Here are all the up to date listed codes for a Sharp TV. Sharp remote codes: 0093 0165 0009 0386 0030 1193 0032 0157 0036 0294 0491 0256 0653 0053 0193 0650 0186 0720 0818 0516 0200 0760 1917
code p 0720 refers to output shaft speed (OSS) sensor---circuit malfunction=== causes ---wiring--OSS sensor ---ECM/ TCM
intermittent problems can be from wiring and connections ( loose corroded, water etc)
as the code suggests it could be from the TCM as well and again check the wires and connections
as the problem is periodic that suggest wires and connections ( excessive resistance or loose pins )
the sensor at fault is the shaft speed sensor and not the vehicle speed sensor (VSS) so make sure you get the correct sensor to fix
This error code is given by the Wii when it cannot connect to the internet, try to test your internet connection. I'm assuming you are connecting through a Wii due to the error code. hope this helps.
P0720 is a code for the output shaft speed sensor on the transmission. If you are handy with a volt/ohm meter you can test the resistance of the sensor unpluged. should be 500-700 ohms. or you can just put a new sensor in, its a comon problem.
