Infinity BassLink II Car Subwoofer
Problem for Infinity BassLink II Car Subwoofer
TURN OFF NOISE
By lemartinez on Apr 14, 2008
It works for few month with no problem. Now each time I turn off the radio or the car a big boom noise comes out the subwoofer. The subwoofer sound is OK.
Comments:
Apr 15, 2008
- I double check the positive cable that runs from the battery to the subwoofer and the ground cable. Install a new battery and teminals too, just in case.
Apr 15, 2008
- Made a mistake. Still got the problem and press the wrong buttom. Need a solution.
Solution #1
posted on Apr 14, 2008
Somewhat Helpful)
proton77
Rank: Wiz
Rating: 84%, 404 votes
There is a static that builds on the woofer , check the wiring and check grounding of the woofer once again
Rating Locked! (?) lemartinez has rated this solution as Somewhat Helpful
Solution #2
posted on Apr 27, 2008
Not Rated)
Benimur
Rank: Guru
Rating: 88%, 3790 votes
This sounds like a small line capacitor discharging and amplified by the power amp. Unfortunately, this small capacitor can be anywhere from the head unit, equalizer or electronic crossovers (if any), regular amp (if separate from the subamp) and where the RCA terminated cables from the HU initially goes to and finally the sub amp itself. These could be a 1~2.2uF (or thereabouts) line/series capacitor. Its purpose is to provide a pathway for the audio but block an DC signals. What you are hearing (I suspect) as boom are these capacitors discharging along the audio line.
Corrective measure would be open the units up, performing diagnostic and capacitor test (specifically those that are used as inputs). The best would be with the use of a capacitance meter but an ordinary analog VOM/Continuity tester would also do the job. These capacitors are normally located pretty near the RCA input or output jacks. It is not uncommon also for capacitors in the amplifier to cause similar concerns.
Alternately, a quick and dirty trick to reduce if not eliminate the sound is to install another set of capacitors along the audio line. This could be done at the HU's RCA output or the amp's RCA input. Of course this did not correct the defective capacitors (if any) but merely a workaround.
Another possibility that can not be discounted is that the internal DC to DC power supply of the sub amp is acting. Again main possible culprit could be the big capacitors. Additionally, it could be simply the speaker relays (if present) failing to switch off during power down.
All of the above of course would require that you be familiar with electronic circuitry and components, the use of a DVM and possibly a soldering iron. Should you be uncomfortable with a DIY, perhaps your best bet would be to seek the services of a qualified audio professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Solution #3
Not Rated)
s4u311
Rank: Wiz
Rating: 83%, 453 votes
chek your wofer cable is is bed
Comments:
Apr 27, 2008
- or chak the wireing of your woofer
Popular Solutions for Infinity BassLink II Car
Questions and Unsolved Problems for Infinity BassLink II Car
Do you recommend Infinity BassLink II Car Subwoofer?
Answer
Answer
i have a 1996 chevrolet impala. where can i install the kfc-t207?
Answer
radio in my peugeot 106 is asking for the code which i dont have the serial number is... (More)
Answer
Test drove truk yesterday and stereo worked fine. Bought truck and drove it off the lot and when I... (More)
Answer
Okay, I have an Infinity Basslink II installed in an 04 Acura TSX. I have left the unit hooked up to... (More)
Answer
I've just had this thing pro installed and havw an appointment to see them again on Wed to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Car Speakers and Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
