Question about Bernina Virtuosa 160
Programmed stitches on the 160
Most of the programmed stitches on my Bernina V. 160 don't perform as they should -- funny stitching, nothing like it used to work. It was cleaned and serviced a year ago and new hook installed. Can this be repaired/remedied??
  • 202 Answers
As a Bernina tech I can tell you to try adjusting the stitch balance with the small knob on the side + or -. Just in little increments until they start to look right. Maybe this has gotten turned too far off. If this doesn't help (50/50), worst case scenario most likely the small gear has been jarred loose or has skipped a tooth to the stepping motor which means a tech will have to reset this and balance it from the inside. There are also steps to take in the service program but again this would be a job for a tech. I suggest you get the whole clean, oil and adjust as this would be included in that.
Posted on Jul 27, 2008
I cannot get the green decorative stitches to work. I'm insure if my Bernina 930 is broken or I'm just unfamiliar with this machine. How do I set my machine for the embroidery stitches?
There are 2 levers on the top that need to be set. One shows the green stitch selections. That needs to be set to your stitch choice. To its right, there is another lever called the "changeover lever." It needs to be pushed all the toward the back of the machine--that switches it from straight stitch to decorative stitch.
Then on the bottom front on the right is a large knob. Both the outer ring of the knob and the inner knob perform different functions. One drops the feed dogs for darning or raises to activate the feed dogs to pull the fabric through the machine. The other part switches between the red and green stitch selections. When that knob is turned the light should show green or red to coordinate with the stitch selection lever on the top of the machine.
So to make decorative stitches, there are 2 levers that need to be moved plus the red/green activator knob. In addition, you will want to adjust the stitch width dial and the stitch length lever to widen or lengthen the stitch.
If you need a manual for your machine, you can download it free here:
BERNINA Support Machine and Accessories Finders and Software Support...
Apr 07, 2016 | Bernina Sewing Machines
Sewing Machines How do I make a zigzag stitch
When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
  1. Step 1 Zigzag Stitch. ...
  2. Insert your fabric into the sewing machine and depress the presser foot. ...
  3. Guide the fabric through the machine to keep the stitch straight
Zigzag Stitch iFixit
How to Make Zigzag Stitch Sewing Machine
Bernina 550 40 Triple Straight Stitch Zig Zag
Zigzag foot 0
Bernina Sewing Machines How do make zigzag stitch Google Search
on Dec 13, 2017 | Sewing Machines
I have a Bernina 1230, that was a gift from my mother-in-law. I need help creating continuous decorative stitches and I don't understand the user guide directions.
What a Great Gift!!!
The manual is a bit confusing. From what I can gather, it looks like to program, press MEM, select the first stitch, press MEM, select the next stitch...end programming with MEM.
Press "pattern begin" to start and then "pattern end" to end.
If you are interested in joining a Bernina group who discusses all kinds of questions and tips about using older Bernina machines, look for a Yahoo Group called "BerninaThirtySomethings" The members are very helpful and some are Bernina technicians who know a lot about the machines.
Actually, you can also download the 1260 manual. It is very similar to your 1230 but may be easier to understand. Look at the memory instructions there (page 26...). It appears in order to perform multiples of a particular stitch, after selecting that stitch, press the MEM button that many times.
Mar 16, 2016 | Sewing Machines
Need to change stitch density
Hi Debbie,
I found the command for this change in the Features menu called "Balance" and it has a "b" symbol. In the ARtista 185 instruction manual this appears on page 30 so probably around there in your manual too.
Manual says
"Balance - touch symbol to open balance screen, correct forwards and reverse stitches, correct sideways motion stitches.
If you dont' have a manual you might want to download the 185 from the Bernina website, the link is
Hope this helps you to resolve your issue.
Oct 10, 2011 | Bernina Artista 180
Bernina 1080 while sewing normal stitch, stitch
What stitch to you have selected for it to do? Please check to see if it is set for straight stitch only.
Linda at Relics
Jul 05, 2011 | Bernina Sewing Machines
Bernette 75 won't Zig-Zag
Is there a stitch width setting and has to be set to a number greater than zero?
May 14, 2010 | Bernina Bernette 75
Bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
Jul 27, 2009 | Bernina Virtuosa 160
Bernina 1008 - tension problems
Make sure the presser foot bar is UP before you thread the machine, otherwise the thread doesn't connect propertly with the tension discs. Top thread should reel-off in clockwise direction.
Jan 02, 2009 | Bernina 1008
Sewing Machines Logo
74 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
