Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Access Internet using wireless USB adapter
Dear Sir, I have a wireless router connect to a PC and am able to browse the Internet for quite sometime now. I recently have installed another PC in a different room and have attached and installed a wireless LAN mini USB adapter (IEEE 802.11b compatible, portable) to it, but am unable to browse the Internet. While trying to connect to the LAN it is asking for WEP identification. How do I get this "WEP". Am I missing something? I basically need some hep in setting up an internet connect to this new PC. Many Thanks
How do I add a computer that isn't able to get wifi straight out of the box to this network? Do I need an adapter or something?
  • 550 Answers
From the pc that can access the internet
type this address in your browser
http:\\192.168.0.1
which should start the routers webinterface you can navigate thru the Wireless settings and copy them to the pc that you are trying to connect,
WEP - wireless encryption protocol - a method of scrambling transmitted data for security - both ends of the link have to have the same code key or they wont talk to each other
Posted on Apr 30, 2008
Can i use connect dongle as wireless adapter
Yes definitely ,I think i need lots more information about router version, IEEE standard.
basically adapter that uses mobile phone networks to provide broadband as a WiFi Dongle while USB WiFi adapter can be used to connect your PC to and existing wirless network provided by a wireless router.
but first you should find out what kind of Internet router you are using and always purchase a Wi-Fi adapter that is compatible with the Wi-Fi standard of your wireless router.
read more information
for more http://www.ebay.co.uk/gds/Buying-a-USB-Wi-Fi-Adapter-Dongle-Can-Make-You-More-Mobile-/10000000177329841/g.html
If you still not able to solve follow us Linksys Router Support .
Apr 17, 2014 | Computers & Internet
Airlink adapter and att router access problems
Make sure you have the most up to date drivers for both your mini usb adapter and your router.
The 64 bit version of windows 7 may not have the right driver for your equipment.
Will get better with time.
Good luck.
Jul 04, 2010 | Airlink (AWLC3025) Wireless Adapter
Cant connect wii to internet
The unit can connect to the Internet by utilizing its 802.11b/g Wi-Fi, which is built in, for wireless connections or via a USB-to-Ethernet adaptor for DSL connections.
For your wireless connection or Wi-Fi, the 802.11b Wi-Fi has a data rate of 11 Mbits per second and has an indoor range of 30m or approximately 98 ft. The 802.11g has the same indoor range, however the data rate is at 54 Mbits per second. If you have an existing wireless connection or are in a Wi-Fi hotspot, the unit will connect to your wireless connection automatically out of the box. If you do not have a wireless network, however, you will need to have your wireless network subscription done or set-up first. Once you have wireless Internet access, you then search for your access point, put in your security settings and you’re good to go. It would also be advisable to have a wireless router for this so that you won’t have to shuttle the connection between your PC and your Wii. wi-fi-usb-connector.thumbnail.jpgAnother option would be to connect your Wii via the Nintendo Wi-Fi USB Connector. This accessory allows Nintendo Wii users who do not have an existing Wi-Fi connection or a compatible Wi-Fi network to create one through their broadband or DSL connected computer. This is inserted into your existing computer’s USB port and the Wi-Fi USB Connector acts as a wireless access point for the Wii. This allows the user access to the internet and to play Wi-Fi Connection games from Nintendo Online.
nintendo-wii-lan-adapter.thumbnail.jpgFor your DSL connection, however, you will need to have quite a few things. You can use a WII LAN adapter to connect your Wii to your DSL modem. You can also use a router so that you can use your PC and your Wii at the same time. With the LAN Adapter though, to use or plug in the Wii, you must disconnect your PC. This can be quite tedious since you will have to plug in and out your PC and your Wii every time you need to use one or the other. A LAN Adapter is fairly cheap, but if you get a router, your PC and your Wii can go online at the same time, saving you the hassle of connecting one or the other when you need them. You can then hook up the existing ethernet cords to the back of the router and connect it to the Wii via a USB 2.0 cord.
i hope this helps
Nov 05, 2009 | Nintendo Wii Console
Lenovo 3000 H Series local area network access ONLY
I would suggest backing up all you sensitive data and doing a complete factory restore withe the Lenevo disks that came with your laptop. Some of them are stored on the hard drive and you just have to press a button. It should say at start up which it is.
Aug 17, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Can i use Bluetooth USB Adapter to connect PC to wireless router?I purchased a new PC that's connected to a wireless router for internet. I want to connect my old PC to the same wireless router. I don't...
Hi, to connect your computer to the wireless network of the router you need to have a wireless adapter. The bluetooth adapter will not work in this case as the router does not communicate with the bluetooth signals.
Purchase a wireless adapter like NETGEAR WG111
Rate it, if it helps.
Regards
Anand
Aug 03, 2009 | Computers & Internet
No, I am afraid not. the bluetooth adapter will not connect to your wireless router because as of now there is no router that support that function.
you can buy a USB wireless adapter instead.
thank you for using Fixya
Aug 03, 2009 | Linksys (USBBT100-CA) Bluetooth Wireless...
I have an older HP laptop with no wireless capability. We have DSL with the wireless router connected to our desktop. The only way I can access the internet is by putting in the AT&T air card. I don't want...
You can connect to the Internet using your DSL wireless router by several methods.
1. If your HP has a LAN port the you can connect to your wireless router with a LAN cable (provided you have a spare LAN port on the router.
2. You can use a USB wireless adapter to connect to the wireless router.
3. You can use a PCMCIA wireless card to connect to the wireless router.
Both the wireless USB and PCMCIA wireless adapter are approx. $50, my preference is to use a PCMCIA adapter, it leaves the USB port free for other devices,such as USB memory sticks, especially if the laptop has only one USB port.
Jan 17, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Linksys Wireless-G problem with Internet connection
Have you tryed unpluging both routers then pluging them back in?
This will refresh your Ip's
Dec 11, 2008 | Linksys Wireless-G WRT54G Router
I am unable to get wireless internet connected i have called escapenet and i have called my speechtouch and they said its my computers problem but previous to my son buying computer wireless internet...
To my knowledge of understanding is as if the WIFI is weak and cannot get connected to any network around anymore so if you wish to have a wirelless connection you can still make use of a USB doggle and the network operator or manufacturer will give you the access and you browse anywhere you go with your system and the USB will be connected to your system ok
Rate this Solution.
Oct 23, 2008 | Computers & Internet
You can find the WEP code in your setting on your router. Just get into your bios on your router and find the wireless WEP code you will see it is a 26 digit code just type that into any other computer on that router and make sure workgroup is the same too. Once you put the 26 digit code in you should be online now, Hope that helps Let Me Know Thanks Bear001 If you need more help write back here.
Dec 24, 2007 | GigaFast Ethernet WF748-UI (WF748UI)...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
165 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
