Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic hdtv convergence repair
How do i fix the convergence in the panasonic hdtv?
  • ngifsdbagif May 29, 2008
    i have a squiggly line that runs from the bottom of the screen to the middle of the screen purple and blue line and another that comes off the far left of the screen.. Almost looks cracked but its not?? I dont know how to get rid of it?
Panasonic 51'' HDTV Model PT51HX42F - Turns off, light blinks 3 times, pauses, blinks 3 times again, etc.
the 3 blinks is caused by convergence failure indicating the Convergence ICs and resistors need replacement. You can get the convergence repair kit for your model at www.tvrepairworld.com the kit contains the ICs and resistors and also has the CD that shows how to do the repair.
Jul 28, 2012 | Panasonic PT-51HX42 51" Rear Projection...
Convergence problem at top and bottom of screen
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 23, 2011 | Panasonic PT-47WX53 47" Rear Projection...
My Panasonic hdtv PT47WX53G is having convergence issues
The repair kit called PT53WX53 convergence repair kit from www.tvrepairworld.com is the correct kit for your model and symptom. The kit contains the ICs, Resistors and the CD with instructions.
Aug 20, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Panasonic PT-47WX53 47" Rear Projection...
2002 Panasonic PT-47WX52F - Power button now just blinks 3 times
thats the convergence circuits needing repair. You can repair it yourself for around 50.00 with the convergence repair kit for your model from www.tvrepairworld.com the kits contain the parts and the CD with instructions.
Mar 28, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic rear projection-red convergence-moves horizontal only!?
The convergence ICs have failed. You will need to install a convergence repair kit. You can get the convergence repair kit for your model Panasonic from www.tvrepairworld.com which contains both of the Convergence ICs , the associated resistors and the cD with detailed repair instructions.
Dec 26, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Picture is out of focus, fuzzy
Replace the two ICs. You can get the convergence repair kit at this link which contains the parts and step by step instructions with pictures.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Jun 18, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic rear projection tv blinking one time will not turn on . tried to reset it but no luck
The 3 blinks is a error code for the convergence circuit. You can get the convergence repair kit for your model at the following link which contains both Convergence ICs and all six feed resistors and they include step by step instructions with pictures that show how to do the repair yourself. Heres a link to the proper kit for your model Panasonic.
Jun 15, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic hdtv projection colors will not line up
If only minor convergence issues, the setup menu has user controls for 9-point convergence. If it's major misalignment in just one color, you may have a blown convergence amplifier chip. Big bucks repair, unfortunately. Chipsare about 30-40 dollars apiece but labor will kill you if they'll even fix it on-site. Most try to order $700+ board which is no longer available. Teh they send yours out for -10 weeks at similar prices.
Jun 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic projection tv
Standby light blinking 3 times means a convergence error. The two convergence IC's need to be changed Panasonic part# C5AA00000203 (do not substitute with a generic STK#) This is about a $300-$400 repair.
Sep 23, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
308 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
