Compaq Armada E500 PC Notebook
Problem for Compaq Armada E500 PC Notebook
Error Message: PXE-E61 Media Test Failure Check Cable
By nicorose on Apr 12, 2008
The Compaq Armada E500 notebook was working one minute. Next time it was booted up, screen started flashing, and any key you pressed it would just beep. Final message showed up in the middle of the screen - PXE-E61 Media Test Failure Check Cable.
Clarification Request
Posted by Compurepair on Apr 12, 2008
Your problem is with your hard-drive.
remove and reconnect.
Mike @ Compurepair.
Same Problem
May 24, 2009
-   Compaq 2100... Looking at it for a friend. First issue was the power supply over heating. Melted the last one, so he got a new power cord. Still getting real hot. Suggested he have the jack port looked at. The next day he calls after a night of running the thing for hours and says it will not boot and just gives the media test faliure ck cable. So I have attemped to switch the boot order. didnt help, also tried deleting the LAN option, it wont let me. Lost for options here. Any assistance would be appreciated. -   catcat1065
Jan 06, 2009
-   I have the same problem PXE E61: Media test failure.check cable PXE MOF: exiting PXE ROM
I just want to know that if I go back to my college and boot from the network, will my computer start up?
-   comdud
Jan 03, 2009
-   when i connect a new HDD & start pc the black screen appears with PXE-E61 Media Test Failure Check Cable , what should i do now pls give me answer as soon as possible-   nileshsonni
Dec 30, 2008
-   I want to boot my computer and it tells me that.PXE-E61 media test failure check cable-   Guest
Dec 24, 2008
-   Compaq M2000 V2.13 getting PXE-E61 Media Test Failure on reboot.
Tried removing and reseating disk card and got same problem.
Then removed RAM and disk card, same problem. Got into setup and tried hard disk test and setup shows no IDE disk drive.
Finally after mutiple attempts, achieved restarting windows and boot OK.
Now in the process of copying all documents to a USB drive.
Expecting that the drive will go soon...-   fbaratta
Best Solution
posted on Apr 18, 2008
Helpful)
mewms_14904
Rank: Guru  Compaq Expert
Rating: 88%, 1048 votes
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jun 12, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I keep getting this message, and after my Toshiba Satellite boots up I get this magenta and blue lines all over my screen before the computer stops working. I thought it might be overheating so I bought a chill pad and it still had the same problem. I removed the battery and left on on AC power, nothing bad has happened yet. Should I replace the battery with a new one?
Solution #3
posted on Apr 29, 2009
Very Helpful)
tceneut
Rank: Master
Rating: 87%, 19 votes
Hi Friends,
Compaq Presario PC Notebook's main problem's are Audio Driver, Software Installation etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here .
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Feb 21, 2009
Very Helpful)
asmelashh
Rank: Apprentice
Rating: 100%, 1 votes
the problem on my laptop is when it starts up it says media test failure chech cable so what would be the solution for this.
Was this helpful?
Yes
No
Solution #5
posted on Sep 03, 2009
Somewhat Helpful)
chiiibabvein
Rank: Apprentice
Rating: 75%, 2 votes
I have a ACER lap top that has error message PXE-MOF: Exiting Broadcom PXE ROM and PXE-MOF: Media Test Failure. Check Cable.
Was this helpful?
Yes
No
Solution #6
posted on Jan 04, 2009
Somewhat Helpful)
ohms
Rank: Wiz
Rating: 83%, 796 votes
the computer is set to boot from the network.
access the BIOS and set the computer to boot from the hard drive.
[more...]
Was this helpful?
Yes
No
Popular Solutions for Compaq Armada E500 PC Notebook
Questions and Unsolved Problems for Compaq Armada E500 PC Notebook
Do you recommend Compaq Armada E500 PC Notebook?
Answer
Answer
when i switch it on it keeps beeping like a button is pressed down
Answer
FREE do-it-yourself 2004 nissan armada keyless programing instructions
Answer
my touch pad on my armada e500 is not working the right click works bit this is all anyone can help... (More)
Answer
hoe kan ik het password van de hdd resetten hdd is locked with password
9 Other Users Have The Same Problem - Continued
Comment by jassisonu, posted on Dec 01, 2008
i m getting Error "PXE-E61 Media Test Failure" at Boot while booting up my system..
Comment by loverbabe, posted on Sep 18, 2008
I have e 2007 Toshiba Lapotop not even a yr old. I was on the internet andf suddenly it froze. I waited about 5 to 10 minutes to see if it was working again and it wasn't, so i turned it off, since i couldn't do anything like shutting down. Five minutes later i turned it back on and it wouldn't even let me log in. The whole screen was black and showed writing in white saying " ethernet failure" or " media testy failure". People say that it is the hard drive, and others that it can be a virus. Can you help?
Pat
Comment by Guest, posted on Jul 29, 2008
I install WinXP SP2 on PC with Asus P5GCMX Mainboard and set BIOS boot from Lan. Sometimes is ok Some getting that errors. Help!
Comment by maruf_na, posted on May 10, 2008
I'm trying to install windows by RIS and when boot up with LAN following message showing up -E61 Media Test Failure Check Cable problem
what is the solutuon of that my lancard is 3com
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , CA
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
