Got six wires co ming out of amp two for rear speakers two for front two for center and only two on my telly and also my dvd player
I'm assuming the "six wires" you're asking about are outputs that should go to your speakers.
I'm also assuming the the "two on your telly" are audio inputs for your telly's two speakers. You could wire these up as your two front speakers if you would like, but you're really better off getting real speakers for front and not using the TV speakers at all.
Your DVD player should have no audio inputs at all, so you should not wire any of your receiver's outputs to it. end of story.
Your receiver should have audio (and perhaps video) INPUTS for your DVD player, in which case there should only be two (Left and right) this is fine. Your receiver should split the DVD signal into 5.6/6.1 whatever.
hope it helps.
Posted on Apr 12, 2008
Tip
How to set up a seven-speaker home theater system
Set up a home theater
How to connect your speakers
In order to deliver surround sound, home theater systems require 5, 6, or even 7 speakers--and that's not even counting the subwoofer. Connecting all those speakers together can be quite a challenge, so here's a quick overview of the basics.
If you don't have an all-in-one, home-theater-in-a-box system, you'll probably need to supply your own speaker cables. There are several different types available--they vary in terms of wire size (or gauges) and termination types. Make sure you pick cable that's a good match for your speakers and receiver. And make sure they're long enough; the rear-channel cables in particular will be stretching all the way around the room.
Once you've selected your system and have all your speakers ready to set up, begin by placing each speaker at or near its intended location. Then, attach the cables to them one by one. After securely fastening one end of the cable to the speaker, connect the other end to the appropriate speaker output on the back of the A/V receiver. Be sure to connect the cable to the correctly labeled output.
For instance, the front-right speaker wire needs to go to the terminal labeled front-right. Also, make sure that each speaker connection is in phase, meaning negative to negative and positive to positive. Otherwise, your system's sound will sound out of whack. Repeat the process for every speaker in your system. Note that the subwoofer uses a coaxial-style RCA cable instead of standard speaker wire.
Once all the wires are connected, you should test the system with several DVDs and CDs, to ensure that everything is in working order.
For our first example, we used an elaborate 7.1-channel system, so it may have 1, 2, or several more speakers than your system. Some systems even employ wireless rear speakers, or virtual surround-surround modes that simulate multichannel experience from 3, 2, or even 1 speaker. And some listeners still prefer good old stereo sound from 2 speakers. No matter what type of speaker setup you prefer, however, the wiring basics remain the same.
How to position surround-sound speakers and a subwoofer
To get the best performance from a surround-sound speaker system, you must install each speaker in the correct location. There are three basic types of surround-sound speaker systems.
  • The 5.1-channel system has five satellite speakers and a subwoofer.
  • 6.1-channel systems have six satellites and a subwoofer.
  • And 7.1-channel systems have seven satellites and a subwoofer.
Start by placing the center speaker either directly above or directly below your TV. The center speaker can be perched atop a direct-view TV or mounted on the wall. Aim the center speaker at ear level.
In most cases, the front-left and front-right speakers can be wall mounted or placed on stands. However, if your speakers have rear-panel bass ports, they should not be wall mounted. Space your front-left and front-right speakers the same distance apart as the distance between your center speaker and your listening position. Position the front-left and front-right speakers no more than two feet above or below the front-center speaker. The tweeters in the front-left and front-right speakers should be roughly at ear level relative to your seating position.
Ideally, the surround-left and surround-right speakers should be mounted on the side walls of your room, slightly behind or parallel to your listening position. If your speakers have rear-panel bass ports, place them on stands instead. If installing the speakers on the side walls isn't practical, you can mount them on the room's rear wall or place them on stands behind your listening position. The surround speakers can be installed up to two feet above the front speakers.
Also, 6.1 surround systems have a back-center speaker. You'll typically mount this on the rear wall of your room, centered behind your seating position. Position the back-center speaker no more than six feet behind the surround-left and surround-right speakers. If your speaker has a rear-panel bass port or if the rear wall is too far behind your seating position, place the back center speaker on a stand instead. The back-center speaker should be installed at the same height as the surround-left and surround-right speakers.
Instead of a single back speaker, 7.1 surround systems use a back-left and a back-right speaker. These, too, are typically mounted on the rear wall of your room. Position the back-left and back-right speakers so that each is approximately aligned with the left and right edges of your listening position. Place the back-left and back-right speakers no more than six feet behind the surround-left and surround-right speakers. If your speakers have rear-panel bass ports,or if the rear wall is too far behind your seating position, place the speakers on stands instead. Install the back-left and back-right speakers at the same height as the surround-left and surround-right speakers.
A subwoofer is the last component of a 5, 6, or 7.1 system. Because bass frequencies are nondirectional, you can place the subwoofer in various locations. You may get the best performance by installing the subwoofer in the front of the room, approximately six inches from the wall. If you want more bass, try placing the sub near a corner in the front of the room.
Connect your DVD player to your A/V receiver--digitally
To hear a movie's soundtrack in surround sound, you must first connect your DVD player to an A/V surround-sound receiver. You'll need to make what is called a multi-channel-compatible connection.
The easiest way to do this is to use a cable that carries a digital signal. There are two digital options: optical and coaxial.
An optical digital connection, also called TosLink, uses pulses of light to deliver a digital signal. According to some experts, one advantage of optical digital connections is that optical cables don't pick up noise, while lower-quality coaxial cables can. Many, but not all, DVD players have an optical output. Most A/V receivers have at least one and usually multiple optical inputs. Plug one end of the optical cable into the DVDs player's optical-out jack. Plug the other end into the receiver's optical input.
Finally, you need to tell your receiver to use the optical connection whenever you switch to the DVD input. This is called assigning the input. Information about this simple process can be found in your A/V receiver's manual.
A second option is a coaxial digital connection. This type of connection is also used for cable TV, but the connectors are different. This type of coaxial cable has an RCA connector. Coaxial cables are less expensive than optical ones. In fact, you can use any old RCA cable to make a coaxial digital connection, and you won't lose any audio quality.
Most, but not all, DVD players, have a coaxial output. Some have coaxial and optical outputs, so you get a choice. Audiophiles argue over which connection is better, but it's very hard to hear the difference. Most A/V receivers have at least one and usually multiple coaxial inputs. Plug one end of the coaxial cable into the DVD player's coaxial-out jack. Plug the other end into the receiver's coaxial input.
Finally, tell your receiver to use the coaxial connection whenever you switch to the DVD input. Again, your A/V receiver's manual will have instructions for assigning an input.
on Aug 13, 2010 | Audio Players & Recorders
Tip
How to set up a six speaker home theater surround sound system
This walk through is for a six speaker setup but can be used for any type. First you will have a sub., a center speaker, a surround L and R, and a front L and R. Most likely your speaker wire (silvery wire) will have a colored tip at end. This tip will show where the wire fits into the bluray or DVD player and what speaker it goes to. I am going to use the Surround Right or S.R. as an example because most the speakers are very similar to set up. The S.R. is (at least for me) a smaller black speaker with a gray sticker on the back indicating what wire should be use for it. The S.R. should be hung behind the main seat (Sofa, Chair, Etc.) and to your right side. and the wire should be ran around the ceiling to the DVD or Bluray player (its good to hide it behind wall edging or pictures) and then fit the colored piece at the end of the cord into the correct colored slot at the back of the player. If necessary use a staple gun to attach the wire to the the back of the wall edging (make sure the staples are not visible because I guarantee you won't want it there forever. Also, make sure to not tear or puncture the wire with the staple. Repeat this step for all the other speakers. Your setup should look some thing like this
Left Front Sp.////////// Center Sp. /////////// Right Front Sp.
//////////////////////sub. (directly below)////////////////
...................................Sofa.........................................
Left Surround ////////////////////////////////////// Right Surround
on Dec 04, 2009 | Audio Players & Recorders
HOW DO THE WIRE GO ON A2003 SIVERADO
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Red
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Red/Black
Car Stereo Amp Trigger Wire: Pink (also known as the remote wire)
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Here is the installation manual for your particular deck. Click Here. The first thing you should focus is getting the unit to power on. Follow the diagrams and you should be fine. Once you get your deck to power on then you can move on to the speakers. I tried to provide as much info as I can. Let me know if you need anymore help
Jan 28, 2012 | Eclipse AVN5435 Car DVD Player
My wiring plug to the back of the radio was cut on my 1990 4runne
fun fun fun.
1990 Toyota 4Runner Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Blue/Yellow or Blue/Black
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jul 31, 2010 | 1990 Toyota 4Runner
Rear speakers not working
Your FM tuner will only generate sound from the front sepakers. CD's, Tape, and I guess mp3 player, as well, will only play through the front speakers.
I've included a link for the manual. The audio on this rig is pretty complex. read through the info, especially pages 11,12,13, and play with the audio controls.
http://support.radioshack.com/support_audio/doc61/61792.pdf
Aug 16, 2009 | RCA RT2500 System
Lost the owners man, and need to hook up my Clarion VRX 485 VD
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
thats the radio here's the diagram for your car
1995 Honda Civic Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
pls rate people arnt rating hope this helps
Mar 18, 2009 | Clarion VRX485VD Car DVD Player
No remote from Cd player. What to do?
thats a car dvd player right what u would do is to take the back of the unit and look for the female ends of rca's on the unit that they will say rear out put hook them up and run them to the amp and i dont get what u mean about the remote wire but let me no if that helps
Apr 04, 2008 | Jensen A600HLX Car Audio Amplifier
NO Sound Except Subwoofer on Disk Playback
guys wrong iso adapter.go to propper audio shop
Oct 11, 2006 | JVC KD-AVX2 Car DVD Player
 Grubhead
Grubhead
