washer
A necklace has dropped down under the agitator in my Simpson Espirit 700, how do I get it out. Thanks - ****
Hi just read your posting.Now do you still require help?If you do then pull the middle of the agitator out and shine a torch down the center.You should see a 10 mm bolt.Grab a socket set and turn the bolt anticlockwise to remove it and then lift the agitator out.Please reply on how you got on and for more advice if needed.Looking forward to your reply.
Aug 17, 2010 | Washing Machines
Does not stay hot
The problem is the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Try these videos http://appliancehelponline.com/gdryertroublevideo.html
http://appliancehelponline.com/gdryertroubleshootge.html
Jun 04, 2010 | KitchenAid KGYS850LT Gas Dryer
Replacing the lever latch
Look at the parts diagram in the following:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212057.pdf
and in particular:
9 24452 Latch, Link & Lever
Hope that helps you figure out where the parts go.
Apr 07, 2010 | KitchenAid Classic Stand Mixer
Need help to remove water pump on a kitchen aid washing machine kaws777
Hello Friend, It's easy to replace the pump on your machine. First, remove the two screws that hold control panel in place and tilt back exposing the two metal clips that hold the cabinet in place. You will see some wires plugged into the cabinet, just unplug them. There are two clips, one on each side. Just pop these clips off and lift cabinet slightly from back and tilt forward. At this point you will be able to completely remove the cabinet. Once you have cabinet removed just set it aside. Now, you can easily remove the pump by snapping off the two spring clips. The pump will slide right off the motor shaft. Happy to help, Tim.
Jun 25, 2009 | KitchenAid KAWS850LE Top Load Washer
Necklace caught under the agitator
In the center of the sgitator, there is a bolt.
Sometimes there is a plug to remove by prying out.
Remove this bolt.... or just loosen it, and the necklace will come free.
See item 2 in the expanded view on the left side.
Thank you for using FixYa - A FixYa rating is appreciated!!
Jan 26, 2009 | KitchenAid KAWS750L Top Load Washer
Don't remember how to remove the agitator
withte palm of your hand youllneed to remove the fabric softener dispensor(a solid bump) will dislodge it, after that youlll gain acess to the center shaft of agitaotr, remove small white cover and underr youll see a 7/16 bolt head, remove the bolt and the agitaotr will pulll right up and then reinstall the same way
Jan 06, 2009 | KitchenAid KAWS850L Top Load Washer
Necklace stuck in washer
Hold the bottom part of the Agitator,(The part that you are talking about),Undo the very top part in an anti-clockwise direction and it will come right off.Use a wrench to remove the nut on the top of the agitator and then lift it right out,you may need to move it from right to left.You will now be able to remove the necklace.Replace the Agitator the reverse of removal.
DW
Oct 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Necklace wrapped around bottom of agitator
1. Pry off protective cap with knife or small screw driver.
2. Remove agitator bolt
3. Lift off agitator
4. Retrieve Necklace
Regards;
reg501
The FixYa team
Jun 23, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
