Question about Singer CE-100 Futura Computerized Sewing Machine
Flashing lights My machine will only sew straight stitches and embroidery will not work It even flashes when I wind the bobbin.
  • Anonymous Mar 19, 2014
    The lights down the rhs are flashing - bobbin won't wind
  • 19,396 Answers
This is a copy of the post on your premium solution thread.
According to Singer guidelines , if there is only red blinking light, then there is an fault inside the machine, unless it reset disconnecting from power.
If there is an error code with format EM-01 - EM-09 tell me which error you get and I should find a fix.
Here is a complete user guide, check pages 90-92 for common errors.
If you have no error message, and light does not go out with power disconnect then it may be a faulty control board.
In this case I suggest doing a last attempt removing all threads, and reset design unplug from power 10/15 mins.
Let me know if you still have the problem.
Regards
Posted on Apr 12, 2008
Haven't used my Kenmore sewing machine #385.19153 for a long time. The display shows "bobbin winding" I don't remember how to change for simple straight line stich
Try pushing the bobbin winder spindle to the left. It's on the top of the machine to the right of the spool. When this spindle is pushed to the right, the sewing machine is ready to wind a bobbin. Once the spindle is to the left, you should be able to select a straight stitch (stitches 10-12), set the stitch length and check the thread tension.
See https://www.manualslib.com/manual/505279/Kenmore-385-19153.html?page=44#manual for a picture.
I hope this helps.
Jul 04, 2017 | Kenmore Sewing Machines
Starting to sew basic stitch
You need to know how to thread the upper thread, wind thread onto a bobbin, and install the bobbin in the machine.
Be sure to lower the presser foot onto the fabric you are going to stitch.
Then press on the foot control pedal (like a gas pedal in a car). The harder you press, the faster it will stitch.
There are a lot of web sites and videos available. But, you should probably read the machine's manual.
How to Use your Sewing Machine for Beginners
How to Use Sewing Machine
How to Sew using sewing machine
Sewing 101 Guide for beginners like me The Dreamer
The Best Sewing Machines For Beginners She Likes to Sew
How to Use Sewing Machine Beginner Guide
Best Sewing Machines For Beginners Our TOP PICKS Sewing Made Simple
Oct 06, 2016 | Brother SE400 Computerized Sewing and...
After I "undid" winding my bobbin, the electronic display still showed the symbol for winding bobbin and the machine will only sew straight. None of the other buttons like back stitch or change stitches...
are you sure you've moved the bobbin winding mechanism back to the right spot? if its still pushed over against the bobbin spool holder it may be stopping the normal functions from working. If that isn't the problem then it may be something for the tech at the Elna dealers.
Sep 10, 2013 | Elna Sewing Machines
Drop in bobbin on singer 6234 will not thread empty Bobbiin thread winds around underside od bobbin
try using a different bobbin and see if that helps, if it doesn't
then the machine may need to be checked to see if there is
something wrong with the hook and the hook race.
Nov 29, 2012 | Janome Jem Silver 662 Mechanical Sewing...
Won't sew with foot dog down and using the freehand embroidery foot
Won't sew can mean more than one thing - the machine has no power or is seized up; the needle is not going up and down; the needle and bobbin are not forming a stitch.
When the feed dogs are down, you move the fabric by hand.
The presser foot has to be down to stitch.
If you wound a bobbin before you starting the sewing, did you disengage the bobbin winding feature(s)?
Mar 20, 2010 | Bernina Activa 140
I was doing fine zigzag, ran out of bobbin thread did not change any thing and now the thread bunches on the bottom and the machine does not advance. Bobbin casing pop up also this is a 774 model
Well The most probable cause of the lower thread breaking is an improperly wound bobbin. Regardless of where you wind the bobbin, inside the machine, on the top of the hand wheel or on the front side near the hand wheel, the basic "bobbin" rules apply.
** Always start with an empty bobbin. Never wind one color over another color.
** Don't wind the bobbin so full that it would be tight and hard to insert into the bobbin case. Most machines have an automatic "shut off" when the bobbin gets full, but if yours does not, be careful not to fill it too full.
** Wind the bobbin evenly across and in level layers.
** Never mix different sizes of thread in the bobbin and on the spool, unless you're doing sewing machine embroidery or some specialty type of sewing. Using different weights of thread on the spool and in the bobbin for general sewing will cause ragged stitches as well as other stitching problems.
So clean all the threads and do it work from start.........
Please reply ......
Thanks
Dec 29, 2009 | Singer Sewing Machines
Needle is moving when bobbin is winding & lights are flashing
Check the clutch at the knob on the right side of the machine, where you tighten it to sew & loosen it to wind a bobbin. It could be very loose and when you start to wind a bobbin, it tightens itself up.
Apr 06, 2009 | Singer 7436 - INGENUITY
Singer 7442 will not sew
Had the same problem as mommyb2 - it was the bobbin spindel was in the wrong position. Push bobbin spindel to the left and it works for sewing.
Have the same problem winding my first bobbin - pushed spindel to the right to engage bobbin fuction and the machine locks up and wont wind the bobbin. Irig did you bring it in for repair? I'm thinking its broke - which **** as mine is a brand new machine
Mar 23, 2008 | Singer 7442 Mechanical Sewing Machine
Singer CE-100 Futura Computerized Sewing Machine Logo
277 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
