Question about Proscan PS60690 60" Rear Projection Television
Green screen After ready my dreams problems I replaced my HV splitter. Know I have a green screen. I didn't have any screen before. From the back of the TV I can see a blue reflection on the left and a red on the right. Looking from the front I see the three boards under the projectors the green (center) projector has a green led lit on it, but both the blue (right) and red (left)projector boards do not. What should i do????
  • BPWISN Apr 15, 2008
    When I replaced the HV splitter I had to unplug a board mounted to the frame at the front of the TV. No adjustents were made directly.
  • 2,335 Answers
If the lines you see are retrace lines, It means that the 200VDC are missing and not getting all the way to the video amplifier assemblies.
Did you touch the screen control settings by any chance before you replace the HV splitter?
Posted on Apr 14, 2008
My RCA HD52W59 problem
set is prone to two problems: high voltage splitter at front of set behind speaker grill arcs-------also set does have parts on HV board that do the same thing---HV transformer feeds voltage to the splitter.
Jun 07, 2012 | RCA HD52W59 HDTV Projection Television
Sony 60
Have you check the sleep timer? It could be possible reason why your tv shut off every 30mins. bc the timer was set.
Feb 20, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
I have a RCA D52W20 52" HDTV Ready TV which I
Unplug High voltage lead from HV splitter. This is a red wire going from HV transformer to similar (white plastic) device located up front, between picture tubes. Disconnect the one which is coming in, by strong energetic pull down with pliers. Leave those which go to picture tubs in. Make sure that disconnected wire is far from other components or metal parts (high voltage - SEVERAL INCHES SPARK CAN OCCUR) Turn the unit on - if different than 3 blinks - the splitter is your problem.
Feb 03, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Oct 02, 2010 | Sony KP-51WS500 51" Rear Projection...
It won't power up
You need the HV splitter. You can leave a email at the following link state your model number and let them know you need a HV splitter. They will respond quickly to your inquirery and they will provide free tech support to explain how to change the part.
http://servicemanuals.vstore.ca/
Jul 01, 2008 | Mitsubishi WS-55819 55" Rear Projection...
TV Won't Turn On
hi there i have the exact same tv and the exact same problem, i was just wondering if it was the hv splitter if so can you please let me know thank you
Jan 09, 2008 | Proscan PS60690 60" Rear Projection...
ProScan wont turn on
PS52690 52" projection TV (CTC188 series) that won't power up. From what I have read here and other places, the most common cause of this is the HV splitter. Actually, when the unit was 3 years old, the HV splitter went out and had to be replaced but it was under warranty at the time. I have found that the part I need is 205064 and runs around $40-$70
A post in another thread said that you could test to see if the HV splitter is really the problem by disconnecting the HV anode (big red wire) from the flyback (not the splitter since that will arc), plug the TV in, power it up, and if the power stays on and you hear sound, replace the HV splitter to fix the problem.
Dec 05, 2007 | Televison & Video
Wire diagram for splitter
On the 205064 hv splitter with the splitter mounted in the set,left to right, hv transformer,red tube,green tube,blue tube,plug on right side goes to screen asy,the black wires plug on the left side of splitter,which are grounds.
Jul 28, 2007 | RCA P52771AT 52" Rear Projection...
Open Questions:
Proscan PS60690 1st turns off then on by itself. Then 3 on-off cy I've had this exact problem twice. The 1st time I replaced the RCA part number 205064, which I believe is called the HV splitter. I used a generic non RCA part. The TV worked great for several months but went out again and it has been broken for 2 years. I finally ordered the new true RCA part number 205064 HV splitter. The TV, again seemed to be fixed, and what I a beautiful picture it had through our cable box. But, no happy ending at this point. It worked for a couple of days and then turned off and back on while my wife was watching it a few minutyes ago. It cycled off then back on twice in a 3 minute period so with the picture showing and tv still on she went ahead and turned it off. This is how the problem began several years ago the 1st time it went out. I don't want to turn it back on anymore in case the brand new HV Splitter is still OK. Does anyone know what other parts may be going out, causing the HV splitters to go bad and start shorting out. I know the HV spitters have been an ongoing problem with these sets, but since I just put a brand new RCA one in only 2 days ago I'm wondering if something else goes out first and causes the splitter to go bad after a period of time. I would appreciate any help. I can't afford a new set right now and the picture looks so great on this set using a cable box I feel it's definately worth fixing. ps Could missing o-rings cause this? I've never seen the o-rings. Even the first time I replaced the HV Splitter. Thanks
Feb 28, 2017 | Proscan PS60690 60" Rear Projection...
Televison & Video Logo
112 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
