Question about Creative Labs ZEN SLEEK MP3 Player
Is it possible to fix the headphone jack
I kept having to change headphones because they wouldn't work and i figured out that the prong things kept widening up and then I tried tightening them, and it worked for a while, but then it broke off and the sound hasn't been the same.
  • 8,596 Answers
There is no repair svc for such a thing
Posted on Jul 06, 2008
Speakers do not work. Headphones do. Tried adjusting volume but nothing changes
Possible causes are:
faulty conections on speaker cables, check all conections.
cable damaged, replace cable
speakers faulty, replace speakers
Feb 03, 2016 | Dragon Touch Touch7 Blue Dual Core Y88...
Can i hook up my PC to my sterio system through the headphone jack on the stereo to the PC HEadphone jack? been trying to get it to work on Auxilary but no sound :( please help
If you are still working on the question you asked about. This is what I would do. One of two things:
First: purchase an adapter that goes from your laptop 3.5 mm headphone jack to the microphone input if there is one.
Second: Would be to purchase what is called a "Cassette Tape Adapter". This will take your 3.5 mm headphone jack and play it through your cassette tape area of your stereo.
I hope one of these is a solution that will help you. -- wicc --
Aug 16, 2012 | Computers & Internet
Headphone jack requires bending the headphone jack to a side to get stereo. this is the coby mp725 16 gig love the unit. got it as a gift. had to send my first unit in due to headphone jack not working....
This problem is common with a lot of MP3 players. It is caused by excessive movement of the headphone jack and causes the headphone jack has worked loose from the circuit board.
To fix this problem the MP3 player needs dismantling and the headphone jack needs resoldering onto the circuit board to get the headphone working properly.
Jun 30, 2011 | Coby MP725Digital Media Player
Head phone socket intermitent and now failed. Any idea what to solder where?
the headphone jack would either be a 3 prong or a 4 prong. meaning it was either had 2 contacts on the headphone barrel or 3 contacts and the last prong being for ground. If you desolder the headphone jack you can easily determine this. Then you can goto a radio shack and pick one up for under 5 dollars. Problems that may come into play are is if they used a low profile jack over a standardized. But even if its 3.5mm or 2.5mm radio shack generally always sells them. You could also purchase them online. Most likely the cause is the contacts inside the headphone jack are no longer making contact with the barrel of the headphone plug. But if its not the headphone jack then it is possible the amp inside the unit has broken. also if you open the unit up determine if the solder on the headphone jack that makes the contact may have become cracked. If that is the case just heat up a soldering iron and make circles around the solder, but be careful not to spread the solder and cross connections.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Aug 20, 2010 | Samsung YP-K3 MP3 Player
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
No sound in right earbud?
sounds like your 3.5mm jack (headphone jack) s broken. try getting a new one on ebay. if you are not confident opening your ipod, find a handy friend to do it for you
Aug 17, 2009 | Apple iPod MA446LL/A MP3 Player
I lost the sound on the right ear of my bose around-ear head phones and I checked the lines and nothing is cut, the left ear is working perfectly. Please help!
This may be your headphone jack (what you use to connect it to your ipod or speakers ect.). check the connection there, and if you see the wire became loose near it, that is most likely the problem. You can fix it! With a new headphone jack (available at the Source or Radioshack or other stores like that), and with some manual soldering (it's not too hard, I fixed my myself and I havn't soldered before.) you'll get those headphone to be as good as new. here are the steps to fix this problem.
1. cut your old headphone ******** and strip the wires. you should see two wires; one copper wire and one coloured wire (green or Red) on each cord. there is a total of 4 wires, two per cord.
2. Tin coat the wires. this means to burn the wires a bit (with the soldering iron) and put solder over them. this gets rid of the coating that is on the wires to stop them from shorting out in the cord and helps conductivity when soldering them onto your headphone jack.
3. there should be three holes on your new headphone jack. there should be two prongs left and right of the part you plug into the machine, and there should be one connected to the part that holds the wires once done.
4. connect the coloured wires (red and green) to the left and right prongs of the new jack and secure with solder. These are called the live (or hot) wires because they are the ones that send the signal that makes the sound.
5. connect both of the copper wires to the other hole and secure with solder. these wire are both ground wires, which are very important.
6. by the end, you should have connected four wires. two to the seperate prongs, and two to the third ground hole.
7. test your connection by trying to use your headphones. if it does not work (which may happen, don't get discouraged!) check your soldering. if it is touching any metal it shouldn't be, that means you have created a short circuit. simply burn off the solder (with the soldering iron) and try again.
8. keep trying until you get sound. good luck!
9. Once you get sound, you may want to secure the soldering job. you can either use two part epoxy and put this over your work, or you can tie a knot before you put the cover on you headphone jack. either will work just fine. Also, there sometimes are two metal protrusions that you can bend with plyers to help hold your chord in place.
10. enjoy your fixed, good as new headphones! Enoy hope this helped.
Bee's
Jun 20, 2009 | Bose Around-Ear Headphones - Silver
Sound only in right ear
Its either the jack or the connector in the device is the problem. You can try connecting other headphone, if this works, then the problem lies on the jack of the old headphone.
May 03, 2009 | SanDisk Sansa e200 MP3 Player
Sound only comes from left earphone (taking the cover off the headphone jack)
Hello. The problem could be the jack itself, more exactly it has a bad contact with the main board. If you have a soldering equipment you should try to resolder the jack to the main board. Or you may try to go at a service center, to have the jack replaced just to be shure. It isn't an expensive repair and can be done in half hour at max. I don't recomand you to try to dissasemble the jack because it may get damaged even further. check the connections with the main board, it may even be a broken pin. Good luck, feel free to ask further questions and don't forget to rate any answer received from this site :)
Mar 03, 2007 | Sony Walkman D-FJ61 Personal CD Player
Creative Labs ZEN SLEEK MP3 Player Logo
56 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
