Question about Cameras
My dxg-328 has red key lock on and i cannot get it of. until then i cannot use my camera
Your memory card is locked. take the memory card out, and there will be a small white slider on the side of the memory card. Just slide it up and your camera will be unlocked.
Posted on Jun 22, 2008
How do I unlock my camera and camcorder?
hi,
i think it is because of your SD card that is on "record protected" position...
just change it to non protected by moving the tiny lock on the left side it must be up, not down (that arrives sometime when inserting the SD card in the cam, if not really straight !
cheers
mich
Nov 02, 2014 | DXG Technology Dxg 565v 5.1 Mp Digital...
DXG-301V CAMERA
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 19, 2014 | DXG Technology DXG DXG-301V Digital...
I do not have the installer cd for the dxg 328 and can not install the driver or anything so am unable to import my pics.
Hi ,
don,t worry,
it is not so important . and very easy you can transfer your picture from camera to computer.
you need only a ram reader .
you can insert the camera ram in to the ram reader and transfer all of your pictures from
ram to your computer.
don,t worry
good luck
gorbesia
Jun 14, 2011 | DXG Technology DXG-328 Digital Camera
If my dxg 538 slim camera gets locked? how do i unlock it if i cant even take a picture. it locked everything but i can see pictures i already took but i cant take one.
I'm not familiar with this camera but does it use a card with a slide switch on the side? If so, it may be in the locked position.
Mar 29, 2010 | DXG Technology DXG-538 Digital Camera
Manual or user guide
After meticulously looking at the manufacturer's site (it dramatically changed since 2006), there doesn't seem to be a link for it anymore. However, it has resurfaced through this link:
http://camera.manualsonline.com/manuals/mfg/dxg_technology/dxg328_1.html
Nov 30, 2008 | DXG Technology DXG-328 Digital Camera
518 camera DXG
with how you described the issue, there is a possibility that the lens assembly something blocking its operation, you can either shake the camera to check if there are loose parts inside, or carefully open it and check if you have a loose part in the camera.
usually this is caused by the focus or zoom mechanism being derailed. and having it replaired can be the key. but if you have the service manual for the unit that will allow you to open the camera up just by following the lens maintenance section
if you have other questions regarding this or other matter just lemme know.
Nov 04, 2008 | DXG Technology DXG-503 Digital Camera
My DXG model 552 is locked?
Try pulling the memory card out of camera too see if you can take a picture with out the memory card in place.
If you can do this the memory card is locked. Look at the memory card and find small swith on the side. Look for the lock symbol and be sure the switch is not in the locked position. Move the switch as needed.
Put the card back in and try it. This should solve your problem
Aug 14, 2008 | DXG Technology DXG-552 Digital Camera
Battery cover broken
A repair is unlikely without parts, It also depends weather its the part that is actually broken is on the battery cover or the camera itself.
If the camera itself a new case for the camera will be required if the battery cover then a new cover will be needed.
to obtain the spares you have two routes,
a) contact the manufacturer (contact details should be in the manual or on the gtee card)
b) buy a faulty camera from somewhere like ebay and use it for parts
May 25, 2008 | DXG Technology DXG-328 Digital Camera
Cameras Logo
16 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
