Question about GE Spacemaker JVM1640SJ Microwave Oven
F3 light comes on the front panel and microwave does not work
Out of the blue this started. It is getting electricity b/c inside light comes on but keypad does not work and mic doesn't come on. We did lose power for a short while the other day but the mic worked for a day or so before this started. GE said to try to reboot it - we have and it doesn;t work. It is spacemaker XL - (manuf. Feb2000) Model# JVM132OWBOO2. Thanks for any help! Maureen
  • 2 more comments
  • socmoe Apr 18, 2008
    very helpful - thanks - just don't like the idea that an expensive microwave lasts less than 8 years!! We jsut bought a sharp caroseul for 100 bucks at sears. Maureen
  • Anonymous Jul 12, 2008
    the fan does not come on
  • Anonymous Jul 16, 2008
    We are having this same problem...F3 and nothing on the key pad works, but the inside light does come on...our microwave is less than 2 years old...we had to replace a similar one shortly after we bought our house because it caught on fire when we had a babysitter....I don't think we'll be buying anymore GE products!!!!!
  • msdundas2u Jul 17, 2008
    The F3 light comes on and the technician said that the control panel had broken keys not related to normal wear and tear. It was working fine for the last 8 months then F3 started to flash and the microwave beeps. I am sure it is still under warranty so I will contact GE.
  • GE Master
  • 9,098 Answers
F3 means a shorted keypad.
On this model (assuming it's JVM1320WB02) the repair cost would run about $115 if we do it for you. We regularly repair these for customer nationwide.
If you prefer to do it yourself, you can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Full details of our service are at http://www.microwavedisplay.com but if you still have questions, please reply to me directly via my site.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
F3 code
An F3 error code indicates that the keypad for the control panel is bad or has a short. This will cause the microwave to beep continuously after the set clock message appears.
On many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Aug 10, 2011 | General Electric Microwave Oven
Get F3 warning on panel. where are the codes located so i can see what the problem is, thank you JOHN BOMSA
Error code F3 on many models of microwave oven means a problem with the touch panel, (tact switches).
Hope this helps.
Feb 01, 2011 | General Electric PEB1590SMSS Stainless...
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My spacemaker stopped working and no panel lights. It's not the circuit breaker. Any ideas? model JVM140001
Could be the fuse inside the microwave is blown. You will need to unplug the microwave and remove the front control panel. Inisde the microwave housing you will need to trace the electrical wire coming into the unit. Usually you will find the in-line fuse located on the black power wire. You can pull the connectors off the fuse and test it with a continuity tester. If the fuse is blown replace it but make sure you use the same amp rated fuse as you removed. If the fuse blows again then there is an electrical short somewhere in the microwave.
Dec 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker Microwave Oven
F3 means shorted key panel. You get prompted with F3 error if a short on key panel is detected for over 60 seconds.
Test key panel wiring and eventually replace key panel.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 17, 2009 | GE Spacemaker JVM1750 Microwave Oven
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shows F3
microwave quits working and F3 comes up on the readout - along with a series of beeps - pressing any of the buttons on the touchpad does nothing - The F3 stays there and beeps intermittently
Jul 25, 2008 | GE JE1460 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
168 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
