5 days agao, it is OK,we didn't use it,
but today, I found that the image from the camera shows pink, but the taken image shows green or yellow, in on word, completely distortion.
Hi, It is known problem of ccd imager chip failure in DSC-T1 camera and ccd imager chip will be replaced to fix the issue. Local camera repair shop will help you to replace ccd imager chip. It is not user level repair and camera will take apart to replace defective part. Thanks.
Hi there: Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter. In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it. Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Hi, It is ccd imager chip failure problem in DMC-TZ3 and ccd imager chip will be replaced to solve this issue. CCD Imager chip part number is VEK0L04 and available in PartStore.com for $141 Local camera repair shop will replace it because camera will take apart and expert tech is required to do so. Thanks.
Hi, It is known problem of ccd imager chip failure in Canon A60 camera and ccd imager chip will be replaced to fix this issue. Canon offers ccd imager chip replacement free of cost, click Canon CCD Imager Advisory for details. Thanks.
This is simple, you just need to have the camera serviced for this distorted image problem. That's usually the ccd sensor that just needs to be replaced when that happens. If you go to: www.camerasandparts.com they specialize in Service for the Canon Powershots and they are amazing if you need service for one of these. They actually have this exact distorted image problem on their site for your model so you can get it taken care of for very little and have the camera serviced up completely. Try that site, that's where a lot of people go for help with the Powershots, good luck
Camera symptoms shows bad CCD Imager in camera and this part needs to be replaced.
Sony has announced free of cost repair scheme for such problem in DSC-T1 models. Please click Sony Support for details.
Thank you.
If it's pink/purple and "streaky", you have a bad CCD sensor. The only fix is replacement of the sensor. This is the main image capturing sensor in the camera. The situation is well documented on the web. It's usually the end of the camera, unless it's under warranty (or just a little past). Approaching Fuji's repair department can sometimes yield a sympathetic rep who'll have it fixed at no charge to you. If you are on the hook for the repair, expect to drop about $100 US.
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager( they are still doing it). check it out.
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says.
"You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
This is a defective CCD. Canon is replacing them free of charge. Go here for details: http://www.usa.canon.com:80/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8044&keycode=2112&id=29819
