Question about Sharp Televison & Video
I have a BD-HP20U Blu-ray disc player. I have downloaded the software update but the player will not recognize the file on the USB device. I have followed the directions very closely and have re-tried the installation about ten times now.
I had the same experience, trying several different USB sticks with different capacities to see if it would make a difference.
What DID make a difference was resetting the BD-HP20U to factory settings, and THEN installing the update from the USB stick. This time, the unit recognized the file on the USB device and installed the update.
Posted on Mar 22, 2009
Vizio bluray vbr220 firmware update where ?
2 ways to update Vizio BR vbr220, see page 41 of manual
1. via USB
2. via internet
Via USB
1. Download the software from www.vizio.com to the root directory of a USB thumb drive.
Notes:
The USB storage device should be 1GB or larger with at least 100MB of free space and
formatted FAT32. NTFS and other file systems are not supported.
The USB storage device must not have other .iso or .dat files in the root directory.
2. Connect the USB storage device to the USB port on the front of your player.
3. Follow the on-screen instructions to update your player.
Via Internet
When a new software update is available, a message will be displayed on the Home menu. To
update the software:
1. Connect your Blu-ray player to your home network
2. Press the B (green) button.
OR
a. Press < or > to select Settings and then press SELECT.
b. Press < or > to select System. The System menu opens.
c. Press \/ to select Update Via Network and then press SELECT.
May 31, 2014 | Samsung BD-P1200 Blu-Ray Disc Player
Pandora Activation Code Not Generating
I have the Samsung BD-E5400 Blu-Ray Disc. Pandora did not recognize my log in and I had to go online to Samsung.com and download the latest software update BSP-E5400WWB-1006.0 and save it on my computer in a zip file. Then I had to unzip it and save the RUF file with the same name BSP-E5400WWB-1006.0.RUF on a thumb drive. I inserted the thumb drive in the back of the Blu-Ray and went into settings/support/software upgrade and picked the option to upgrade by usb. This quickly uploaded the updated software and restarted my Blu-Ray. Everything was fine then. I was able to go into Pandora and it recognized my account and email/password.
Dec 27, 2012 | Samsung WiFi Blu Ray Player - Black...
My Bd-hp22 Aquos blu-ray pllayer won't play a blu-ray and I think it needs an update but I don't know how... please help
Hello queerdust89,
Go to www.sharpusa.com and look for a software update. Download into a usb and plug the usb into your blu-ray player. There should be a usb port right at the front. Press menu using your blu-ray remote and go to settings. From there go to software update and click enter. If you have a password on your blu-ray then enter it in, if you have not set one then press enter to start checking data in your USB device. Once it detects it, click yes to start the software update. (NOTE: make sure that there is ONLY the software update in the usb, and other folders or files otherwise it will not update). Once you press enter to start updating, give a few minutes for it to update by itself. Once its done, just turn off the blu-ray and take out the usb. Turn it back on and try putting a blu-ray movie in there. I hope this helps, give me your feedback if it does not. Good luck.
- Joe
Sep 01, 2011 | Sharp AQUOS Blu-ray Disc Player
My blu ray player won't play blu ray copy of avatar
Try completing the update.
The update file can be found here http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Select bluray disc players
model not listed
type in model number
Then click on search
Click on the instructions and read thme if you need to. If you do not need to read the instructions click on the firmware and save it to your desktop. After the download has completed open the folder and click on extract all files under folder tasks, which should be on the left of the window nearer to the top.
At this time insert a 1, 2 or 4 GB flash drive into your computer. Then in the window click on next if you need to or browse and then my computer and then the icon of the usb device itself. Click on extract or next. When it is done safely remove the usb device from your computer by clicking on safely remove hardware located near the time on the bottom right hand side of the computer monitor.
Click on the usb device and click on stop. Remove it from the computer and place it in the back of the bluray player. Turn the tv and bluray player on as if you were going to view a bluray. There shouldn't be any discs inside. Press the setup button on the bluray remote control. Choose settings. Choose software update. Begin the update. After it is completed turn off the bluray player before removing the usb device.
If the usb device needs to be reformatted or if the zip file folder is placed on the usb device instead of the extracted file the download will not be successful.
May 04, 2010 | Sharp AQUOS Blu-ray Disc Player
I downloaded to the latest firmwire update to my usb for the sharp bd-hp22u player and when i try to install it it keeps saying no update found and i tried two different usb's and the player keeps sayin no...
I had the exact same problem! I realized though that I had to extract the Zipped files so my Sharp BD-HP22U could read them. Basically, I extracted the files onto another USB then placed that into my player and it finally recognized the files and began downloading the update. Avatar (Blu-ray), now plays! However, the chapter selection pops up on and off the screen during play. I guess I'll have to figure that out now. Anyone know how to fix that?
Apr 26, 2010 | Sharp BD-HP22U Player
Avitar says it needs to be updated
Step one is to find the manufacturers website for the Blu-ray player you are using.
Go to their technical support page and download the latest release or update for that player. (You may be asked to enter the model number and or serial number of the Blu-ray player you are using.)
Save or burn the downloaded file to a DVD and insert into your Blu-ray player. (While there are many easy to use DVD Burner software packages, Roxio is a user friendly application found on most computers.) Follow the on-screen prompts.
Or if the your player has a USB port, download the update into a flash drive, insert the flash into the usb port of your player, press Usb on the player's remote and the update should commence.
Good luck.
Apr 22, 2010 | Samsung BD-P1200 Blu-Ray Disc Player
Want to update my sharp blue ray disk player bd-hp21u - does not play current disks
To obtain the software update file, please call 1-800-BE-SHARP (23-74277). Save the update file into a USB drive.
  1. Insert the USB memory device
    with the update file into the BD
    STORAGE/SERVICE terminal on
    rear of this player.
  2. Press SETUP to display the SETUP
    MENU screen.
  3. Press arrow keys to select
    “SETTINGS”, then press ENTER.
  4. Press UP/DOWN keys to select “SOFTWARE
    UPDATE”, then ENTER.
  5. Enter the 4-digit number using 0-9.
  6. Press ENTER to start checking data
    in the USB memory device.
  7. During the data checking,
    “Checking” blinks.
  8. The current version of this unit software
    and the version of the update file on the
    USB memory device are displayed. To
    update this player software with update
    file, select “YES”, and press ENTER.
  9. If the USB memory device is not
    properly installed or the correct update
    file cannot be found on the USB
    memory device, an error message is
    displayed.Check the file on the USB memory
    device, and then reinsert the USB
    memory device correctly.
  10. Press ENTER to start updating.The screen becomes dark for a
    while until the update screen can be
    displayed. Please wait for the update
    screen to appear. Do not unplug the AC
    cord
  11. When the software is successfully
    updated, a screen is displayed
    indicating that the update process is
    completed.If the update has failed, check the file
    in the USB device and try Software
    Update again.
  12. Press POWER to turn off the player.
  13. Remove the USB memory device.
Oct 18, 2009 | Sharp BD-HP21U Blu-Ray Player
I have the aquos bd-hp20u and i cant find the update anywhere.... help!
just go to www.blu-ray.com/firmware. before you download, make sure you have selected the correct country location you are in now.
Sep 16, 2009 | Sharp BDHP20U Blu-Ray Player
I've downloaded a firmware update for my Aquos BD- HP20 Blu-ray player.  Unzipped the zip file and I put the .RVP file onto a Sony memory stick but when I try to get the player to recognize I file on the...
today i solved following errors on sharp blu-ray hp20 when updating software to play quantum of solace:
can't detect software: due to .rvp file being inside a folder--not in root directory on usb stick
more than one software file detected by player: .rvp hasn't been properly unzipped. the 2 gb disc and, as far as i could tell, my system (imac os 10.5.6) showed successfully extracted SINGLE file ready for transfer to dvd player, but dvd player said that there was more than one file. erased the 2 gb disc with disc first aid utility as part of exercise. also verified FAT format on 2 gb disc. only after i used a downloaded free mac utility *specifically for extracting ZIP files* to transfer the .rpv file to the 2 gb disc did the dvd player recognize the file and i successfully updated the player's software! (sorry for the run on, i think the logic is accurate)
Jan 29, 2009 | Sharp AQUOS Blu-ray Disc Player
Televison & Video Logo
486 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
