Question about Whirlpool Calypso GVW9959K Top Load Washer
Ob code Hello, the washer keeps stopping with "ob" code even if there's no clothes in it. It began with what I thought was "LP"...as I was a distance from it and didn't notice when I cleared and restarted the machine. I now see there's no "LP" code so maybe it was "LF"? That was the only time it gave that code. The next time the washer stopped it was "ob". (I'm familiar with that one). I readjusted the load and started the washer again. Since then it keeps stopping at the beginning of the cycle with "ob" and there's a buzzing or humming noise? Help!! Thanks, Debbie
  • squire828 Apr 25, 2008
    used same solution awesome
I'm having a similar problem with the buzzing and water not pumping out too. I found the problem is the plastic impeller slot has the teeth worn off by the metal water pump shaft. I didn't find anything clogging the flow or in the impeller. I guess something was binding the impeller and caused the teeth to get worn down.
Now I need to fine the part without having to purchase a complete pump.
Posted on Jun 09, 2008
Once a month you drag your machine outside, does this sound odd to you, we are in the 21st century, If you have to drag it out to the curb, you should shoot it and leave it there
Posted on Apr 30, 2008
Hello Debbie,
I, too, have fallen victim to the Whirlpool Kenmore Calypso curse. The repair is easy.
Get a shop vacuum and set it up to vacuum water. Put the washer's drain hose in the vacuum hose and make a seal, as best you can with your hand where the two hoses meet. Fire up the shop vacuum. It will remove most of the water from the machine. It may take a few minutes.
At this point, I usually finish disconnecting the machine from the wall and dolly it outside. You could repair it in place, but there may be a bit of water get spilled when you work on it.
Once outside, lay it on its back. You will find that the bottom of the machine has a removable piece of sheet metal. There are three screws in the front of this piece of metal. take 'em out and the metal can be removed.
Now, you will be looking for your water pump. It has two hoses connected to it, and is sort of circular in shape. It is held on by two clips. Pop the clips off. You can now get the pump lose from its motor.
Remove the two hose clamps by squeezing them with pliers. Slide the clapms up the hose a little so as to free the hose from the pump housing. Yank the hoses off. Twisting them a little may help loosen them.
Now you have the answer to your problem in your hand. There is something stuck in that pump which locks the impeller in place. Fish around in there and locate it. You can reach in there with a finger or a knife and try to rotate the rubber impeller. Once it is turning, and the junk has been removed you can put it back together by reversing the procedure listed above.
One small thing to pay attention to is that when you put the hoses back on, there's a little notch in the hose with a corresponding tab on the pump. You should line those up before you put the clamp back on. It will help make sure the hose is on far enough and located properly.
If this sounds complicated, let me assure you this can be done in 10 to 15 minutes. Once you've done it, it gets easier.
I do this to my machine about once a month when it quits.
You get the OB code 'cuz it tries to spin the load with the wash water still in it. ("Cuz the pump locked up). So, it thinks it's out of balance. It will attempt to drain and spin three times, and then it throws the code. My machine has thrown several different codes for the same problem. Junk in the pump.
I hope this helps. Don't pay for a new pump. I have never needed one.
Good luck,
Richard
Posted on Apr 16, 2008
Kenmore calypso washer will not spin the clothes ld or ob signal continue to show even after i have evenly distributed the clothes
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore 24032\24036 Top Load Washer
Ob keeps comoing on even if no clothes in machine
Mar 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washer keeps giving teh OB error, but it's completely leved and I've even tried removing all the cloths from it and it still keeps doing it.
Sep 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer says "ob" and there aren't any clothes in the washer
some machines can be over loaded and under loaded u need to take the clothes out and run it with nothing in if it does it again with nothing in the sensors are faulty and u need an expert to check it for u
Jul 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
The washer stopped running and draining "OB"
Jul 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Ld and ob error codes
hello.........
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
Sep 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso kemore elite washer
May 01, 2008 | Kenmore 15864/15862 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
311 people viewed this question
Dan Webster
Dan Webster
Sal De
