Question about KitchenAid KSRP25FN Side by Side Refrigerator
Puddle We have a KSRS25FTMS side-by-side -- about 9 months old.   We have been very happy until this week.  It has twice dumped a puddle of water on the floor.   It is not continueous, so I do not think it is at the connection. Then water seems to be coming from underneath.  For example, I had a piece of clean newsprint under it to trace where the water might be coming from.  It was fine at 5:00 PM. Then ice maker had filled fine.  We left for about an hour and when we returned the paper was sopping wet.  I suppose we are getting between 1 and two cups of water.  I cleaned it up, and it has not been wet since.   The same thing happened last Monday.  Where is it coming from?  It appears to be underneath.  Is there a defrost drain pan that is overflowing?
  • jpbays Apr 12, 2008
    That I know:-)  However, they would be interested in knowing where the water is coming from.   If they come and the floor is dry, because this is not a continuous problem, what do they do?   Now, there may be a known reason for this issue, and I thought someone here might give me a clue so I would know how to talk to the factory reps.
    Genius:
  • 1,073 Answers
No mater what the issue is the machine is under manufacture warranty for 1 year, call for factory service
Posted on Apr 12, 2008
Have a 10 year old GE profile side by side refrigerator that has a puddle (2-3oz) of water about once or twice per week comming from back bottom. I have checked the drain in the freezer section about 1.5'...
hi that the only drain going to the pan douse it have an ice maker if so check the water line going up the back to ice maker check around water valve may have a small hole or a hole in pan jim
Oct 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leak from under refrigerator
Only two possible sources for a leak one is an ice maker, the other is defrost drain water. Either way it is only 9 months old and still under full warranty!! Call sears and have them come and look at it! I have seen a few of these units with cracked drain pans so be persistent if the tech cannot find a leak, have him pour some water into the pan to see if there is a crack.
good luck and save yourself some stress.. You have a warranty to cover this:)
Jun 11, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
99 Sunfire Coolant keeps dumping
You need to find the source of the leak. it hasn't overheated yet because you keep catching it and re-filling. From your description, it sounds a lot like a bad water pump seal (part of pump) but without physically looking you can't be sure of that. when the pump seal begins to fail, internal pressure while running often will drive the seal tighter against the shaft stopping the leak. as pressure drops as the engine cools, the seal relaxes and permits seepage.
With time, that will change and it will leak all the time.
Oct 06, 2009 | 1999 Pontiac Sunfire
Our side by side is leaking water in a puddle on the left front corner (water dispener side) off and on. 9 year old refrigerator. Refrig/Freezer and ice/water working well.
I'm going to give you a lot of information on one page please choose thye part that most defines your situation and I will be here to assist you, Please rate me, Thanks, Sea Breeze
Click Link Below
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My refridgerator leaks water every two weeks
check to make sure the drain pan is in the right place. If it puddles up inside the bottom of the fridge first, your drain hole is plugged up. for this, you wil have to remove the access panel in the back of the freezer side to get to the drain hole. you may also have a crack in your drain pan.
Aug 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
I have a crosley refridgerator approximatly 8 or 9 yrs. old, and it has started leaking water on the floor. We will find a puddle on the floor about every 2 days. Yesterday, (march 24th), We noticed water...
First make sure than the drain hole in the freezer floor is not clog also check the water plastic lines under the front and back of the refrigerator
Mar 25, 2009 | Refrigerators
Side by side refrigerator has puddle under freezer
Check and clean door seal, chech defrost drain tube ad a cup of water and clorine into tube, Check drin pan and clean under refer.
Sep 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Puddle
all frost free freezers have to defrost the coils. there is a drain pan or cup in the bottom .. if it overflows or it can't drain out you will get puddles check the drain hose and drain cup or pan.. also check to see if you have ice inside the bottom of you freezer that would be a plugged or freezing drain hose..call for services if only 4 months old...
Apr 20, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
KitchenAid KSRP25FN Side by Side Refrigerator Logo
186 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
