Question about GE GSS22JFMWW Side by Side Refrigerator
I Have a GSS22JEPAWW, Water no longer working
I have a Side by Side that no longer dispenses water, the icemaker works but water won't come out of the door???? any ideas.
Thanks
  • Anonymous Jun 01, 2008
    the water does not come out of the door, ice does, crushed ice does but not water. Maybe a drip or two but that is it.
  • kjls Jul 24, 2008
    We have the exact same problem. The GE technician diagnosed the problem as a frozen water line inside the door. He stated that it is a design flaw, and offered to install a heater inside the door to fix the problem at a cost of $250.00. We refused to pay for GE's design flaw, and we contacted upper management at GE to discuss the issue. They refused to pay for the repair. We still have not had the refrigerator repaired.
    Genius:
  • 1,073 Answers
Check the water valve at the back of the washer, if valve shoes good then remove the larger line off of the dual valve and blow through it if it blows freely the line is ok if it does not then there is and obstruction water line frozen,
if it has no obstruction then the problem lies in the freezer control assy in the frount of the freezer door
Posted on Apr 12, 2008
Icemaker works but water doesn't dispense. I have
I think our water will dispense but our tab(arm) came off track and we don't know how to put it back on. Our icemaker works fine but can't see how the arm should be on. Let me know if you have any advice. Thanks, Shelby ~ Ohio
Feb 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our water dispenser no longer gives us water, but the ice cube maker still works
The water valve in the rear needs replacing. There are different parts of the valve that direct water to the icemaker and the dispenser, but the whole valve will have to be replaced.
Jan 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Jenn-air side-by-side water dispenser leak
Check the fill tube to your icemaker and see if it has ice in it or in the fill cup to the icemaker. Most of the time when this problem happens it is the icemaker spraying the water. It could also be a bad module on the icemaker which can get stuck in the fill position and spray water all over the freezer.
Sep 14, 2009 | Refrigerators
Icemaker doesn't work
chack water valve and make sure it is getting water if so and there is ice in ice maker then your heater is bad and not releaseing ice
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Icemaker works; water dispenser not
You can get to it, it is just a matter of figuring which valve has gone bad. You may need to disconnect different lines and actuate the water dispenser to see if water comes out of the valve. You gain access to the valves from behind the machine by removing the access panel that is at the bottom
Jun 16, 2009 | Amana SXD524VW Side by Side Refrigerator
Icemaker not working, but water dispenser is
Water valve has separate coils for water to door and to icemaker. If icemaker is cycling the valve is likely the problem.
May 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker not working,water pours from dispenser side
it could be water valve or ice maker that has gone bad.check all connectins to icemaker and tubing to icemaker and water valve.
Mar 20, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
GE GSS22JFMWW Side by Side Refrigerator Logo
93 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
