Frigidaire Washer machine with burning smell
I have a Frigidaire super capacity plus top loading washer (Model: CRWS5700AS0). Just recently a burning smell is coming from the the washer. What could be the cause of it?
  • shylady_157 Apr 13, 2008
    The machine washes just fine. I smell the burning after the spin cycle.
  • 1,073 Answers
Burnt belt, tight center tub bearing, motor going bad, loose idler pulley spring, wiring issues at the motor, a lot of could bees
Posted on Apr 12, 2008
Model wdss4120aww GE Washer is leaking
If it's leaking during the agitation cycle, and only in 'large' and 'super' water levels, then that's just the way the washer is designed. I got rid of that piece of junk.
Mar 03, 2013 | GE WBSR3140D Top Load Washer
I have a westinghouse super capacity plus commercial washing machine. It spins on some washers and now has a burning smell to it
Unplug it and don't use it will be a burnt wire or the motor burning out there is a safety feature built into it which will cut the motor off after it gets hot so it wont start a fire. You will need a qualified technician come look at it and replace one or both sorry for the problem its giving you. Also if it is the motor they normally run $150 and up...
Jan 02, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My top load washer smells like moldy, nasty water
use some vinagar let wash
i heard deluted CLR works too, but delute it really good
Apr 18, 2010 | Maytag HAV2557 Top Load Washer
The burning smell is from your coupling and when this breaks the rubber spins across the plastic face of the opposite coupling. Your washer will not wash or spin until this is replaced. fortunately these are cheap and easy to replace. Refer to my step by step instructions to replace yours.
Here is the guide:
Mar 24, 2010 | Washing Machines
Walking ge super capacity plus washer
the drum straps are probebly broken just remove the front then remove the 2 1\4 inch screws that hold the top on remove the top the straps are located on top of the tub they are black rubber
Aug 28, 2009 | GE WBSR3140DW Top Load Washer
What is the capacity of my Kenmore washer?
3.2cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
White Westinghouse model #MWX413REW The
Belts can wear out from: Overloading, old age, or stretching. Sounds like a new belt is in order for you.
To see the specifications and schematics for this machine, and how many belts it has, type your model number into the web-site "SearsPartsDirect" when you are asked to .
God bless your efforts.
Dec 21, 2017 | Westinghouse WWS833ES Super Capacity Top...
White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
Frigidaire model CRWS5700AS0 washing machine burning belts
check the tub see if with the washer off.See if you can spin it both ways . let me know and i will advise futher this will be the spin tub
Jan 16, 2008 | Washing Machines
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
383 people viewed this question
Top Washing Machines Experts
