Question about Olympus FE-230 Digital Camera
Len will not retract
Lens wil not retract
  • Anonymous Mar 10, 2009
    lens not able to capture object
    Scholar:
  • 71 Answers
Bad Lens assembly, cost more to fix than replace.
Check the Olympus store for clearance items,
Pricewatch is a good one also.
Never buy a used one online, new is ok, because dropping them is the #1 reason for the lens assembly failure.
I'm sorry I couldn't be more helpfull.
Best regards, Paul
Posted on Jun 11, 2008
  • Paul Hering
    Paul Hering Jun 12, 2008
    Hi again mharper,
    Here's your link... Olympusamerica.com
    Consumer Division Tech Dept. 800-622-6372 8 AM to 7 PM EST
    Mon to Fri
    They do have a trade in program even for broken cameras.
    A FE-230 Will Cost $139.00 + tax Free shipping and they throw in a free 3 year warranty. That's worth $60.00 alone.
    Regards Paul
SOURCE: lens error 126,1,0,-9
pull on the lens.
Posted on Jul 13, 2008
jackboy
  • 2985 Answers
SOURCE: Zoom lens won't retract
The motor mechanism has failed electrically or through damage- taking a knock. Either way nothing for you to do- unless you are a watch maker or good with fine tools. A repair will cost much as a new camera. Try both -a self repair and a new camera. You may get lucky and have two cameras
Posted on Aug 28, 2007
t00nz
  • 4738 Answers
SOURCE: lens not retracting on kodakc330
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
  • 4 Answers
SOURCE: lens won't retract
Mine has done this twice, both times requiring it to be sent off for repair, both covered under warranty though luckily. Both came back saying they replaced the shutter assembly. Camera is fixing to go back out for a third time (not shutter related). I've lost all confidence in canon with this one.
Posted on Dec 29, 2008
  • 102366 Answers
SOURCE: lens error and will not retract
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
LENS ERROR RESTART CAMERA
The lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Feb 25, 2011 | Canon IXUS80ISS Digital Camera
Zoom error
It sounds as though your lens is sticking while trying to extend. Check the lens to see if it binds. Also look at the retracted lens and see if the center portion is properly centered or is cocked to one side and out of alignment.
Once your camera is working properly, as you say it does at times, hold the camera with the lens pointed downward and run the zoom in and out several times to see if there is dirt caught between the lens cylinders. Sometimes that will work any debris out.
May 20, 2010 | Fuji FinePix S2000hd Digital Camera
Samsun sl201 lens will not extend, then camera shuts down
If the camera's lens will not retract out, then eventually shuts down, here is what you try to do.
Hold the camera from your right hand with the lens facing down. Then tap the base of the camera to your left palm while turning the camara on; do this several times until the camera's lens retracts out.
This problem often occur when the camera was taken outdoor or in the beach. Sand or a tiny granule of dirt might got stuck in the base of the lens.
Sep 25, 2009 | Samsung SL201 Digital Camera
Lens will not retract, camera was not dropped,
Leave the batteries out for a while and then try turning camera on..hopefully its resets the camera and retracts lens.
Jul 07, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Lens wil not retract after battery died
It takes power for the Lens to retract. Recharge or replace batteries to get the lens to retract.
Jun 19, 2009 | Nikon Coolpix 5000 Digital Camera
Lens will not retract. orange and green lights come on, but preview screen remains dark and lens will not retract when I trun it off.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
May 02, 2009 | Cameras
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Lens error of casio EX Z300
Apr 18, 2009 | Casio EXILIM EX-Z300 Digital Camera
C875 lens won't retract
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Nov 14, 2008 | Kodak EasyShare C875 Digital Camera
PowerShot SD600 will not focus
If the camera was open (lens extracted) the camera lens may be damaged. If you can retract it (power off), then maybe it's just dirty. Can you zoom in or out?
Jul 26, 2008 | Canon PowerShot SD600 Digital Camera
Olympus FE-230 Digital Camera Logo
262 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
