Question about Gateway FPD1810 18.1" LCD Monitor
Gateway 1810 LCD monitor
The display will start jittering or shaking and I discovered that a slight tap on the frame will stop the jittering. It seems to occur more frequently as time goes by, maybe once or twice a night. Any experience with this?
Wally
  • gwj5035 Apr 21, 2008
    I have the same problem. I think I have it narrowed down to the VGA input socket on the monitor. When mine starts to jitter and tear I press on the cable plug at the monitor and keep pressing until the screen goes back to normal. I am waiting for a 26" Double Sight monitor to replace the FPD 1810.
  • Anonymous Dec 12, 2008
    This same problem has happened to me. I am on my 2nd monitor. Both did the same thing. A light tap wound up being a hammer hit! Seriously, a drywall hammer! It's comical, but, after a while the finger tap didn't work. I read somewhere that bad capacitors was the issue. I can say one thing, these monitors could take a drop down the stairs as long as nothing impaled them. I am moving to another monitor now that Gateway has sold their support side of things.
Same problem with the Gateway FPD 1810 monitor here! Same solution after going through the MADNESS of the drivers...a light tap on the very top and centre of it, and the problem went away! When I was a kid, our family television (remember when your home had ONE television?) would do this, and when it did, my dear old Dad would STOMP ON THE FLOOR, and the picture would then suddenly stop flickering! He was a big believer in this! I hope that he is looking down from heaven and getting a laugh from this. He was a Chiropractor, and he referred to this manouvre as treating the TV for a "subluxation", which is what Chiropractors mean whenh they "adjust" your neck! Solution for the 20th century model DuMont Television? Whack it! Solution for the 21st Century LCD Gateway monitor? Whack it! Everything old is new again. Perhaps I should procure a can of TV tuner spray, you never know what is going to break next! Rest in Peace, Dad. Gunsmoke is still on the air HERE, but I'll bet YOU are watching Jackie Gleason up THERE ! ;-)
Posted on Dec 15, 2008
Can you replace power cord?
Sure, purchase one at Amazon.com
http://www.amazon.com/STARTECH-COM-DVIMM6-Digital-Monitor-Replacement/dp/B000067SOL
hope it works.
May 12, 2011 | Gateway FPD 1810 18.1" Flat Panel LCD...
Cornea 1810 monitor power cord
Apparently the monitor's power consumption is near or slightly exceeds the specified value.
My suggestion would be to purchase an adapter with higher rated output current - if for example your original adapter was rated 12V 4.5A, go for a 12V 6A rated adapter. A 30% safety overhead will hopefully contribute to higher reliability.
Nov 18, 2009 | Cornea CT 1810 18.1" Flat Panel LCD...
Our computer monitor is fuzzy, all the text shakes up and down rapidly. What is there to do?
try reinstalling the driver, make sure correct power cord is being used, check power connections on surge protectore or outlet... if all is well and this continues... unfortunately your monitor may have cancer and is on its death bed. u have warranty? return options?
Oct 06, 2009 | Gateway FPD1975W 19" LCD Monitor
Sony hdr-cx7 image jitters when the cam gets hot
one fix is turning off steadyshot then try putting the camcorder upright(the lens pointing up) for few second until you see the video stabilize, then use as normal but the camcorder will jitter again if handle it roughly. This is just a workaround, i still dont know why it happens, need to send it for repair soon.
Jul 22, 2009 | Sony HDR-CX7 Camcorder
Monitor displays image for second and displays black again
Your Monitor has a heat sink issue. A capacitor in the monitor is at fault and when it heats it tells the monitor to turn off the display to save the display from damage....Problem Cost to repair will supercede the cost to replace it...Wal-mart 15" monitor 119bucks --17" monitor 129...same at staples office supply (Poof) problem solved.
Mar 21, 2009 | Gateway FPD 1810 18.1" Flat Panel LCD...
Shaking
On the power supply PCB are two 220uf 25V capacitors that will be leaking. Replace both and the picture will return to normal.
Jan 05, 2009 | Acer AL1717 17" LCD Monitor
Asking support for getting drivers to 610 Gateway desktop computer
If its just the drivers u need, go to www.support.gateway.com and download it from under your model no.
Oct 23, 2008 | Gateway FPD 1810 18.1" Flat Panel LCD...
Can I get this power adapter for my monitor at a store?
I was in radio shack today... they don't sell them.
Jun 25, 2008 | Gateway FPD1810 18.1" LCD Monitor
Monitor picture jitters
I had to say this, but I am on my 3rd LCD monitors,
One shook like what you are saying, the other had colored streaks.
They will take them back, most of the time... sorry
Apr 11, 2008 | X2Gen MG19MY 19" LCD Monitor
Jumpy screen as a monitor
There are a number of things that can cause the problem:
The frame and scan rate from your computer is not matched to the specs of the monitor. The monitor may have a sync lock fault.
LCD monitors must be operated in their native mode for best results. Some models are very critical for the frame and scan rate especialy when using a composite video source.
If you take the monitor to the service rep for it, the should be equiped to diagnose it and tell you the exact answer.
Jerry G.
Apr 07, 2008 | iLO 3200 32 in. LCD Television
Computers & Internet Logo
403 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
