FixYa.com
Tags:
System Power Supplies
Generic problem for all System Power Supplies
Power supply
posted by cemuni on Apr 12, 2008
does the store have a service that can test my power supply to see if it is working or not?
Comment by cemuni, posted on Apr 12, 2008
can I go to a store and have someone test my power supply?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 13, 2008
Not Rated (0)
califteacher
Rank:Guru Guru
Rating: 89%, 32 votes
Yes of course. I bought a tester of power supplies at a computer store for $20..
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP (399542-B21) 700-Watt Power Supply HP (5187-1098) ( 5187-1098 ) Power Supply HP (950-3473) (09503473) 120-Watt Power Supply HP (351599-001) (351599001) 460-Watt Power Supply HP (380312-B21) (380312B21) Power Supply HP (304231-001) (304231001) 75-Watt Power Supply HP (105739-001) (105739001) Power Supply
Can you Help with these System Power Supplies problems?
Loose power port
The power port is very loose... Answer This...
power supply
where do the plugs go on this... Answer This...
astec atx200-3516 power pack
hi there,i need to know how to... Answer This...
Codegen POWER SUPPLY CG|PS-350XA-12 RT...
Constant Beeping
Hi Of recent my power supply... Answer This...
Acer (91.AB814.003) 450-Watt Power Supply
SMPS powered on but the display...
I repair an SMPS and its all... Answer This...
Repair Service
Find System Power Sup. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
