Question about Dryers
I just purchased a Duet Dryer, model #WED9400SW...When I try to dry clothes, after approx. 1 min., I get fault code F23...Can you help???
  • sthornin Jun 26, 2008
    Dryer was dropped off yesterday and turned it in.  It ran for 60 sec and F23 error nothing in the manual either HELP
    Genius:
  • 1,073 Answers
Contact whirlpool factory service for help the number is in the owners manual, the f23 does not show up in my tech sheets, it is under warranty
Posted on Apr 12, 2008
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
Clothes dryer overheating?
use your dryer on air dry only (not heat dry) run about 2 min. check if your dryer is hot, that is heating element is short to ground and if your dryer is cold, check your dryer air venting system. (open the door if you see lint on door panel, it is a sing of bad air flow, it is dangerous to fire) hope its help.
Jul 10, 2014 | Whirlpool Dryers
Clothes are no longer drying on the normal setting. dryer will run for approx 10-15 minutes and shut off. clothers are not dry. have tried other settings and same thing happens.
Try cleaning the metal sensor strips right inside the door opening on the back of the filter housing assembly. You can see them if you put your head in the drum and look down. They are metal, about 4" long or so and about 1/2" apart. Residue builds up on these and over time will not allow them to sense the moisture properly. You can clean them with sandpaper, steel wool, wire brush, or Scotch Brite pad. That will likely remedy your trouble...
Dec 27, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Takes long to dry clothes
on your side, it is better you don't touch anything internal in the dryer as you can hurt yourself and spoil the device even more. have a professional take a look at it before you use it any further.
Jun 11, 2010 | Kenmore 62802 Electric Dryer
Just purchased a used Whirlpool Duet dryer(2 to 3 yrs. old). I hooked it up and placed it on a normal automatic cycle. The unit started up a little noisey but quitened down in approx. one min. Shortly...
try replacing the power cord, and make sure that you have a "dedicated" power sorce for the plug. The system board will shut the dryer down if a power supply issue is detected. This feature is to prevent fire hazards. Make sure your electric box is grounded and up to code.
Jun 26, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Error Code
I don't have a manual on the newest dryer like you have, but one of the models just older than yours has a F23 code that indicates a shorted thermistor.( temp sensor )
Since it is new you need to call for service. They will usually look up the code and tell you if it is anything you need to check but most likely you will need a repairman to repair it in warranty.
Post back if you have any questions.
Nov 08, 2007 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
428 people viewed this question
Top Dryers Experts
