Question about Gaggia Titanium Espresso Machine
Steamer not functioning properly. (Every other part working perfectly)
  • 833 Answers
This can be quite a problem. First, the connections in some of these units are poorly made and need to be tightened. Open the unit and recycle any push on connections. Then, tighten any screw connections. Find the thermostat on the unit (black button thing about 1/2 inch (12mm) in in diameter...it has two wires coming out. Check for continuity across the terminals...if none...that's the problem. Next, use a coffee cleaner solution or vinegar and water to clean out the heat chamber (rinse well with water and then use baking soda and water).
Posted on May 09, 2008
My steamer is not working properly
Take the nozzle off and wash well also there is a small hole pin size at the top clean out with a pin and push the black inside piece inside nozzle out 2/3 MM out it must pop out I use a chop stick it's perfect. I had the same problem perfect now
Nov 07, 2015 | Gaggia Titanium Espresso Machine
Hot water steamer does not work properly
Any coffee maker, espresso machine related sales-support issues you can always get in touch with www.De-Brewerz.com
Dec 15, 2013 | Saeco Odea Giro Plus Coffee Maker
Saeco royal coffee bar steamer doesnt work
Hi there
Have you looked into the steamer to see if the things function there?
I suspect that there is something not working. What does the troublshooting say? Look there ;
http://www.generalmanual.com/Kitchen-Appliances/Saeco-Royal-Coffee-Bar.htm
Good luck
Kolbrun
Mar 05, 2012 | Saeco Royal Coffee Bar Coffee Maker,...
Conair steamer leaks water and wets my clothes.
When I use mine I hang the hand held part from my closet door, while I am waiting for it to heat up. When the hose gets too much condensation, from the steam, it leaks out... This will also happen if you try to use in the motion of an iron. The hand held part needs to be at a vertical position at all time to prevent leaking.
Jan 24, 2009 | Conair Compact Garment Steamer Iron
Can't Prime Water Circuit
Hi You need to switch Steam ON so it heats up and then turn Steam button OFF (no light) and then turn steamer knob counter clockwise you will hear the pump start up and then water will stream out. This is when it's primed. Turn steamer clock wise to close. You must do this everytime you use the steamer.
Dec 06, 2008 | Saeco VIA Venezia
Sunbeam 4710 steamer
The most likely reason they don't fit together perfectly right is because, when I bought the Sunbeam Instant Steamer Model 4710, it only came with 1 steaming tray.
Jul 21, 2008 | Sunbeam SUN-4710 5-Cup Rice Cooker
Conair steamer
Fill it with boiling hot mixture of half water half vinegar. Let it sit two hours. Rinse and repeat as necessary. Hope this helps you out.
George
Jul 03, 2008 | Conair Compact Garment Steamer Iron
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
104 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
