Question about Cyberhome CH-LDV 712 Portable DVD Player
You can hear it spinning -and it say's it's loading, but it never loads
No picture or sound ever comes up.
I bought the Player November 5, 2005. I was activated in the army the next week and have finally come home and putting things in place I discovered my cute little DVD player.
I couldn't take with me or never used. Could that be the problem it hasn't been used at all and in the box for all 2 1/2 years?
    Genius:
  • Cyberhome Master
  • 1,550 Answers
Limpia el lente del laser con un Qtip humedo con alcohol despues con el lado seco limpia los restos de alcohol que quedan,el problema es suciedad del lente suerte.
Posted on Apr 12, 2008
Sdv395 will not open
Hello
There are two possibilities for this fault. The first one is of its loading belt. If loading belt, that fastened to loading gear wheel to loading motor get loose or broken, the tray won't come out or go inside. Just place your ear very near to the player, and push eject button and listen, whether there is a motor running sound for at least 3 seconds. If you hear this sound, make sure that the belt is brokenn. The second chance is with loading motor itself. If it do not get proper voltage or got dmaged, the fault you describe here will occur. To replace this motor, you have to disassemble the CD mechanism. You must have all the tools to do the work and experience to disassemble and reassemble the CD mechanism. The motor is not a costly part, and can be bought from most of the electronic spare part selling shops at your town. OK.
Jan 03, 2012 | Toshiba SDV395 DVD Player/VCR
I have an Amana washer model NAV3330EWW purchased in November 2004. The washer will not drain during any of the cycles, It apparently went through the entire wash without draining after the wash or...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2011 | Amana Washing Machines
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
I load disc, it spins but no pic/sound
you better take it to someone professional in the domain as your portable dvd player seem to have problem with its laser
Oct 04, 2009 | Car Audio & Video
Ive had my RCA pearl 2gb mp3 player since November 2008. recently, it stopped loading the music. now all it does is turn on, show the "pearl" logo, and freeze. can u help me unfreeze it?
sounds like you may need to upgrade the firmware....her is the link to the file in case you dont have the software..
http://www.rcapearl.com/download.aspx
thank you . please let me know if it helped..
Jun 21, 2009 | RCA Pearl TH1102 MP3 Player
Dvd wont load
my dvd players one audio port not working
Jan 20, 2008 | Televison & Video
DVD player problem
you allneed to make sure the disc is spinning in the player you should hear it whirr as ut builds speed listen closely to it and keep a hand on it to feel when the disk quits if it starts. its supposed to spin v ery fast do you think you could tell by the sound of it if its spinning fast. some times they make a clicking noise because the drive mounts have slid down in the case and allows the disk to rub or tap the case. please let me know what you find out. this is for all three problems. let me know the results so i can further advise you.
Nov 26, 2007 | Cyberhome CH-DVD 300 DVD Player
Nw a3000 freezes on startup it has a spinning disc
Reset
Go to Sony's website to get the user manual/software to make sure you did everything correctly
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Get a Refund
Oct 04, 2007 | Sony Network Walkman NW-A3000 MP3 Player
SAYS "NO DISK"
sounds like the laser doide has failed, and may not be practical to have repaired. D-Dan
Aug 25, 2007 | Coby TF-DVD7100 Portable DVD Player
Cyberhome CH-LDV 712 Portable DVD Player Logo
81 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
