Question about Kitchen Ranges
I have a Jenn-air nat. gas stove Model # SCG202000W the lower oven burner takes very long time to ingnite then it only has avery small flame less then 1/4", the top broiler burner works fine so do all the top burners. seems like no little or no gas is getting through.
  • jpdj Apr 12, 2008
    I have already checked that and also the jet is clear now there is no light off at all.
  • 983 Answers
I think there are obstacles in the tiny holes ...
take a small pin and clean it and have a check is the gas is getting through it...
any further queries reply me ..
i am always here to assist you
thank you
bye..
Posted on Apr 12, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Apr 12, 2008
    the pipe from which the gas comes near that burner is having some obstacles in between it ...
    the other burner is working fine as there will deviation of the pipes to the different burners the other burner s pipe s deviation is clear in path ...
    while from which you are getting small flame there in that pipe deviation there is some problem i think due to obstacles ...
    open that and clean that also then have a look...
Jenn-Air JGR8850 Gas Oven doesn't hit the right temperature
this is the oven thermosat of the flame failure device not working , you could be looking at buying new as this wiil not be cheap fix ..............
Jul 31, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Installed stove, no flames on burners?
It may still have air in the system, turn on one burner on and allow the gas to flow with a lighter in the path of the gas see if the gas lights of at least explodes I mean until it goes Poof, once it does that if it does not light then pull the top off the stove and adjust the vents on the pipes to focus the flames and how much air is blended in with the gas, also turn the burner so that the holes are half way open, I am not sue about your stove but most have an adjustment by turning the burner 1/4 of a turn to change the flame characteristics. if this does not help post here and I will see what else I can find out on your stove. I need the modle of the stove and the regulator number where the gas hooks up.
Jul 23, 2009 | Kitchen Ranges
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Jenn aire oven no power.
go to jenn air web site -find your stove model number and find user & care guide that should help you
Mar 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Covert a frigidaire stove to nat. gas
Lift the top of the stove up. Then there should be 4 nuts on the backs of the burner controls. Turn them left to open the valves for nat. gas. You want just a small amount of yellow on the flame. Then take the droor out of the oven and there should be another nut close to the gas valve for your oven flow. Do the same to the oven.
Nov 20, 2008 | Frigidaire FGFB75D Gas Kitchen Range
Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Super Capacity 465 Gas Range
my gas stove top burner will not ingnite when I turn on the gas.
I have gas supply to the house, the gas stove top makes the tick tick noise when you
turn one of the burners on, but no flame, even if you try using a match.
What all can I checK?
Sep 20, 2008 | Kitchen Ranges
Jenn-Air JGR8855BDS Gas to propane conversion
propane is higher pressure than natural gas, there should be some orifices on the stove for the top burners, some have them near the top in a metal clip, some have them in a lower location, usually you can see them from the back of the stove. the oven and broiler may only need "tightened down", and the air blend will probably need adjusting for "flame color", you don't want yellow flame tips, good luck!
Jul 18, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Kitchen Ranges Logo
100 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
