Question about Konka K2001UM TV
Dark picture The picture is dark, I go to menu but do not have a code. I cannot get to adjust the ptcture. How do I get a code and how do I enter it.?
    Sergeant:
    Champion:
  • 375 Answers
Require model and make of unit and what code are you requesting .
Posted on Apr 13, 2008
Dvd's are very dark and hard to see.
Using the remote for the TV, enter the menu and find the picture settings.
Adjust the brightness and contrast controls until you are happy with the picture quality. Product Support
Mar 11, 2015 | LG 42LC2D 42 in. LCD HDTV
Brightness adjustment
There will be a control panel on the TV, usually on the side of the TV. You can use these buttons to enter the menu and adjust picture brightness. You can find an inexpensive universal remote easily.
Nov 04, 2013 | Sharp Aquos Televison & Video
I HAVE A PHILLIPS 37 PFL5522D THAT HAS A VERY DARK PICTURE CAN YOU ADVISE
if picture is still veiwable but dark, try to do some menu adjustment in contast, brightness. picture temp. if still dark or dim the problem maybe is the power supply filtering capacitors. worst is the t-con assembly.
Feb 25, 2011 | Philips Televison & Video
At start up my viewsonic va1912wb display blinks several times then i can see the picture but it is dark almost unreadable. Today it went darker than yesterday. HELP!
If it is dark due to brightness adjustment, get that adjusted. Usually when you adjust the brightness by pressing the menu button, the menu screen would not be dark. If everything is dark dark dark and you can only see some display but in very pitch darkness, then your monitor is a goner, backlit for the monitor is dead, and your monitor will need to be replaced. You can fix the backlit tubing, however it is risky, and expensive, and would cost less if you bought a replacement.
Jan 30, 2011 | Computers & Internet
The picture is too dark even after adjustment
your CCFL LCD backlight is weak. check also inverter.
May 25, 2009 | Samsung LN-T1953H 19 in. LCD HDTV
Picture getting dark
My jvc 27" tv was so dark I could hardly see any night scenes, even with the bright all the way on. If you push the sleep button, let go, then hold down the video and display (together), the service menu will come on. Scroll down to #7 (too dark) and adjust the brightness there. Works immediately. Good luck.
Nov 29, 2008 | JVC AV-27530 27" TV
Picture is too dark
How many years is your TV now? Usually TV has its life span, there comes a time that it happens. And need to look for a technicians, cause some of theme can still be repair by adjusting the brightness inside your TV.
Oct 19, 2008 | JVC AV-27530 27" TV
TV picture too dark
your screen adjustment needs to be turned up just a touch (flyback)
Aug 01, 2008 | JVC AV-27D302 27" TV
Picture is dark
sitnlisten - yes it does appear your pix tube is getting weak,but we may be able to turn up the flyback alittle to brighten up the picture.If you take the back off you will see the flyback-large black unit with a wire going to the round rubber cap on the back of the pix tube.Look at the flyback there are usually 2 adjusters one marked focus the other screen,just turn up the screen a little bit at a time.If you turn this up too much you will wind up with retrace lines on the screen.You may also want to check the pcboard ass'y for a sub bright adjust,and same thing small adjustments.If this don't help your pix tube may be too far gone.I hope this helps. cooltek Feb.1/08
Feb 14, 2008 | Zenith C27A24T 27" TV
Dark picture and greener than normal
hmmm curious why you would adjust convergance to adjust a dark picture?press menu button on remote and scroll down
are you have convergance problems?
convergance amp ic are know to go bad with this set.
Dec 17, 2007 | Toshiba 53H71 53 in. Rear Projection...
Televison & Video Logo
67 people viewed this question
Top Konka Televison & Video Experts
Arnel
Arnel
Computer Repairing
Computer Repairing
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
