Question about Canon PIXMA iP1600 Printer
Canon 1p3300 paper jam
Last night as I was printing jewel case covers, for some unknown reason several pieces of paper tried going through my ip3300 printer. The printer jammed. As gently as possible I removed the paper. When I looked inside the printer all the lights on the ink tank were out.
My question is have I damaged the printer beyond repair or is there a way to restart and get back to printing?
  • 96 Answers
Remove all paper.Turn off printer.
Recycle power.
all should be ok.
Posted on Aug 03, 2008
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
Jan 13, 2013 | Canon IMAGECLASS MF-6530 Multifunction...
Please help with cannon PIXMA MP150 printer problem, when trying to print, It reads that paper is jammed but I've checked several times and no paper is jammed. Printer will not print due to this...
Hello and Welcome to FixYa!
Paper jam means their may be small bit paper jam in side
, actually there are some "micro sensors" that detect a paper jam. There will be tiny piece of paper inside those sensors, thus tripping the sensor and paper jammed keeps coming up.
To solve this first of all Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
, If you become sure that now really there is no paper, dust or foreign objects then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
I hope this solution helps you
Thank you for using FixYa!
Aug 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Display states paper jam, open cover, reset... paper comes out 90% & then gets stuck... can pull paper out & last 1/2 inch has an imprint like the paper is in a vice grip
in this case I think you not choice the correcte paper if you make print from the computer go to the printer and try to choice a corect size paper ( A4)
Dec 01, 2009 | Canon FAXPHONE L170 Plain Paper Laser
After paper jam text is offset 1 mm every 0.5"
you still have a piece of paper stuck some where in the paper path have a closer look
May 12, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Printer jams. gray foam released in paper path.
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Try this I found it doing a search on your machine, that foam was called a blotter, and it should work without it, good luck
Dec 19, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Canon printer i pixma ip3300
nothing's the may find some useful information in this link area, under the search engine for fix your own printer.
Mar 20, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP160 showing paper jam, but none
just recently had these problems
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
good luck...
Feb 24, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma mp 160
HI this is happening to me right now too-- try this-- I'm not sure if it's going to work-- but it's worth a shot.
On your computer, go to a print menu to print a document.
click on properties
go to maintenance tab
try the quiet/sleep mode
also, try going to custom and slow down the printing allowing for a little extra dry time.
reason I suggest it: my printer is doing the same, it's almost like the auto sheet feeder (only on the right side--why paper is grabbing weird) is grabbing too quickly. When in sleep mode, it seems to slow it down a little. I've also been printing 1 page at a time. I'm not saying this is a permanent fix, but at $50 for a pack of ink-- hopefully if you can't fix it-- it can get you to use up the last of the ink you have incase you decide to get a new printer.
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
91 people viewed this question
old marine
old marine
