Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
The rubber seal kenmore 3.8 cu ft he3t king size capacity
THE RUBBER SEAL HAS COME OFF FROM THE BASKET IT LOOKS LIKE THE METAL BAND HAS LOOSENED I CAN'T FIND ANY IINSTRUCTIONS ON HOW TO GET IT BACK ON. I HAVE TH EMACHINE TAKEN PARTIALLY APART I CAN'T GET THE CONTROL PANEL OFF TO GET WHERE I CAN GET THE RUBBER SEAL AND BAND BACK O ON
  • Anonymous Apr 19, 2009
    jsrock516 Thanks so much for posting your steps. I got the whirlpool repair manual and your directions were much more specific and succinct and helped me complet the replacement of my door boot/bellow.
  • 5,911 Answers
Here ya go. These are the complete steps involved i how to replace the door bellow. Just follow these instructions:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the screw(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you and let me know if you need further assistance.
Posted on Apr 12, 2008
Why won't the lock disengage?
Most likely, the electric lock mechanism is jammed and/or shorted out and it must be replaced.
Jul 30, 2015 | Kenmore HE3t 4.0 cu. ft. Front-Load King...
Getting an H R error
http://c.shld.net/assets/own/HE3t_W_e.pdf
unless it is a problem or stops washer from working,deal with it or buy a new,Preferably not a kenmore or sears,sears is going under,here is the manual that says nothing about hr error,it will cost 1000's to repair,{it is old}
Mar 14, 2015 | Kenmore HE3t 4.0 cu. ft. Front-Load King...
Door wont lock, cycle doesn't start
interlock could be knackerd...................cheers
Jan 22, 2014 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
Door wont lock cycle wont start
Try unplugging the machine for 5 minutes then plug it back in to reboot it.
Jan 22, 2014 | Kenmore HE3t 4.0 cu. ft. Front-Load King...
How do you reset the computer on kenmore elite he3t steamer
UNPLUG FROM WALL SOCKET FOR 5 MINUETS PLUG BACK IN TRY AGAIN IF YOUR DRYER IS HARD WIRED DO THE SAME AT THE FUSE OR BREAKER
Oct 30, 2013 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
Our rubber seal was torn and we had a Sears repairman replace it - he said it required a special tool to install it (which he didn't have) but through some long and physical process, he was finally able to get it on.
Jan 26, 2009 | Kenmore Elite 45986 Front Load Washer
KENMORE HE3T BASKET RUBBING ON THE PLASTIC FRONT TUB
if ripped obvioussly youl need to replace the front rubber bellow, i would remove the bottom panel and have a look inside sounds like you have a broken shock aborber or 2 not properly supporting tub assy
Feb 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
513 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
