Question about Samsung DVD-R135
Samsung dvd-r135 Unit powers up,tray door doesn't open. I had a similar problem with a Liteon 5007,but a firmware upgrade fixed it. Is there a firmware upgrade for the Samsung dvd-r135? thanks
The Disc Tray Will Not Open And/Or There Is A Disc Stuck In The Player. samsung dvd-r135 - spacer.gif Some DVD Players manufactured prior to 2003 have a Dealer Lock or Child Lock function. This will prevent the panel buttons from operating.
This function is activated by pressing the STOP button on the front panel
and the POWER button on the remote control simultaneously for four seconds in the power on state. Repeating this sequence releases the dealer lock. When the dealer lock in activated, DEALER LOCK ON or DEALER LOCK OFF scrolls on the display.
If this does not resolve your problem there may be an error with in the player. To resolve this try the following these steps:
  1. Unplug the DVD player from the electrical outlet and leave it unplugged for thirty seconds.
  2. Plug the DVD player back in to the electrical outlet, but do not turn the DVD player on.
  3. With the DVD player off, press the [Open/Close] button on the front of the DVD player. The home theater should power on when you press the [Open/Close] button and eject the tray.
The second option worked for me...
Posted on Jun 15, 2008
Tip
Xbox 360 - Stuck or sticking tray fix!
If your Xbox 360 DVD drive won’t eject it can be a very simple fix.
The Samsung drive is almost always a very simple fix, if you have another drive, it may be more difficult.
To identify your drive, follow this guide:
• Remove the faceplate by firmly grasping the opening for the USB ports and pulling.
• Underneath the DVD tray there should be a small hole.
• Look at the wires in the hole to identify which drive type you have.
Red and Black Wires = Samsung Drive
Yellow Wires = LiteOn Drive
White Wires = BenQ Drive
No Wires = Hitachi Drive
SAMSUNG:
It is very common for a Samsung drive to not eject. It’s a very simple fix for this!
1. Power on your Xbox 360
2. Press the eject button
3. When the Xbox 360 “tries” to eject, just simply push in on the tray cover.
That should make it eject!
If it does not, please follow the guide for the other drives below:
This requires you to disassemble your Xbox 360. IF you don’t know how, look it up on google, there are plenty of guides.
Then follow these steps:
1. Remove your Xbox 360 DVD drive from the Xbox 360
2. Turn over and remove the four screws securing the drive (6 screws if it’s a Hitachi)
3. Remove the top cover of the DVD drive.
4. Put the drive back in the Xbox 360, connect the wires, and power on your Xbox 360.
5. Once the 360 powers on, eject the drive. Most of the time it should eject normally. If it doesn’t you may have to force it.
6. Unplug the Xbox 360. If you turn it off with the power button the tray will close first, we need it open.
7. Near the front of the drive, you should now be able to see and access a small rubber band that was hidden by the tray.
8. Remove the band, lubricate and replace.
9. Replace the top cover and hook up and test.
10. If that doesn’t work, you may need a new rubber band. If you can get one of the right size, replace and test.
on May 13, 2010 | Video Game Consoles & Games
WHEN I PRESS THE OPEN/CLOSE BUTTON THE DISC TRAY DOES NOT OPEN. HOW CAN I GET THE DVD OUT OF THE DISC TRAY?
Look for the small hole in your dvd rom. This hole usually can fit a paper clip. Push and hold the paperclip inside the hole to open the dvd tray.
Dec 28, 2009 | Samsung DVD-R135
The DVD will not stop spinning. The door will not open either. When I took the cover of the players and plugged it in, the DVD just keeps spinning even when I hit STOP, OPEN, and turn the player OFF. ...
I've had this problem twice now.
The first time, I unplugged the unit for about a minute, plugged it back in and pressed the Open button. The disc was ejected and ran fine for about a week.
Then it happened again, but the unplugging didn't fix it this time.
Try this;
Unplug the unit and let it sit for a few mins to let the disc stop spinning. Then gently pull down on the DVD door. Look at the lower left side of the DVD tray and you should see a large slot. Shine a light into the slot and you will see a dime size white gear. I used a small flat head screwdriver to spin the gear to the right. After 2 small turns, the DVD tray opened enough so that I could pull it gently open. I took the DVD out, gently pushed the DVD tray back in and set the DVD player on my workbench to tinker with on a rainy day. Not sure what the root cause is, but I'll worry about that later!
Aug 14, 2009 | Samsung DVD-R135
Door will not open on my samsung dvd-r135
Most of the times the belt that drives the "door-assy" became too loose.
Answer: replace the belt
Jul 09, 2009 | Samsung DVD-R135
DVD recorder firmware corrupt?
http://www.liteonit.com/global/index.php?option=com_wrapper&Itemid=153
Jun 14, 2009 | Lite On LVW-5007
Pre-recorded dvds used before now will not load?
Since there are no firmware updates for this device, the lens is either dirty or defective. Unfortunately, the reviews for this product aren't very good. http://reviews.cnet.com/dvd-recorders/samsung-dvd-r135/4505-9141_7-31778396.html
Hope this answers your question. Best of luck.
Greg
May 28, 2009 | Samsung DVD-R135
Samsung DVD-R135 Factory Reset Procedure
HOLD DOWN CH UP & DN BUTTONS AT SAME TIME FOR 5 SEC. TRAY EJECTS AND RESET MESSAGE COMES ON SCREEN
Oct 03, 2008 | Samsung DVD-R135
My liteon combo sohc-5235k won't open its door
Straighten-out a thick paperclip and push it into the small hole just below the tray, usually towards the center-left. It must be pushed in straight, and when you meet resistance, use a little force. This is the drive's "emergency open" system.
Get the disk out and then replace the drive with a different brand like Samsung, HP, Plextor, etc.
May 13, 2008 | Lite On (SOHC-5235K-BKRTL) CD-RW/DVD-ROM...
Liteon LVW 5007 recorder problems
check with www.partstore.com and see if you can get a manual for your dvd recorder.i cannot tell off hand what to do the manual will.good luck or go to www.oxysearch.com for transfer of data.
Apr 02, 2007 | Lite On LVW-5007
Samsung DVD-R135 Logo
1,273 people viewed this question
Henry  Thomas
Henry Thomas
