Question about Brother DCP 7010 Multifunction Laser Copier
Unable to print 50
I have a MFC brother i can't print anything. It says unable to print 50. I need a solution.
    Champion:
  • 320 Answers
The error 50 i bekeive is that the laser unit needs to be replaced
Posted on Jan 16, 2009
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
The MFC has a mechanical problem, or a foreign object, such as a clip or ripped paper, is in the MFC.
Turn off the MFC's power switch, and then on again. If the error message continues, leave the MFC for several minutes and try it again.
Posted on Oct 17, 2008
3 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
pineworks
  • 4041 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Posted on Mar 02, 2010
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have the same problem. Most people i asked about it said it is a mechanical problem. It's better to bring it to a brother service center near you.
Feb 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
BROTHER MFC210-C "UNABLE TO INIT"
good day! Unable to print 50 means'' the machine does not work due to paper jam or some sensor...mostly unable to print 50 is sensor problem. to clear the problem clean the sensor, and then the mechanical...t
Dec 07, 2017 | Brother MFC 210C All-In-One InkJet Printer
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Brother DCP 7010 Multifunction Laser Copier Logo
451 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
