Question about Canon Pixma MP800 All-In-One InkJet Printer
Canon Pixma MP 800 printing Issue (heavy black line on opposite side of print page
When printing from a PC or when copying,  a large (1/4" wide) black line appears on the opposite side (that is being printed on) of the sheet of paper.
It appears that before  printing begins a large drop of black ink is released before the paper arrives creating a puddle that is then spread across the back side of the printed document.
We have changed ink cartridges and it hasn't solved the problem.
Almost appears to be a software/signal problem sending a command to open the ink cartridge before the print information has arrived.
Any idea what's causing this and how to proceed?
Rickaydee described it beautifully. What do we do?
  • 4 more comments
  • pyc44V Apr 14, 2008
    I have the same from two weeks ago. have reinstall drivers --> no change, have change cartridge ---> no change. i think it come from the support of the head when the printer is off. In my case this support is very dirty, and its'not easy to clean it without the service manual...
    to see this part, put on the prinetr, open as if you want to change cartridge and then put line cord out. head will stay in the middle and you will see on the right part, under the cover the location of this part.
    i think solution is to clean, not to change the head or somethink else. But canon dont put the service manuel in public area..
  • Anonymous Apr 26, 2008
    when printing, a dark line appears on the backside of each sheet, creating a messy copy
    when printing on the pixma mp800, a black ink line appears on the backside of the printed sheet, creating a messy product.
  • Anonymous May 30, 2008
    it is related to the head clean signal, dumps black ink in quanty leaks on to rollers, sorry don,t know how to fix. New print head is almost £100 and not sure to fix problem
  • rmrau Nov 23, 2008
    I have the same problem with my Canon Pixma MP530. If I print many pages, the line eventually fades away, but the amount of ink in the line has been getting greater over time.
  • Wolsey May 11, 2010
    I have a Canon Pixma MP800 with the same problem, a heavy black line on
    the back of the page. If I clean the roller it might print 20 pages
    cleanly and then it returns and fades away over 10 pages, then 20 clean
    pages then a heavy black line again. I have changed all the ink
    cartridges, cleaned the rollers and reset the printer. The printer is
    just over two years old and the only thing left is to buy a new printer
    as I must print urgently. Is it wise to buy another Canon?
Problem is when the printer does a head clean dumps large amount of black ink on to rollers. Replacement head is almost £100 and not certain to fix fault
Posted on May 30, 2008
Bizhub C652 has horizontal lines.
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
Fuzzy horizontal lines printing every 1 1/8"
Sounds like you've already diagnosed the problem.
Oct 11, 2012 | Tektronix PHASER 6180 All-In-One Laser...
How to configure printhead alignment
Hi there, Aligning the Print Head
If ruled lines are misaligned or a printout is unsatisfactory,Print Head Alignment is required.
Steps for Aligning the Print Head.
1) Press [Menu] repeatedly until [Maintenance] appears.
2) Press [Maintenance] repeatedly until <P> appears.
3) Press [Black] or [Color].
The machine print the head alignment sheet.
4) Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
5) Load the checked sheet on the Platen Glass.
When loading the checked sheet, place the front side down, and align the upper left corner of the sheet with the alignment mark on the lower right corner of the Platen Glass.
6) Press [Maintenance] repeatedly until <U> appears,
7) Press [Black] or [Color].
The machine scans the pattern and aligns the Print Head automatically.
Note : If you select <L>in step 2, the machine prints the current Print Head Alignment setting.
Hope this help.
Have a good day.
Dec 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
1/2 inch wide black line appears on the copies
Please use the link provided below to download the user guide. The user guide and the troubleshooting guide will have detailed steps to solve this issue.
http://safemanuals.com/user-guide-instructions-owner-manual/HP/PSC%201510-_E
May 20, 2009 | HP PSC 1510 All-In-One InkJet Printer
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Black line on right side of prints
the drum life is over, change PC drum, also you may clean laser glass whats under the pc drum
Jun 06, 2008 | Konica Minolta magicolor 2400 Laser...
I have exactly the same problem with a Canon Pixma MP800, I have cleaned the rollers, changed the ink cartridges and reset the printer. It will print a few pages cleanly then dump black ink on the roller which leaves a heavy black line on the back of the page. It fades away after printing about 10 pages and then a few pages later appears again. The printer is two years old and it looks as if I must buy another. Should I buy another Canon?
Apr 03, 2008 | Office Equipment & Supplies
Red line on last quarter of photos
I assume that the red line is not on the photos themselves (make sure this is the case - if they're scanned photos, it might be a scanner problem). If this is a 4" by 6" paper, set it in the printer after bending it in the opposite direction. 1) Set a sheet of paper on the printing side of the paper to be printed on. (If the print surface is touched by hand, the print surface may be soiled by skin oils, and the print quality may deteriorate.) 2) To bend the paper, hold the paper in a rounded shape for about 10 seconds. 3) Remove the paper not to be used in printing, and confirm that, when laid flat with the print side up, the center of the paper to be printed on is raised between 2 to 5 mm (0.2 in.) . 4) The curled paper to be printed on should be set in the printer, and printed, sheet by sheet. Canon recommends using Photo Paper Pro PC-101S 4" x 6" sized paper. When using PC-101S, printing is performed at the center of paper and streaks or uneven printing is avoided. If this is an A4 sized paper, try using Photo Paper Pro PR-101 paper, and make sure that the printing quality is set to "high" or "fine". If nothing helps, I would suggest trying a new ink cartridge. If you still have this problem and nothing solves it, call a repairman.
Apr 09, 2006 | Canon BubbleJet i560 InkJet Printer
Canon Pixma MP800 All-In-One InkJet Printer Logo
301 people viewed this question
old marine
old marine
