Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My RCA D52W20 will not stay on
A couple of days ago, I turned on my tv and the green led power button came on and I heard the normal click and then the led light continued to come on and go off all along with the clicking for about three cycles and then finally cut off. I tried again and nothing. I waited about 10 minutes and it did the same thing again, but this time it did finally pop up the picture and sound and appeared fine for about a minute and then cut off again. I unplugged the set for about four hours, plugged it back in and it cut back on and was normal. Turned the tv off that evening and the next day it went through the same sequence of the power button coming on and off and the same clicking sound of the tv trying to come on. Unplugged it again all night and this morning when I got up, the green led power button was constantly blinking and the tv would not come on. I unplugged it and the light continued to blink for about 20 seconds and now nothing. My remote has always been weird and every time you hit the on switch the six buttons right below (tv, dvd, vcr, etc) blink through each button at least once before the tv button finally remains lit. There are also times when the remote will not turn the tv on unless I mess with it for a white. I'm not sure if it is the original remote - it says RCA Universal - we got the tv and remote from a friend about a year ago. We have actually had no problems with the tv and love the picture and sound quality. Just don't want to take it to a repair shop and get ripped off with a bill that is more than the tv is worth. Any help with repairs or advise would be greatly appreciated.
  • 2 more comments
  • oneanother Apr 21, 2008
    My D52W20 will not turn on. When you hit the power button, it turns green, makes a clicking sound and turns off. It never comes on. Need solution. thanks.
  • Victaman Apr 21, 2008
    It appears, in reading this board, that this is a common issue with these televisions. Mine also began doing this and would, after repeated attempts, finally turn on and stay on. My "solution", if you want to call it that, was to just leave the TV on once it was on and turn the sound/picture off through my home theater system. This worked wonderfully until the other day when my step-daughter turned off the TV. Now I can't get it back on...
  • jwatsonkk Apr 21, 2008
    yep that the same problem we have. The green light comes on and flashes turns off. It use to turn the tv on for awhile and then turn off . but now nothing. we changed the flyback and it stills does nothing. This is a peice of ****. dont buy
  • grandmatv Apr 23, 2008
    my tv is pink and green and it makes a poping sound and then you smell burining smell and then the tv shouts off it self
    Sergeant:
    Champion:
  • 319 Answers
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Posted on Apr 23, 2008
RCA D52W20 52--Delayed Power On and does NOT turn on now.
U DM power supply board have dead capacitors,before the capacitors have some functions left,that why u able to recycles by pushing the power buttons 3 or 4 cycles to get power to the tv.U have tools,soldering iron,solders,and know to do soldering?Tries website like Tvrepairworld.com to buy a capacitors kit,that design to replaced in the DM power supply board.Look around and replaced these dead capacitors,it alway bulges up or puff up on it top.Ur tv will power up and as normal again.
May 30, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 WONT TURN ON...GREEN LED ON /OFF THREE TIMES
LOCATION NUMBER CP114,CP150,CP140,CP120,CP130 ANY CAN BE BAD ALSO SOLDER LOOSE CONNECTION UNDER FLYBACK
Aug 28, 2009 | RCA HD52W58 52" TV
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
My RCA model D52W20 will not fully power on when we try to turn it on by using the power button on the tv or by using a remote. There is a click and the green light that shows power lights but the tv does...
unfortunatly the rca d52w20 is a flawed tv, they a high rate of problems with the power supply and convergence amps, both parts are no longer available, i have scrapped those sets that were barley a year and a half old. sorry and good luck
Mar 20, 2009 | RCA 20F510TD 20 in. TV/DVD Combo
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
RCA D52W20 52 in. Rear Projection
the main pwr board is defective and will need replacement...
Oct 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
kimmipoo_2000@yahoo.com
Apr 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
349 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
